Nintendo Switch 2 Screen Replacement
    1. Nintendo Switch 2 Screen Replacement, Power off the console: step 1, image 1 of 3 Nintendo Switch 2 Screen Replacement, Power off the console: step 1, image 2 of 3 Nintendo Switch 2 Screen Replacement, Power off the console: step 1, image 3 of 3
      • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
      • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
      • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement, Remove the bottom screws: step 2, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the bottom screws: step 2, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
      • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement, Remove the top screw: step 3, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the top screw: step 3, image 2 of 2
      • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
      Ask FixBot
    4. Nintendo Switch 2 Screen Replacement, Heat the right side sticker: step 4, image 1 of 1
      • The Switch 2 has stickers on either side that need to be removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
      • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
      • You can use the kickstand to prop the console up vertically for easier access.
      • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
      Ask FixBot
    5. Nintendo Switch 2 Screen Replacement, Pry up the right side sticker: step 5, image 1 of 3 Nintendo Switch 2 Screen Replacement, Pry up the right side sticker: step 5, image 2 of 3 Nintendo Switch 2 Screen Replacement, Pry up the right side sticker: step 5, image 3 of 3
      • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
      • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
      • Gently pry up on the sticker until it starts to lift from the console.
      • Leave the tweezers in place to keep the sticker lifted.
      Ask FixBot
    6. Nintendo Switch 2 Screen Replacement: step 6, image 1 of 3 Nintendo Switch 2 Screen Replacement: step 6, image 2 of 3 Nintendo Switch 2 Screen Replacement: step 6, image 3 of 3
      Tool used on this step:
      Jimmy
      $7.95
      Buy
      • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
      • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
      • Remove the tweezers once the sticker is lifted.
      • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
      Ask FixBot
    7. Nintendo Switch 2 Screen Replacement, Heat the right side sticker: step 7, image 1 of 1
      • Reheat the bottom of the right side until it's hot to the touch.
      Ask FixBot
    8. Nintendo Switch 2 Screen Replacement, Remove the right side sticker: step 8, image 1 of 3 Nintendo Switch 2 Screen Replacement, Remove the right side sticker: step 8, image 2 of 3 Nintendo Switch 2 Screen Replacement, Remove the right side sticker: step 8, image 3 of 3
      • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
      Ask FixBot
    9. Nintendo Switch 2 Screen Replacement, Remove the left side sticker: step 9, image 1 of 3 Nintendo Switch 2 Screen Replacement, Remove the left side sticker: step 9, image 2 of 3 Nintendo Switch 2 Screen Replacement, Remove the left side sticker: step 9, image 3 of 3
      • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
      Ask FixBot
    10. Nintendo Switch 2 Screen Replacement, Remove the side screws: step 10, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the side screws: step 10, image 2 of 2
      • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
      Ask FixBot
    11. Nintendo Switch 2 Screen Replacement, Open the kickstand: step 11, image 1 of 3 Nintendo Switch 2 Screen Replacement, Open the kickstand: step 11, image 2 of 3 Nintendo Switch 2 Screen Replacement, Open the kickstand: step 11, image 3 of 3
      • Use your fingers to flip up the kickstand on the back of the console.
      • If there's a microSD Express card installed, remove it now before you continue to the next step.
      Ask FixBot
    12. Nintendo Switch 2 Screen Replacement, Remove the back-side screws: step 12, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the back-side screws: step 12, image 2 of 2
      • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
      Ask FixBot
    13. Nintendo Switch 2 Screen Replacement, Insert an opening pick: step 13, image 1 of 2 Nintendo Switch 2 Screen Replacement, Insert an opening pick: step 13, image 2 of 2
      • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
      Ask FixBot
    14. Nintendo Switch 2 Screen Replacement: step 14, image 1 of 2 Nintendo Switch 2 Screen Replacement: step 14, image 2 of 2
      • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
      Ask FixBot
    15. Nintendo Switch 2 Screen Replacement, Insert a second opening pick: step 15, image 1 of 3 Nintendo Switch 2 Screen Replacement, Insert a second opening pick: step 15, image 2 of 3 Nintendo Switch 2 Screen Replacement, Insert a second opening pick: step 15, image 3 of 3
      • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
      Ask FixBot
    16. Nintendo Switch 2 Screen Replacement: step 16, image 1 of 2 Nintendo Switch 2 Screen Replacement: step 16, image 2 of 2
      • Slide the first opening pick back to where it was first inserted.
