Microsoft Surface Pro 7+ Screen Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
9
Past 7 Days:
68
Past 30 Days:
294
All Time:
1,116
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace a broken, cracked, or non-responsive screen on your Microsoft Surface Pro 7+ tablet.
You'll need replacement screen adhesive to complete this repair.
Parts
Tools
    1. Microsoft Surface Pro 7+ Screen Replacement, Before you begin: step 1, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Before you begin: step 1, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Before you begin: step 1, image 3 of 3
      • Before starting this repair, allow your Surface Pro's battery to drain below 25%. A charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your tablet.
      • If you have a keyboard attached, remove it.
      Ask FixBot
    1. Microsoft Surface Pro 7+ Screen Replacement, Open the kickstand: step 2, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement, Open the kickstand: step 2, image 2 of 2
      • Open the kickstand to about 90 degrees.
      Ask FixBot
    1. Microsoft Surface Pro 7+ Screen Replacement, Remove the SSD door: step 3, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the SSD door: step 3, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the SSD door: step 3, image 3 of 3
      • Firmly press a SIM eject tool into the small hole in the corner of the SSD door until it pops up.
      • Alternatively, you can also use a small, straightened paper clip.
      • Remove the SSD door.
      Ask FixBot
    1. Microsoft Surface Pro 7+ Screen Replacement, Remove the SSD screw: step 4, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement, Remove the SSD screw: step 4, image 2 of 2
      • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
      • Use a Torx Plus 3IP screwdriver to remove the 2.2 mm‑long screw securing the SSD.
      Ask FixBot
    2. Microsoft Surface Pro 7+ Screen Replacement, Remove the SSD: step 5, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement, Remove the SSD: step 5, image 2 of 2
      • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
      • Use your fingers to pull the SSD out of its socket at a shallow angle.
      Ask FixBot
    1. Microsoft Surface Pro 7+ Screen Replacement, Reinstall the SSD door: step 6, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement, Reinstall the SSD door: step 6, image 2 of 2
      • Leave the SSD removed to keep the battery disconnected.
      • Slide the SSD door back into its recess and press down on the bottom edge until it clicks into place.
      Ask FixBot
    2. Microsoft Surface Pro 7+ Screen Replacement, Close the kickstand: step 7, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Close the kickstand: step 7, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Close the kickstand: step 7, image 3 of 3
      • Close the kickstand and flip your device over so the screen is facing up.
      Ask FixBot
    3. Microsoft Surface Pro 7+ Screen Replacement, Heat the right edge: step 8, image 1 of 1
      • Heating the screen helps soften the adhesive securing it, making it easier to open.
      • Heat an iOpener and lay it on the right edge of the screen for two minutes to soften the adhesive.
      • Alternatively, you can use a hair dryer or heat gun to soften the adhesive. For a more detailed look at best practices for using a hair dryer, check out this guide. For information on heat gun use, check out this guide.
      Ask FixBot
    4. Microsoft Surface Pro 7+ Screen Replacement, Adhesive information: step 9, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Adhesive information: step 9, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Adhesive information: step 9, image 3 of 3
      • Don't insert your pick more than 8 mm when separating the screen adhesive. Otherwise, you may damage your device's internals.
      • When separating the top edge adhesive, follow instructions carefully to avoid damaging the front camera.
      • To prevent inserting your pick too far, measure 8 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, tape a coin to a pick 8 mm from the tip.
      • If you're having trouble separating the adhesive, use the third photo as a reference for the adhesive location.
      Ask FixBot
    5. Microsoft Surface Pro 7+ Screen Replacement, Insert an opening pick: step 10, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Insert an opening pick: step 10, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Insert an opening pick: step 10, image 3 of 3
      • Insert the tip of an opening pick under the screen near the bottom of the right speaker cutout.
      • Be careful not to damage the speaker mesh, or you'll need to replace it.
      • Slide your pick towards the bottom edge so the tip goes under the notch in the screen.
      Ask FixBot
    6. Microsoft Surface Pro 7+ Screen Replacement, Separate the right edge adhesive: step 11, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Separate the right edge adhesive: step 11, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Separate the right edge adhesive: step 11, image 3 of 3
      • Remember not to insert your pick more than 8 mm.
      • Slide the pick down the right edge to separate the adhesive securing it.
      • Leave the pick inserted under the bottom right corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    7. Microsoft Surface Pro 7+ Screen Replacement, Heat the bottom edge: step 12, image 1 of 1
      • Heat the bottom edge of the screen with an iOpener, hair dryer, or heat gun.
