Samsung Galaxy S9 Display Replacement
  1. Samsung Galaxy S9 Display Replacement, Rear Glass Removal: step 1, image 1 of 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
    • You might need to reheat and reapply the iOpener several times during the removal procedure to get the adhesive warm enough to cut. Follow the iOpener instructions to avoid overheating.
    • The adhesive of the Samsung Galaxy S9 is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S9 Display Replacement: step 2, image 1 of 1
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive in the inside of the back cover is laid out as seen in the image.
    • You'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
  3. Samsung Galaxy S9 Display Replacement: step 3, image 1 of 3 Samsung Galaxy S9 Display Replacement: step 3, image 2 of 3 Samsung Galaxy S9 Display Replacement: step 3, image 3 of 3
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Insert an opening pick in the gap you created and slide it to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
  4. Samsung Galaxy S9 Display Replacement: step 4, image 1 of 2 Samsung Galaxy S9 Display Replacement: step 4, image 2 of 2
    • While inserting only the tip of the opening pick, slide it from the bottom left corner along the side to the top.
    • Slide the pick around the top corner and leave it there to prevent the adhesive from resealing.
  5. Samsung Galaxy S9 Display Replacement: step 5, image 1 of 3 Samsung Galaxy S9 Display Replacement: step 5, image 2 of 3 Samsung Galaxy S9 Display Replacement: step 5, image 3 of 3
    • Slide the opening pick from the bottom right corner along the side to the top.
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Slide the opening pick around the corner and cut the remaining adhesive at the top of the phone.
    • Don't open the phone all the way yet. The fragile fingerprint sensor cable still connects the back cover to the motherboard.
  6. Samsung Galaxy S9 Display Replacement: step 6, image 1 of 2 Samsung Galaxy S9 Display Replacement: step 6, image 2 of 2
    • Carefully lift the side of the rear glass where the volume button is located.
    • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  7. Samsung Galaxy S9 Display Replacement: step 7, image 1 of 1
    • Remove the rear glass.
    • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
    • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
  8. Samsung Galaxy S9 Display Replacement, NFC Antenna and Charging Coil: step 8, image 1 of 1
    • Remove the eight 4 mm Phillips #00 screws.
  9. Samsung Galaxy S9 Display Replacement: step 9, image 1 of 2 Samsung Galaxy S9 Display Replacement: step 9, image 2 of 2
    • Insert an opening pick under the right side of the plastic cover containing the NFC antenna and charging coil.
    • Twist or pry to release the plastic clips securing the cover.
  10. Samsung Galaxy S9 Display Replacement: step 10, image 1 of 2 Samsung Galaxy S9 Display Replacement: step 10, image 2 of 2
    • Insert an opening pick under the left side of the plastic cover.
  11. Samsung Galaxy S9 Display Replacement: step 11, image 1 of 1
    • Remove the plastic cover containing the NFC antenna and charging coil.
  12. Samsung Galaxy S9 Display Replacement, Battery Disconnection: step 12, image 1 of 1
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  13. Samsung Galaxy S9 Display Replacement, Screen: step 13, image 1 of 1
    • Remove the plastic cover from the motherboard.
  14. Samsung Galaxy S9 Display Replacement: step 14, image 1 of 2 Samsung Galaxy S9 Display Replacement: step 14, image 2 of 2
    • Use the flat end of a spudger to disconnect the display flex cable.
  15. Samsung Galaxy S9 Display Replacement: step 15, image 1 of 1
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • Tape over the glass if your display is cracked to keep further breakage contained and prevent bodily harm during your repair.
    • Lay overlapping strips of clear packing tape over the display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  16. Samsung Galaxy S9 Display Replacement: step 16, image 1 of 2 Samsung Galaxy S9 Display Replacement: step 16, image 2 of 2
    • Once the screen is warm to the touch, apply a suction cup to the upper edge of the phone.
    • If the phone's screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Insert an opening pick in the gap and start to cut the adhesive by sliding it to the top left corner.
  17. Samsung Galaxy S9 Display Replacement: step 17, image 1 of 2 Samsung Galaxy S9 Display Replacement: step 17, image 2 of 2
    • Insert another opening pick and slide it to the top right corner of the phone.
    • Insert a third opening pick to prevent the adhesive from resealing during the display removal.
  18. Samsung Galaxy S9 Display Replacement: step 18, image 1 of 2 Samsung Galaxy S9 Display Replacement: step 18, image 2 of 2
    • Start to slide the right opening pick half way down the side of the frame to cut the adhesive.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
    • Slide the left opening pick half way down the frame and leave it in its place.
  19. Samsung Galaxy S9 Display Replacement: step 19, image 1 of 3 Samsung Galaxy S9 Display Replacement: step 19, image 2 of 3 Samsung Galaxy S9 Display Replacement: step 19, image 3 of 3
    • Insert a fourth opening pick at the left side of the frame and slide it down to the bottom left corner to cut the adhesive.
    • The screen's flex cable is located just below the midpoint near the power button, and may interfere with your cutting tool.
    • Insert a fifth opening pick at the right side and cut the remaining adhesive with it.
  20. Samsung Galaxy S9 Display Replacement: step 20, image 1 of 2 Samsung Galaxy S9 Display Replacement: step 20, image 2 of 2
    • Once you cut the adhesive on all sides of the phone you can slowly lift the display upwards and remove it.
    • The display cable is threaded through a hole in the midframe; guide it through carefully in order to free the display.
    • Before installing a new display remove any remaining adhesive from the frame, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
    • If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged. If necessary, replace the frame.
Dominik Schnabelrauch
204,077 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,199 Guides authored
Past 24 Hours: 49
Past 7 Days: 301
Past 30 Days: 1,273
All Time: 162,298