      Ask FixBot
    17. Nintendo Switch 2 Screen Replacement, Remove the back cover: step 17, image 1 of 3 Nintendo Switch 2 Screen Replacement, Remove the back cover: step 17, image 2 of 3 Nintendo Switch 2 Screen Replacement, Remove the back cover: step 17, image 3 of 3
      • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
      • Hold the console with two hands. Rest your thumbs on the opening picks.
      • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
      Ask FixBot
    18. Nintendo Switch 2 Screen Replacement: step 18, image 1 of 3 Nintendo Switch 2 Screen Replacement: step 18, image 2 of 3 Nintendo Switch 2 Screen Replacement: step 18, image 3 of 3
      • Lift the back cover up from the bottom edge and remove it.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Remove the lower antenna screws: step 19, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the lower antenna screws: step 19, image 2 of 2
      • Use a JIS 00 driver to remove the three 4.4 mm‑long silver screws securing the lower antenna.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement, Remove the lower antenna: step 20, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the lower antenna: step 20, image 2 of 2
      • Use tweezers or your fingers to remove the lower antenna.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement, Remove the upper antenna screws: step 21, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the upper antenna screws: step 21, image 2 of 2
      • Use a JIS 00 driver to remove the two screws securing the upper antenna:
      • One 4.4 mm‑long silver screw
      • One 4.6 mm‑long green screw
      Ask FixBot
    4. Nintendo Switch 2 Screen Replacement, Remove the upper antenna: step 22, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the upper antenna: step 22, image 2 of 2
      • Use tweezers or your fingers to remove the upper antenna.
      Ask FixBot
    5. Nintendo Switch 2 Screen Replacement, Disconnect the lower antenna cable: step 23, image 1 of 3 Nintendo Switch 2 Screen Replacement, Disconnect the lower antenna cable: step 23, image 2 of 3 Nintendo Switch 2 Screen Replacement, Disconnect the lower antenna cable: step 23, image 3 of 3
      • Insert an arm of angled tweezers under the metal neck of the white interconnect cable coaxial connector (located beneath the lower antenna) and lift straight up to disconnect it.
      Ask FixBot
    6. Nintendo Switch 2 Screen Replacement, Disconnect the remaining antenna cables: step 24, image 1 of 3 Nintendo Switch 2 Screen Replacement, Disconnect the remaining antenna cables: step 24, image 2 of 3 Nintendo Switch 2 Screen Replacement, Disconnect the remaining antenna cables: step 24, image 3 of 3
      • Repeat this procedure to disconnect the three central coaxial connectors from the board.
      Ask FixBot
    7. Nintendo Switch 2 Screen Replacement, Disconnect the MicroSD connector: step 25, image 1 of 3 Nintendo Switch 2 Screen Replacement, Disconnect the MicroSD connector: step 25, image 2 of 3 Nintendo Switch 2 Screen Replacement, Disconnect the MicroSD connector: step 25, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
      Ask FixBot
    8. Nintendo Switch 2 Screen Replacement, Remove the shield plate screws: step 26, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the shield plate screws: step 26, image 2 of 2
      • Use a JIS 00 driver to remove the seven screws securing the shield plate:
      • Two 6.2 mm‑long silver screws
      • Five 4.4 mm‑long silver screws
      Ask FixBot
    9. Nintendo Switch 2 Screen Replacement, Lift the shield plate: step 27, image 1 of 3 Nintendo Switch 2 Screen Replacement, Lift the shield plate: step 27, image 2 of 3 Nintendo Switch 2 Screen Replacement, Lift the shield plate: step 27, image 3 of 3
      • Insert the flat end of a spudger between the shield plate and the processor's heat sink, next to the square (⛶) marking on the shield plate.
      • Twist the spudger to lift the shield plate and separate the thermal putty bonded to it. Keep lifting the shield plate until you don't feel resistance.
      Ask FixBot
    10. Nintendo Switch 2 Screen Replacement: step 28, image 1 of 3 Nintendo Switch 2 Screen Replacement: step 28, image 2 of 3 Nintendo Switch 2 Screen Replacement: step 28, image 3 of 3
      • Lift the left edge of the shield plate to ensure it's fully separated from the thermal putty.
