Introduction
Use this guide to replace the screen on your Motorola Moto Z Play by swapping out the screen/digitizer unit. The replacement screen assembly does not normally include the fingerprint sensor or the front camera flash. If these parts are not being replaced in addition to the screen/digitizer, they must be transferred from the old screen to the new one.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there's a good chance of accidentally damaging the display when removing it. If you're replacing the display anyway, then you don't have to worry—but if you intend to re-use the display, heed all warnings and work very carefully.
If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
If your display is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
Prepare an iOpener and heat the front of the phone along its left edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
For reference, refer to the first image, showing the back of the display assembly (right) after it has been removed from the phone (left).
If you plan to re-use the display assembly, pay particular attention to the side edges. When slicing through the glue in this area, you must be careful to insert your tool less than 2 mm, or your tool will come in contact with the display panel and damage it.
Playing cards are a safer, but much slower, prying tool. The soft paper cards are less likely to damage the display panel, which is good news if you plan to reuse it.
Apply a suction cup to the display, near the middle of the left edge.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
Insert your tool at the top right corner of the phone, and begin to slide it underneath the top bezel to separate the glue.
When your tool just passes the left edge of the earpiece speaker, stop.
Slide or roll your tool over the top of the flash module for the selfie camera to avoid damaging it.
While holding the display open, use the point of a spudger to pry up the locking tab on the fingerprint sensor cable's ZIF connector.
At the opposite end of the phone, use your spudger to flip open the locking tab on the display cable connector.
The locking tab on the is dark colored and runs almost the entire width of the ZIF connector. It is located on the opposite side from where the cable connects into. Pry upward from the bottom- it works like a hinge.
Apply heat for 2-3 minutes to the bezel area below the display on your old display assembly, in order to soften the adhesive securing the fingerprint sensor.
Peel off and remove the liner from the adhesive tape on the fingerprint sensor.
Place your new display face-down, and carefully lower the fingerprint sensor into position on the back.
Press firmly on the back of the fingerprint sensor for several seconds to allow the adhesive to bond and secure it in place.
Peel away and remove all the old display adhesive from the body of your phone.
Use the point of your spudger to scour away and remove any smaller bits of adhesive that remain stuck.
For best results, clean the area underneath the removed adhesive with isopropyl alcohol to help prep the surface so the new adhesive bonds more strongly.
If yours came with a paper liner, peel it away and remove it.
Peel off and discard the plastic liner, exposing the display adhesive.
Should the removal of the blue plastic backing wait until after verifying the screen works in the next step?
Well, you can’t connect the screen with the plastic in the way. But in principle, you’re right—it wouldn’t be a bad idea to pause before installing the display adhesive, plug everything in, and verify that it works. Unfortunately, you then have to unplug it again to install the adhesive, so you’ll want to test it again once it’s plugged back in, but before sealing up your phone—just to make sure the cables are seated properly. So, the verification step is probably best left where it’s at.
Well, I connected the screen to the motherboard without peeling off the plastic.
It is possible!
And after testing the phone I took off the plastic foil from the adhesive without unpluging the two connectors. The plasic foil herefor has two cuts in the area of the connectors .
So I think it’s a good idea to swap step 35 to step 36.
Before sealing the display in place, connect the flex cables for the display and fingerprint sensor, and then power your phone on.
Test all functions to make sure your repair was successful before sealing up the display.
54 other people completed this guide.
13 Comments
I am also confused about the Double Sided Tape. My kit seems to have come with everything I need except for this double sided tape!
i with that i had seen this before i let some third party company ruin my otherwise perfectly good phone
Followed exactly as written and successfully replaced screen on my water damaged Moto Z Play. Be sure to test everything before sealing the screen to adhesive. I didn’t test the camera prior to sealing the screen and don’t feel like opening it back up! Purchased the $99 kit with screen and tools. Unfortunately, the iOpener didn’t last second time in the microwave and leaked even after waiting 10 minutes per directions.
Screen successfully replaced. I managed to crack the plastic backing plate of the front-facing LED, but that doesn’t matter. The last bit about the heavy stack of books was rather silly in my opinion. I heated the screen with a hairdryer and pressed the phone screen down on a soft mouse mat. I don’t a have microwave, so I couldn’t use the provided iOpener at all.
Install went well. I was sweating bullets since this was my first time doing a smartphone repair, but this guide was very thorough. Take your time and be careful since this is very precise work. I also took probably about an extra 30-60 minutes carefully cleaning the dust and hair that had collected just barely under the edges of the screen after several years of use. I really recommend it since how often do you plan on opening up your phone like this?
The entire surface of my screen was completely shattered (100%) and removing all the little peices of it was difficult. I bought the complete kit and followed these instructions. I managed to pry the screen peice by peice, without heat or the suction cup tool. Very tedious work (unless you’re use to working with such small, delicate instrumentation), so take a break if you’re feeling frustrated. I would highly recommend using some type of hands free magnification throughout the process. My phone works perfectly now- complete success! Thank you IFIXIT.
This worked perfectly for me. Thank You!!!!
Excellent step by step. I was nervous at first, but I managed it! This is my first cell phone screen repair. I can hardly wait until something else breaks!
~Kristi
Excellent explanation. My son and I bought the spare screen (pre-assembled with touch screen) of his old and crashed Moto Z2Play from another website, but my IFixit Pro-Tech Toolkit made the difference!!
Thank you!
And keep on Fixing It!!
Warum ist es so wichtig das Handy beim Displaytausch auszuschalten?
I also cracked the plastic backing plate of the front-facing LED. My advice is to use a knife to separate the flash flex cable, and carefully cut through the adhesive securing it in place BEFORE you try to push the LED out of its mounting hole from the front. If you push the LED out first, it will crack the plastic backing plate underneath the flex cable. It still works OK when you glue it back to the new screen. Other than that, repair was a complete success.