      Ask FixBot
    8. Microsoft Surface Pro 7+ Screen Replacement, Separate the bottom edge adhesive: step 13, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Separate the bottom edge adhesive: step 13, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Separate the bottom edge adhesive: step 13, image 3 of 3
      • Insert a second pick under the bottom right corner of the screen and slide it along the bottom edge to separate the adhesive.
      • Leave the second pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    9. Microsoft Surface Pro 7+ Screen Replacement, Heat the left edge: step 14, image 1 of 1
      • Heat the left edge of the screen with an iOpener, hair dryer, or heat gun.
      Ask FixBot
    10. Microsoft Surface Pro 7+ Screen Replacement, Separate the left edge adhesive: step 15, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement, Separate the left edge adhesive: step 15, image 2 of 2
      • Insert a third pick under the bottom left corner of the screen and slide it up the left edge, stopping when you get to the bottom of the left speaker cutout.
      • Leave the pick inserted under the screen to prevent the adhesive from re-sealing.
      Ask FixBot
    11. Microsoft Surface Pro 7+ Screen Replacement, Heat the top edge: step 16, image 1 of 1
      • Heat the top edge of the screen with an iOpener, hair dryer, or heat gun.
      Ask FixBot
    12. Microsoft Surface Pro 7+ Screen Replacement, Insert an opening pick: step 17, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Insert an opening pick: step 17, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Insert an opening pick: step 17, image 3 of 3
      • Insert a fourth pick under the screen near the top of the left speaker cutout.
      • Slide your pick towards the top edge so the tip goes under the notch in the screen.
      Ask FixBot
    13. Microsoft Surface Pro 7+ Screen Replacement, Separate the top edge adhesive: step 18, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Separate the top edge adhesive: step 18, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Separate the top edge adhesive: step 18, image 3 of 3
      • Don't slide the pick over the front facing camera. Remove the pick enough that it can slide past the camera without touching it.
      • Slide the pick along the top edge to separate the adhesive.
      • You'll likely need to slide the pick around the perimeter a second time to fully separate all the screen adhesive.
      Ask FixBot
    14. Microsoft Surface Pro 7+ Screen Replacement, Flip the screen over: step 19, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Flip the screen over: step 19, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Flip the screen over: step 19, image 3 of 3
      • Once the screen is fully separated, slightly lift the top edge and flip the screen so it can lay flat.
      • Be careful not to strain the screen cables.
      Ask FixBot
    15. Microsoft Surface Pro 7+ Screen Replacement, Remove the screen cable cover: step 20, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the screen cable cover: step 20, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the screen cable cover: step 20, image 3 of 3
      • Use the flat end of a spudger to gently lift the edges of the metal screen cable cover to unclip it.
      • Be careful not to deform the cover too much, as you'll need to reinstall it during reassembly.
      • Remove the cable cover.
      Ask FixBot
    16. Microsoft Surface Pro 7+ Screen Replacement, Disconnect the screen cables: step 21, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement, Disconnect the screen cables: step 21, image 2 of 2
      • Use a spudger to pry up and disconnect the smaller screen cable press connector.
      Ask FixBot
    17. Microsoft Surface Pro 7+ Screen Replacement: step 22, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 22, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 22, image 3 of 3
      • Use a spudger to pry up and disconnect the wide screen cable press connector, starting on one of the short sides and moving to the other.
      Ask FixBot
    18. Microsoft Surface Pro 7+ Screen Replacement, Remove the screen: step 23, image 1 of 1
      • Remove the screen.
      Ask FixBot
    1. Microsoft Surface Pro 7+ Screen Replacement, Transfer screen parts: step 24, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Transfer screen parts: step 24, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Transfer screen parts: step 24, image 3 of 3
      • Compare your replacement screen to the original. You may need to transfer the following parts:
      • The skinny board located near the bottom right of the screen.
      • Two S shaped screen cables attached to the original screen.
      • If your replacement screen comes with these parts installed, you can skip down to the adhesive removal step.
      Ask FixBot
    2. Microsoft Surface Pro 7+ Screen Replacement, Remove the screen cable cover: step 25, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the screen cable cover: step 25, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the screen cable cover: step 25, image 3 of 3
      • Use the point of a spudger to pry up and unclip the screen cable's metal cover.
      • Remove the cover.
      Ask FixBot
    3. Microsoft Surface Pro 7+ Screen Replacement, Disconnect the screen cable: step 26, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Disconnect the screen cable: step 26, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Disconnect the screen cable: step 26, image 3 of 3
      • Use a spudger to pry up and disconnect the screen cable press connector, starting on one of the short sides and moving to the other.