      • Gently set the shield plate back down.
      Ask FixBot
    11. Nintendo Switch 2 Screen Replacement, Unroute the gray antenna cable: step 29, image 1 of 3 Nintendo Switch 2 Screen Replacement, Unroute the gray antenna cable: step 29, image 2 of 3 Nintendo Switch 2 Screen Replacement, Unroute the gray antenna cable: step 29, image 3 of 3
      • Insert one arm of angled tweezers underneath the gray antenna cable at the bottom-right corner of the console.
      • Lift the cable out of the black clip securing it to the frame.
      Ask FixBot
    12. Nintendo Switch 2 Screen Replacement: step 30, image 1 of 3 Nintendo Switch 2 Screen Replacement: step 30, image 2 of 3 Nintendo Switch 2 Screen Replacement: step 30, image 3 of 3
      • Unroute the gray antenna cable from its channel along the right edge of the console.
      Ask FixBot
    13. Nintendo Switch 2 Screen Replacement: step 31, image 1 of 2 Nintendo Switch 2 Screen Replacement: step 31, image 2 of 2
      • Lift and slide the shield plate away from the right edge of the console until the gray antenna cable is completely free.
      Ask FixBot
    14. Nintendo Switch 2 Screen Replacement, Remove the shield plate: step 32, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the shield plate: step 32, image 2 of 2
      • Pick up and remove the shield plate.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Disconnect the battery: step 33, image 1 of 2 Nintendo Switch 2 Screen Replacement, Disconnect the battery: step 33, image 2 of 2
      • Insert the flat end of a spudger underneath the flat-topped battery connector, located next to the battery, and pry up to disconnect it.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Clean the heat pipe: step 34, image 1 of 3 Nintendo Switch 2 Screen Replacement, Clean the heat pipe: step 34, image 2 of 3 Nintendo Switch 2 Screen Replacement, Clean the heat pipe: step 34, image 3 of 3
      Arctic Silver ArctiClean
      $11.99
      Buy
      • If you don't have replacement thermal putty, use the flat end of a spudger to distribute the old putty evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate, then skip this step.
      • Use the flat end of a spudger to scrape off the thermal putty on top of the copper heat pipe.
      • Apply high-concentration (90% or higher) isopropyl alcohol or thermal material remover to a cotton swab or lint-free cloth and wipe away any remaining thermal putty on both the heat pipe and shield plate.
      • Don't use a paper towel or rag, as they may scratch the shield plate.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Remove the heat sink screws: step 35, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the heat sink screws: step 35, image 2 of 2
      • Use a JIS 00 driver to remove the four 3.4 mm‑long silver screws securing the heat sink.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement, Free the heat sink: step 36, image 1 of 3 Nintendo Switch 2 Screen Replacement, Free the heat sink: step 36, image 2 of 3 Nintendo Switch 2 Screen Replacement, Free the heat sink: step 36, image 3 of 3
      • Insert the flat end of a spudger between the heat sink and the processor's heat spreader.
      • Twist the spudger to lift the heat sink and separate the thermal paste bonded to it.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement, Remove the heat sink: step 37, image 1 of 3 Nintendo Switch 2 Screen Replacement, Remove the heat sink: step 37, image 2 of 3 Nintendo Switch 2 Screen Replacement, Remove the heat sink: step 37, image 3 of 3
      • Lift the heat sink slowly to avoid bending its thin copper heat pipe.
      • Slowly lift the heat sink from the front, until the aluminum fin stack at the back is detached from the adhesive beneath it.
      • Remove the heat sink.
      Ask FixBot
    4. Nintendo Switch 2 Screen Replacement, Clean the thermal paste: step 38, image 1 of 3 Nintendo Switch 2 Screen Replacement, Clean the thermal paste: step 38, image 2 of 3 Nintendo Switch 2 Screen Replacement, Clean the thermal paste: step 38, image 3 of 3
      $11.99
      Buy
      • Use high-concentration (90% or higher) isopropyl alcohol or thermal material remover to soak the thermal paste on the processor's heat spreader for one minute.
      • Use a lint-free cloth or cotton swabs to wipe away the thermal paste.
      • Repeat this process until the processor's heat spreader is clean.
