Nintendo Switch OLED Model Screen Replacement
  1. Nintendo Switch OLED Model Screen Replacement, Release the Joy Con controller locking tabs: step 1, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Release the Joy Con controller locking tabs: step 1, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Release the Joy Con controller locking tabs: step 1, image 3 of 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
    Ask FixBot
  2. Nintendo Switch OLED Model Screen Replacement, Remove the Joy Con controllers: step 2, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the Joy Con controllers: step 2, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the Joy Con controllers: step 2, image 3 of 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
    Ask FixBot
  3. Nintendo Switch OLED Model Screen Replacement, Remove the top screw: step 3, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Remove the top screw: step 3, image 2 of 2
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
    Ask FixBot
  4. Nintendo Switch OLED Model Screen Replacement, Remove the bottom screws: step 4, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Remove the bottom screws: step 4, image 2 of 2
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
    Ask FixBot
  5. Nintendo Switch OLED Model Screen Replacement, Remove the right screw: step 5, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Remove the right screw: step 5, image 2 of 2
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
    Ask FixBot
  6. Nintendo Switch OLED Model Screen Replacement, Remove the left screw: step 6, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Remove the left screw: step 6, image 2 of 2
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
    Ask FixBot
  7. Nintendo Switch OLED Model Screen Replacement, Open the kickstand: step 7, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Open the kickstand: step 7, image 2 of 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    Ask FixBot
  8. Nintendo Switch OLED Model Screen Replacement, Remove the back-side screws: step 8, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Remove the back-side screws: step 8, image 2 of 2
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
    Ask FixBot
  9. Nintendo Switch OLED Model Screen Replacement, Remove the rear case: step 9, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the rear case: step 9, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the rear case: step 9, image 3 of 3
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
    Ask FixBot
  10. Nintendo Switch OLED Model Screen Replacement, Remove the shield plate's tape: step 10, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Remove the shield plate's tape: step 10, image 2 of 2
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
    Ask FixBot
  11. Nintendo Switch OLED Model Screen Replacement: step 11, image 1 of 3 Nintendo Switch OLED Model Screen Replacement: step 11, image 2 of 3 Nintendo Switch OLED Model Screen Replacement: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
    Ask FixBot
  12. Nintendo Switch OLED Model Screen Replacement, Disconnect the primary Wi-Fi antenna: step 12, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Disconnect the primary Wi-Fi antenna: step 12, image 2 of 2
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
    Ask FixBot
  13. Nintendo Switch OLED Model Screen Replacement, Reroute the primary antenna's coaxial cable: step 13, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Reroute the primary antenna's coaxial cable: step 13, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Reroute the primary antenna's coaxial cable: step 13, image 3 of 3
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
    Ask FixBot
  14. Nintendo Switch OLED Model Screen Replacement, Unfasten the primary Wi-Fi antenna: step 14, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Unfasten the primary Wi-Fi antenna: step 14, image 2 of 2
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
    Ask FixBot
  15. Nintendo Switch OLED Model Screen Replacement, Remove the primary Wi-Fi antenna: step 15, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the primary Wi-Fi antenna: step 15, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the primary Wi-Fi antenna: step 15, image 3 of 3
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
    Ask FixBot
  16. Nintendo Switch OLED Model Screen Replacement: step 16, image 1 of 2 Nintendo Switch OLED Model Screen Replacement: step 16, image 2 of 2
    • Remove the primary Wi-Fi antenna.
    Ask FixBot
  17. Nintendo Switch OLED Model Screen Replacement, Disconnect the secondary Wi-Fi antenna: step 17, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Disconnect the secondary Wi-Fi antenna: step 17, image 2 of 2
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
    Ask FixBot
  18. Nintendo Switch OLED Model Screen Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: step 18, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: step 18, image 2 of 2
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
    Ask FixBot
  19. Nintendo Switch OLED Model Screen Replacement, Unfasten the secondary Wi-Fi antenna: step 19, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Unfasten the secondary Wi-Fi antenna: step 19, image 2 of 2
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
    Ask FixBot
  20. Nintendo Switch OLED Model Screen Replacement, Remove the secondary Wi-Fi antenna: step 20, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the secondary Wi-Fi antenna: step 20, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the secondary Wi-Fi antenna: step 20, image 3 of 3
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
    Ask FixBot
  21. Nintendo Switch OLED Model Screen Replacement: step 21, image 1 of 3 Nintendo Switch OLED Model Screen Replacement: step 21, image 2 of 3 Nintendo Switch OLED Model Screen Replacement: step 21, image 3 of 3
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
    Ask FixBot
  22. Nintendo Switch OLED Model Screen Replacement, Unfasten the shield plate: step 22, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Unfasten the shield plate: step 22, image 2 of 2
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
    Ask FixBot
  23. Nintendo Switch OLED Model Screen Replacement: step 23, image 1 of 2 Nintendo Switch OLED Model Screen Replacement: step 23, image 2 of 2
    iFixit Thermal Putty
    $9.95
    Buy
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
    Ask FixBot
  24. Nintendo Switch OLED Model Screen Replacement, Disconnect the battery: step 24, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Disconnect the battery: step 24, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery.
