Motorola Moto G Stylus 5G (2022) Main Camera Replacement
  1. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Eject the SIM card tray: step 1, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Eject the SIM card tray: step 1, image 2 of 2
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the SIM card tray: step 2, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the SIM card tray: step 2, image 2 of 2
    • Grab and remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Heat the edge: step 3, image 1 of 1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the edge of the back cover with the SIM card slot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Insert an opening pick: step 4, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Insert an opening pick: step 4, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Insert an opening pick: step 4, image 3 of 3
    • Apply a suction cup to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  5. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the right adhesive: step 5, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the right adhesive: step 5, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the right adhesive: step 5, image 3 of 3
    • Slide your opening pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick in at the bottom right corner to prevent the adhesive from resealing.
  6. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the bottom adhesive: step 6, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the bottom adhesive: step 6, image 2 of 2
    • Insert a second opening pick into the bottom right corner.
    • Slide this opening pick along the bottom edge to the bottom left corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
  7. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the left adhesive: step 7, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the left adhesive: step 7, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the left adhesive: step 7, image 3 of 3
    • Insert a third opening pick into the bottom right corner.
    • Slide this opening pick along the left edge to slice the adhesive.
    • Don't worry about slicing under the camera bezel. It's separate from the back cover and will be removed later.
    • Leave the pick inserted in the top left corner to prevent the left edge from resealing.
  8. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the top adhesive: step 8, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the top adhesive: step 8, image 2 of 2
    • Insert a fourth pick into the top left corner.
    • Slide the pick to the top right corner to slice the top adhesive.
  9. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice around the camera bezel: step 9, image 1 of 1
    • Slide an opening pick between the camera bezel and the back cover.
    • The back cover's adhesive is particularly strong around the camera bezel.
    • Slide the opening pick around the camera bezel to separate the back cover from the frame.
  10. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the back cover: step 10, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the back cover: step 10, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the back cover: step 10, image 3 of 3
    • Grab and remove the back cover by lifting it away from the phone.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  11. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Heat the camera bezel: step 11, image 1 of 1
    • Heat an iOpener and apply it to the camera bezel for two minutes.
  12. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the adhesive: step 12, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the adhesive: step 12, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Slice the adhesive: step 12, image 3 of 3
    • Insert an opening pick under the camera bezel.
    • Slide the pick around the perimeter of the bezel to slice the adhesive.
    • If it feels stuck, apply more heat to further loosen the adhesive.
  13. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the camera bezel: step 13, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the camera bezel: step 13, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the camera bezel: step 13, image 3 of 3
    • Grab and remove the camera bezel.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the camera bezel with custom-cut adhesives, follow this guide.
    • To adhere the camera bezel with tape, follow this guide.
  14. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Unfasten the motherboard cover: step 14, image 1 of 1
    • Use a Phillips screwdriver to remove the eleven 4.1 mm-long screws securing the motherboard cover.
    • If you can't find all the screws, check under any leftover adhesive residue.
  15. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Unclip the right edge: step 15, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Unclip the right edge: step 15, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Unclip the right edge: step 15, image 3 of 3
    • Insert a spudger between the bottom right corner of the cover and the frame.
    • Pry up to release the clips securing the cover.
    • Slide the spudger toward the top of the cover and pry to release the right edge.
  16. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the motherboard cover: step 16, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the motherboard cover: step 16, image 2 of 2
    • Grip the right edge of the cover and pull it off the motherboard.
  17. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the battery: step 17, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the battery: step 17, image 2 of 2
    • Use the point of a spudger to pry up the battery's press connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the display: step 18, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the display: step 18, image 2 of 2
    • Use the pointed end of your spudger to pry and disconnect the display's press connector.
  19. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the antenna cable: step 19, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the antenna cable: step 19, image 2 of 2
    • Use the pointed end of your spudger to pry and disconnect the white antenna cable.
    • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  20. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the board connector: step 20, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the board connector: step 20, image 2 of 2
    • Use the pointed end of a spudger to pry up and disconnect the board cable's press connector.
  21. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the upper 5G mmWave antenna: step 21, image 1 of 2 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Disconnect the upper 5G mmWave antenna: step 21, image 2 of 2
    • Use the pointed end of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  22. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Unfasten the motherboard: step 22, image 1 of 1
    • Use your Phillips screwdriver to remove the 3 mm-long screw securing the motherboard.
  23. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Reposition the graphite film: step 23, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Reposition the graphite film: step 23, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Reposition the graphite film: step 23, image 3 of 3
    • Lift and fold the graphite film off the battery and flip it onto the motherboard.
    • Use caution not to tear the film. It's adhered lightly to the battery.
  24. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the motherboard: step 24, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the motherboard: step 24, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Remove the motherboard: step 24, image 3 of 3
    • Grab the motherboard from the bottom edge and lift it from its recess.
    • Be sure the loose cables don't catch on the motherboard as it's removed.
    • During reassembly, make sure no cables or connectors become trapped underneath the motherboard.
  25. Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Main Camera: step 25, image 1 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Main Camera: step 25, image 2 of 3 Motorola Moto G Stylus 5G (2022) Main Camera Replacement, Main Camera: step 25, image 3 of 3
    • Flip the motherboard over so the rear cameras are faced down.
    • Use the point of a spudger to pry and disconnect the main camera's press connector.
    • The camera may eject from the motherboard. Work slowly to avoid losing it.
    • Use a pair of tweezers or your fingers to grab and remove the camera.
Clay Eickemeyer
53,225 Reputation
394 Guides authored
iFixit Member of iFixit
Staff
141 Members
16,255 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 36
All Time: 363
