Up to 20% off select tools
Opening Philips EP-Models
Views: 46K
View statistics:
Past 24 Hours:
162
Past 7 Days:
806
Past 30 Days:
3,493
All Time:
46,433
Comments: 32
21 comments on steps, 11 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
For most repairs, you have to open the device. This isn’t a big problem with the EP models.
Note: EP 5xxx models are from an older Saeco line. Compare with Saeco Minuto.
This guide can also help with Saeco-models and with other fully automatic coffee machines from Philips and Gaggia - the devices all come from the same manufacturer and are very similarly built.
    1. Opening Philips EP-Models, Philips EP Model Coffee Makers: step 1, image 1 of 2 Opening Philips EP-Models, Philips EP Model Coffee Makers: step 1, image 2 of 2
      • Don't forget to unplug the power cord!
      • Remove all attachments, like the water reservoir, the brewing chamber, the bean compartment lid, and the drip tray. Remove all of the coffee beans.
      • Turn the machine around so the back is facing you. Remove the two T10 Torx screws at the bottom edge. Pull out the back at the bottom edge and lift it down.
      • It's important that these parts are readily visible:
      • The motherboard
      • The pump
      • The flow meter
      • The heating element
      Ask FixBot
    2. Opening Philips EP-Models: step 2, image 1 of 1
      • Unscrew the three T10 Torx screws in the coffee bean compartment.
      Ask FixBot
    3. Opening Philips EP-Models: step 3, image 1 of 3 Opening Philips EP-Models: step 3, image 2 of 3 Opening Philips EP-Models: step 3, image 3 of 3
      • Remove all the beans from the opening on the finger guard of the grinder. A T10 Torx screw will be visible in the center of the finger guard.
      • Unscrew the T10 Torx screw from the finger guard.
      • Lift the finger guard up.
      Ask FixBot
    4. Opening Philips EP-Models: step 4, image 1 of 2 Opening Philips EP-Models: step 4, image 2 of 2
      • Slightly lift the top cover up at the back edge.
      • When putting it back together, make sure the grinder control is sitting right.
      Ask FixBot
    5. Opening Philips EP-Models: step 5, image 1 of 2 Opening Philips EP-Models: step 5, image 2 of 2
      • Pull the upper cover out from under the front cover and lay it slightly offset.
      • Remove both of the T10 Torx screws attached to the side covers.
      • You can remove the top cover completely, especially if you must work on the grinder. But, if you want to see the machine functioning later, then lay it back in its original place.
      • Picture 2 shows the grinder, which can now be easily taken off.
      • If you want to repair the grinder: here are the instructions Replacing the Philips ceramic grinder motor and sensor
      Ask FixBot
    6. Opening Philips EP-Models: step 6, image 1 of 3 Opening Philips EP-Models: step 6, image 2 of 3 Opening Philips EP-Models: step 6, image 3 of 3
      • Both side panels are still screwed to the lower edge of the front. Unscrew both of the T10 Torx screws out from here.
      • Slide both side panels back a bit, and take them out from the bottom edge.
      Ask FixBot
Complete the steps in reverse order to reassemble your device.
13 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,359 Reputation
324 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
47 Members
7,166 Guides authored
11 Guide Comments
Leider stimmt diese Anleitung nicht für alle EP Modelle, ich besitze die Saeco Philips EP5960-10 diese zu öffnen ist eine Katastrophe. Da gibt es keine einzelne Wände, ich muss unbedingt unten an den Stromanschluss, da meine Maschine Plötzlich nicht mehr angeht, eventuell ist da eine Sicherung verbaut. Phillips will 200 € haben, da lege ich 100 drauf dann bekommt man was neues.
Michael Kollek - Reply Share
Danke für den Hinweis. Diese Modelle gehen auf eine ältere Linie zurück. Vergleiche mit der Saeco Exprelia.
VauWeh - Reply Share
Die Saeco Minuto kommt meiner gleich, leider um unten an den Stromanschluss zu kommen, muss man alles ausbauen, was ein Mist.
Ja, etwas lästig, aber es geht. Die neuen EP- Modelle sind viel angenehmer.
Past 24 Hours: 162
Past 7 Days: 806
Past 30 Days: 3,493
All Time: 46,433