      Ask FixBot
    5. Nintendo Switch 2 Screen Replacement: step 39, image 1 of 2 Nintendo Switch 2 Screen Replacement: step 39, image 2 of 2
      • If you're replacing your heat sink, skip this step.
      • Repeat this process to clean the thermal paste off the bottom of the heat sink.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Disconnect the fan: step 40, image 1 of 2 Nintendo Switch 2 Screen Replacement, Disconnect the fan: step 40, image 2 of 2
      • Use the point of a spudger to flip up the locking flap on the fan cable ZIF connector, located next to the fan on the console's board.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement: step 41, image 1 of 3 Nintendo Switch 2 Screen Replacement: step 41, image 2 of 3 Nintendo Switch 2 Screen Replacement: step 41, image 3 of 3
      • Use tweezers or your fingers to gently pull the cable out of its socket.
      • If you're using tweezers, pull the cable out by its "wings" instead of gripping the cable itself.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement, Remove the fan screws: step 42, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the fan screws: step 42, image 2 of 2
      • Use a JIS 00 driver to remove the three 5.2 mm‑long silver screws securing the fan.
      Ask FixBot
    4. Nintendo Switch 2 Screen Replacement, Remove the fan: step 43, image 1 of 3 Nintendo Switch 2 Screen Replacement, Remove the fan: step 43, image 2 of 3 Nintendo Switch 2 Screen Replacement, Remove the fan: step 43, image 3 of 3
      • Slide the fan out of its recess to free its cable, then pick it up to remove it.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Disconnect the screen: step 44, image 1 of 2 Nintendo Switch 2 Screen Replacement, Disconnect the screen: step 44, image 2 of 2
      • Use your finger or the flat end of a spudger to flip up the locking flap on the screen cable ZIF connector.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement: step 45, image 1 of 2 Nintendo Switch 2 Screen Replacement: step 45, image 2 of 2
      • Use tweezers or your fingers to gently pull the cable out of its connector.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement, Heat the bottom edge: step 46, image 1 of 1
      • Flip the console over so the screen is facing up.
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • Be careful not to heat the console hotter than this—the frame is susceptible to heat damage.
      Ask FixBot
    4. Nintendo Switch 2 Screen Replacement, Insert an opening pick: step 47, image 1 of 3 Nintendo Switch 2 Screen Replacement, Insert an opening pick: step 47, image 2 of 3 Nintendo Switch 2 Screen Replacement, Insert an opening pick: step 47, image 3 of 3
      • Apply a suction handle to the bottom edge of the screen, above the right speaker and ventilation cutouts.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      • If you can't create a gap large enough to fit an opening pick, reheat the bottom edge of the screen and try again.
      Ask FixBot
    5. Nintendo Switch 2 Screen Replacement, Separate the bottom adhesive: step 48, image 1 of 2 Nintendo Switch 2 Screen Replacement, Separate the bottom adhesive: step 48, image 2 of 2
      • Slide your pick across the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Nintendo Switch 2 Screen Replacement, Heat the left edge: step 49, image 1 of 1
      Ask FixBot
    7. Nintendo Switch 2 Screen Replacement, Separate the left adhesive: step 50, image 1 of 3 Nintendo Switch 2 Screen Replacement, Separate the left adhesive: step 50, image 2 of 3 Nintendo Switch 2 Screen Replacement, Separate the left adhesive: step 50, image 3 of 3
      • Insert a second opening pick next to the first one and slide it up the left edge of the screen.
      Ask FixBot
    8. Nintendo Switch 2 Screen Replacement, Separate the remaining adhesives: step 51, image 1 of 3 Nintendo Switch 2 Screen Replacement, Separate the remaining adhesives: step 51, image 2 of 3 Nintendo Switch 2 Screen Replacement, Separate the remaining adhesives: step 51, image 3 of 3
      • Repeat the heating and sliding procedure along the remaining screen edges.
      Ask FixBot
    9. Nintendo Switch 2 Screen Replacement, Remove the screen: step 52, image 1 of 2 Nintendo Switch 2 Screen Replacement, Remove the screen: step 52, image 2 of 2
      • Lift the screen off the frame to remove it.