    Ask FixBot
  25. Nintendo Switch OLED Model Screen Replacement, Remove the tape: step 25, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the tape: step 25, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the tape: step 25, image 3 of 3
    Buy
    • Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
    Ask FixBot
  26. Nintendo Switch OLED Model Screen Replacement, Unfasten the daughterboard: step 26, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Unfasten the daughterboard: step 26, image 2 of 2
    • Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
    Ask FixBot
  27. Nintendo Switch OLED Model Screen Replacement, Remove the daughterboard: step 27, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the daughterboard: step 27, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Remove the daughterboard: step 27, image 3 of 3
    • The bottom of the daughterboard is connected to the motherboard via a press connector.
    • Insert a spudger between the edge of the daughterboard and the motherboard.
    • Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
    • Remove the daughterboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Ask FixBot
  28. Nintendo Switch OLED Model Screen Replacement, Disconnect the display's ZIF connector: step 28, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Disconnect the display's ZIF connector: step 28, image 2 of 2
    • Use an opening tool, spudger, or your fingernail to flip up the hinged locking flap on the display's ZIF connector.
    Ask FixBot
  29. Nintendo Switch OLED Model Screen Replacement: step 29, image 1 of 2 Nintendo Switch OLED Model Screen Replacement: step 29, image 2 of 2
    Buy
    • Use a pair of tweezers to pull the display cable straight out of its connector on the motherboard.
    Ask FixBot
  30. Nintendo Switch OLED Model Screen Replacement, Heat the right edge: step 30, image 1 of 1
    • Apply a heated iOpener to the right edge of the screen for 90 seconds to loosen the adhesive underneath.
    Ask FixBot
  31. Nintendo Switch OLED Model Screen Replacement, Insert an opening pick: step 31, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Insert an opening pick: step 31, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Insert an opening pick: step 31, image 3 of 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    Ask FixBot
  32. Nintendo Switch OLED Model Screen Replacement, Separate the right edge adhesive: step 32, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Separate the right edge adhesive: step 32, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Separate the right edge adhesive: step 32, image 3 of 3
    • Slide the pick along the right edge of the screen to separate the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Ask FixBot
  33. Nintendo Switch OLED Model Screen Replacement, Heat the top edge: step 33, image 1 of 1
    • Apply a heated iOpener to the top edge of the device for 90 seconds to loosen the adhesive underneath.
    Ask FixBot
  34. Nintendo Switch OLED Model Screen Replacement, Separate the top-right corner adhesive: step 34, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Separate the top-right corner adhesive: step 34, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Separate the top-right corner adhesive: step 34, image 3 of 3
    • Insert a new opening pick into the gap you created.
    • Rotate the opening pick around the top-right corner of the device.
    Ask FixBot
  35. Nintendo Switch OLED Model Screen Replacement, Separate the top edge adhesive: step 35, image 1 of 3 Nintendo Switch OLED Model Screen Replacement, Separate the top edge adhesive: step 35, image 2 of 3 Nintendo Switch OLED Model Screen Replacement, Separate the top edge adhesive: step 35, image 3 of 3
    • Slide the new pick along the right edge of the device towards the top-left corner.
    • Repeat the heating and slicing process on the remaining edges to separate the adhesive.
    Ask FixBot
  36. Nintendo Switch OLED Model Screen Replacement, Remove the screen: step 36, image 1 of 2 Nintendo Switch OLED Model Screen Replacement, Remove the screen: step 36, image 2 of 2
    Tesa 61395 Tape
    $8.95
    Buy
    • Lift the screen off the device, threading the display cable through the frame as you do.
    • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
    • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
    • During reassembly, make sure to thread the display cable through the frame before securing the screen adhesive.
    Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
19 other people completed this guide.
Alex Diaz-Kokaisl
241,312 Reputation
1,180 Guides authored
iFixit Member of iFixit
Staff
122 Members
27,491 Guides authored
9 Guide Comments
Amazing guide! Steps were easy to follow and allowed me to knock out my Switch OLED screen replacement in about 1.5-2 hours, including a few intermissions to clean the internals. The only thing I would add to this guide are a few steps at the end for removing the old adhesive, applying the new Tesa tape, folding/threading the ribbon cable on the new screen, and plugging the ribbon cable into the Switch to make this a true one-stop shop. The 1mm Tesa tape worked like a charm, although there is one side of the screen frame where you need to do three strips instead of one, you don't have to buy a bigger size just for that side. Thanks again iFixit! Y'all rock!
Kyle Bartolo - Reply Share
Hi Kyle.
Thank you for the appreciation and the tips! I changed the last step a bit to hopefully remind people to re-thread the display cable. We will consider making a dedicated reassembly step ;)
Alex Diaz-Kokaisl - Reply Share
nope not doin this
alex gamer - Reply Share
I stripped a screw on my Nintendo Switch OLED, now there’s absolutely no way for me to open it, I wanted to replace my Nintendo Switch Card Cover, and now I can’t. I’m gonna have to get a new Switch now :(
shayne_lavallee - Reply Share
Oh my goodness, I'm sorry to hear that! We've all been there. If you're willing to try something to remove the stripped screw, you can check out this guide for some strategies. Please let us know how it works out!
Past 24 Hours: 37
Past 7 Days: 309
Past 30 Days: 1,615
All Time: 76,092