      • If any adhesive strips are still stuck to the frame, peel it up with slow, steady force to release it.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Disassembly complete: step 53, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Clean the frame: step 54, image 1 of 3 Nintendo Switch 2 Screen Replacement, Clean the frame: step 54, image 2 of 3 Nintendo Switch 2 Screen Replacement, Clean the frame: step 54, image 3 of 3
      Adhesive Cleanup Kit (Set of 12)
      $7.99
      Buy
      • Use the point of a spudger to scrape off any adhesive left on the frame.
      • Apply a bit of isopropyl alcohol to a cotton swab or lint-free cloth and clean the frame until it's free of adhesive residue.
      • Alternatively, use our adhesive cleanup kit.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement, Apply new adhesive: step 55, image 1 of 3 Nintendo Switch 2 Screen Replacement, Apply new adhesive: step 55, image 2 of 3 Nintendo Switch 2 Screen Replacement, Apply new adhesive: step 55, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • If your replacement screen comes with adhesive pre-applied, skip this step.
      • Use your fingers to install strips of thin, double-sided tape to the raised lip along the edges of the frame. Use 1 mm strips for the top and bottom edges and 2 mm strips for the sides.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement, Prepare the adhesive: step 56, image 1 of 3 Nintendo Switch 2 Screen Replacement, Prepare the adhesive: step 56, image 2 of 3 Nintendo Switch 2 Screen Replacement, Prepare the adhesive: step 56, image 3 of 3
      • Use angled tweezers to peel off all liners from the adhesive.
      Ask FixBot
    4. Nintendo Switch 2 Screen Replacement, Install the screen cable: step 57, image 1 of 3 Nintendo Switch 2 Screen Replacement, Install the screen cable: step 57, image 2 of 3 Nintendo Switch 2 Screen Replacement, Install the screen cable: step 57, image 3 of 3
      • Don't adhere the screen to the frame yet.
      • Align the screen's cable with its cutout in the frame.
      • Route the cable through its cutout, ensuring it reaches its connector on the board.
      Ask FixBot
    5. Nintendo Switch 2 Screen Replacement, Adhere the screen: step 58, image 1 of 3 Nintendo Switch 2 Screen Replacement, Adhere the screen: step 58, image 2 of 3 Nintendo Switch 2 Screen Replacement, Adhere the screen: step 58, image 3 of 3
      • Align the right edge of the screen with its recess in the frame.
      • Press the right edge of the screen into place, then work your way to the left edge until the entire screen is adhered to the frame.
      • If the screen starts to feel misaligned as you work your way down, lift it back up and try again. Try to avoid stretching or creasing the adhesive.
      Ask FixBot
    6. Nintendo Switch 2 Screen Replacement, Connect the screen cable: step 59, image 1 of 3 Nintendo Switch 2 Screen Replacement, Connect the screen cable: step 59, image 2 of 3 Nintendo Switch 2 Screen Replacement, Connect the screen cable: step 59, image 3 of 3
      • Use tweezers or your fingers to slide the screen cable into its ZIF connector until it's fully seated.
      • If you're using tweezers, you can use the flat end of a spudger to help guide the cable into its connector.
      • Flip the hinged locking flap down to secure the cable.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Install the fan: step 60, image 1 of 3 Nintendo Switch 2 Screen Replacement, Install the fan: step 60, image 2 of 3 Nintendo Switch 2 Screen Replacement, Install the fan: step 60, image 3 of 3
      • Slide the fan into its recess. Ensure its cable slides underneath the edge of the board.
      • Align the fan with its screw posts on the frame.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement: step 61, image 1 of 2 Nintendo Switch 2 Screen Replacement: step 61, image 2 of 2
      • Use a JIS 00 driver to install the three 5.2 mm‑long silver screws securing the fan.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement, Connect the fan: step 62, image 1 of 3 Nintendo Switch 2 Screen Replacement, Connect the fan: step 62, image 2 of 3 Nintendo Switch 2 Screen Replacement, Connect the fan: step 62, image 3 of 3
      • Use tweezers or your fingers to slide the fan cable into its ZIF connector until it's fully seated.
      • If you're using tweezers, you can use a spudger to help guide the cable into its connector.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Install thermal paste: step 63, image 1 of 3 Nintendo Switch 2 Screen Replacement, Install thermal paste: step 63, image 2 of 3 Nintendo Switch 2 Screen Replacement, Install thermal paste: step 63, image 3 of 3
      iFixit Thermal Paste
      $9.95
      Buy
      • Apply a bead of new thermal paste to the center of the processor's copper heat spreader, roughly the size of a pea.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement, Install the heat sink: step 64, image 1 of 3 Nintendo Switch 2 Screen Replacement, Install the heat sink: step 64, image 2 of 3 Nintendo Switch 2 Screen Replacement, Install the heat sink: step 64, image 3 of 3
      • Set the heat sink's aluminum fins into its recess behind the fan, then lower the heat sink onto the board.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement: step 65, image 1 of 2 Nintendo Switch 2 Screen Replacement: step 65, image 2 of 2
      • Use a JIS 00 driver to partially install the four 3.4 mm‑long silver screws securing the heat sink.
      • Tighten the screws in an X pattern. For example: bottom left, top right, bottom right, then top left.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Connect the battery: step 66, image 1 of 2 Nintendo Switch 2 Screen Replacement, Connect the battery: step 66, image 2 of 2
      • Align the battery connector over its socket on the board.
      • Use your finger or the flat end of a spudger to press the battery connector onto its socket until it's fully seated.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Apply thermal putty: step 67, image 1 of 3 Nintendo Switch 2 Screen Replacement, Apply thermal putty: step 67, image 2 of 3 Nintendo Switch 2 Screen Replacement, Apply thermal putty: step 67, image 3 of 3
      iFixit Thermal Putty
      $9.95
      Buy
      • Apply a line of new thermal putty down the center of the heat pipe, roughly the thickness of a pea.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement, Route the gray antenna cable: step 68, image 1 of 3 Nintendo Switch 2 Screen Replacement, Route the gray antenna cable: step 68, image 2 of 3 Nintendo Switch 2 Screen Replacement, Route the gray antenna cable: step 68, image 3 of 3
      • Hold the top‑right corner of the shield plate above the top‑right corner of the console.
      • Route the gray antenna cable underneath the black hook near the top corner of the frame.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement, Lower the shield plate: step 69, image 1 of 2 Nintendo Switch 2 Screen Replacement, Lower the shield plate: step 69, image 2 of 2
      • Lower the shield plate into place and align it with its screw holes.
      Ask FixBot
    4. Nintendo Switch 2 Screen Replacement, Finish routing the gray antenna cable: step 70, image 1 of 3 Nintendo Switch 2 Screen Replacement, Finish routing the gray antenna cable: step 70, image 2 of 3 Nintendo Switch 2 Screen Replacement, Finish routing the gray antenna cable: step 70, image 3 of 3
      • Route the gray antenna cable down its channel on the right edge of the frame.
      Ask FixBot
    5. Nintendo Switch 2 Screen Replacement: step 71, image 1 of 3 Nintendo Switch 2 Screen Replacement: step 71, image 2 of 3 Nintendo Switch 2 Screen Replacement: step 71, image 3 of 3
      • Press the gray antenna cable into its groove at the bottom of its channel, and continue routing until it's secured to the clip at the bottom of the frame.
      Ask FixBot
    6. Nintendo Switch 2 Screen Replacement, Install the shield plate screws: step 72, image 1 of 2 Nintendo Switch 2 Screen Replacement, Install the shield plate screws: step 72, image 2 of 2
      • Use a JIS 00 driver to install the seven screws securing the shield plate:
      Ask FixBot
    7. Nintendo Switch 2 Screen Replacement, Connect the MicroSD connector: step 73, image 1 of 2 Nintendo Switch 2 Screen Replacement, Connect the MicroSD connector: step 73, image 2 of 2
      • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    8. Nintendo Switch 2 Screen Replacement, Connect the antenna cables: step 74, image 1 of 3 Nintendo Switch 2 Screen Replacement, Connect the antenna cables: step 74, image 2 of 3 Nintendo Switch 2 Screen Replacement, Connect the antenna cables: step 74, image 3 of 3
      • Use tweezers to hold the lower antenna coaxial connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
      • Repeat this process to connect the three central coaxial connectors to their respective sockets.
      • The black cable connects to the socket closest to the fan, the white to the middle, and the gray the furthest away.
      Ask FixBot
    9. Nintendo Switch 2 Screen Replacement, Install the upper antenna: step 75, image 1 of 3 Nintendo Switch 2 Screen Replacement, Install the upper antenna: step 75, image 2 of 3 Nintendo Switch 2 Screen Replacement, Install the upper antenna: step 75, image 3 of 3
      • Use tweezers or your fingers to align the upper antenna with its screw holes and black alignment pegs and set it into place.
      • Use a JIS 00 driver to install the two screws securing the upper antenna:
      Ask FixBot
    10. Nintendo Switch 2 Screen Replacement, Install the lower antenna: step 76, image 1 of 3 Nintendo Switch 2 Screen Replacement, Install the lower antenna: step 76, image 2 of 3 Nintendo Switch 2 Screen Replacement, Install the lower antenna: step 76, image 3 of 3
      • Use tweezers or your fingers to align the lower antenna with its screw holes and gray alignment pegs and set it into place.
      • Use a JIS 00 driver to install the three 4.4 mm‑long screws securing the lower antenna.
      Ask FixBot
    1. Nintendo Switch 2 Screen Replacement, Prepare the back cover: step 77, image 1 of 3 Nintendo Switch 2 Screen Replacement, Prepare the back cover: step 77, image 2 of 3 Nintendo Switch 2 Screen Replacement, Prepare the back cover: step 77, image 3 of 3
      • Fully pull out the game card tray.
      • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
      • Check the microphone to ensure it's fully seated in its slot in the frame.
      Ask FixBot
    2. Nintendo Switch 2 Screen Replacement, Install the back cover: step 78, image 1 of 3 Nintendo Switch 2 Screen Replacement, Install the back cover: step 78, image 2 of 3 Nintendo Switch 2 Screen Replacement, Install the back cover: step 78, image 3 of 3
      • Align the top of the back cover with the top of the console.
      • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
      • Press along the top edge to fasten the clips securing the back cover to the console.
      Ask FixBot
    3. Nintendo Switch 2 Screen Replacement: step 79, image 1 of 2 Nintendo Switch 2 Screen Replacement: step 79, image 2 of 2
      • Squeeze the rest of the back cover and console together to fasten the clips.
      Ask FixBot
    4. Nintendo Switch 2 Screen Replacement, Install the back-side screws: step 80, image 1 of 3 Nintendo Switch 2 Screen Replacement, Install the back-side screws: step 80, image 2 of 3 Nintendo Switch 2 Screen Replacement, Install the back-side screws: step 80, image 3 of 3
      • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
      • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
      Ask FixBot
    5. Nintendo Switch 2 Screen Replacement, Install the side screws: step 81, image 1 of 2 Nintendo Switch 2 Screen Replacement, Install the side screws: step 81, image 2 of 2
      • Use a JIS 00 driver to install the two 3.6 mm‑long gold screws on each side of the console (four in total).
      Ask FixBot
    6. Nintendo Switch 2 Screen Replacement, Test the console: step 82, image 1 of 2 Nintendo Switch 2 Screen Replacement, Test the console: step 82, image 2 of 2
      • Power on the console and test functionality to ensure it's working as expected.
      Ask FixBot
    7. Nintendo Switch 2 Screen Replacement, Install the stickers: step 83, image 1 of 3 Nintendo Switch 2 Screen Replacement, Install the stickers: step 83, image 2 of 3 Nintendo Switch 2 Screen Replacement, Install the stickers: step 83, image 3 of 3
      • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
      • Set the sticker into its recess, first on one side, then the other.
      • Use your finger or the flat end of a spudger to press the sticker into place.
      • If the sticker isn't sticking well, apply heat after you press it into place.
      Ask FixBot
    8. Nintendo Switch 2 Screen Replacement: step 84, image 1 of 3 Nintendo Switch 2 Screen Replacement: step 84, image 2 of 3 Nintendo Switch 2 Screen Replacement: step 84, image 3 of 3
      • Repeat this procedure to install the left side sticker.
      Ask FixBot
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Nick Schultz
65,843 Reputation
343 Guides authored
2 Guide Comments
Where can I find replacement screen?
Ashutosh Sah - Reply Share
They're not available yet! We'll update the guide once we have the part.
Nick Schultz - Reply Share
Past 24 Hours: 56
Past 7 Days: 357
Past 30 Days: 1,797
All Time: 20,256