      Ask FixBot
    4. Microsoft Surface Pro 7+ Screen Replacement: step 27, image 1 of 1
      • Remove the cable and set it aside—you'll install it on your new screen later.
      Ask FixBot
    5. Microsoft Surface Pro 7+ Screen Replacement, Remove the board cover: step 28, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the board cover: step 28, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the board cover: step 28, image 3 of 3
      • Use the point of a spudger to pry up and unclip the edges of the metal cover on the board (near the bottom right of the screen).
      • Remove the cover.
      Ask FixBot
    6. Microsoft Surface Pro 7+ Screen Replacement, Disconnect the board: step 29, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Disconnect the board: step 29, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Disconnect the board: step 29, image 3 of 3
      • Use the flat end of a spudger to lift the hinged, locking flaps on the board's two ZIF connectors.
      Ask FixBot
    7. Microsoft Surface Pro 7+ Screen Replacement: step 30, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 30, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 30, image 3 of 3
      • Use the point of a spudger to slide both cables completely out of their sockets.
      • You can leave the ribbon cable connected to the top edge of the board, since you're going to be transferring it.
      Ask FixBot
    8. Microsoft Surface Pro 7+ Screen Replacement, Remove the board: step 31, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the board: step 31, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the board: step 31, image 3 of 3
      • Mild adhesive secures the board to the screen.
      • Slide the flat end of a spudger under the board and lift to remove it.
      Ask FixBot
    1. Microsoft Surface Pro 7+ Screen Replacement, Disassembly complete: step 32, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Surface Pro.
      Ask FixBot
    1. Microsoft Surface Pro 7+ Screen Replacement, Install the screen board: step 33, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Install the screen board: step 33, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Install the screen board: step 33, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Before installing the screen board, make sure you know how it will be oriented. The cables need to line up with their sockets.
      • Gently press the board into place on the replacement screen.
      • The residual adhesive should be sticky enough to reuse. If the board isn't staying in place, use thin double-sided tape to secure it.
      Ask FixBot
    2. Microsoft Surface Pro 7+ Screen Replacement, Connect the board cables: step 34, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Connect the board cables: step 34, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Connect the board cables: step 34, image 3 of 3
      • Use your finger to slide one of the screen board cables fully into its socket.
      • If the cable isn't sliding in, make sure the locking flap is flipped up.
      • Hold the cable in place, and flip the locking flap down to secure the cable.
      Ask FixBot
    3. Microsoft Surface Pro 7+ Screen Replacement: step 35, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 35, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 35, image 3 of 3
      • Repeat the process to reconnect the other cable to the screen board.
      Ask FixBot
    4. Microsoft Surface Pro 7+ Screen Replacement: step 36, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 36, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 36, image 3 of 3
      • Set the board's metal cover in place and press down around the perimeter to secure it.
      Ask FixBot
    5. Microsoft Surface Pro 7+ Screen Replacement, Reconnect the cable: step 37, image 1 of 1
      • Lay the screen cable in place so the bend lines up with the other screen cable.
      • If the cable is positioned the wrong way, you won't be able to reconnect the screen.
      Ask FixBot
    6. Microsoft Surface Pro 7+ Screen Replacement: step 38, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 38, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 38, image 3 of 3
      • Use your finger to press down and reconnect the screen cable press connector, starting on one side and moving to the other.
      Ask FixBot
    7. Microsoft Surface Pro 7+ Screen Replacement, Install the cable cover: step 39, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement, Install the cable cover: step 39, image 2 of 2
      • Set the cable's metal cover in place and press down around the perimeter to secure it.
      Ask FixBot
    1. Microsoft Surface Pro 7+ Screen Replacement, Remove the old screen adhesive: step 40, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the old screen adhesive: step 40, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the old screen adhesive: step 40, image 3 of 3
      • Use a spudger and your fingers (or tweezers) to scrape up and remove all the old screen adhesive from the perimeter of the frame.
      • If you're reusing your screen, repeat the process to remove any of the old screen adhesive from it.
      • To prevent damaging your screen, press gently with the spudger and make sure nothing is under the screen while you work.
      Ask FixBot
    2. Microsoft Surface Pro 7+ Screen Replacement: step 41, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 41, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 41, image 3 of 3
      • Take your time and be very thorough during the next two steps. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      • The old adhesive likely left behind a thin, clear film on the frame. Use a spudger and tweezers to peel any traces of the film from the frame.
      • If you're reusing your screen, repeat the process to remove any of the adhesive film left on the screen.
      Ask FixBot
    3. Microsoft Surface Pro 7+ Screen Replacement, Clean the frame: step 42, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement, Clean the frame: step 42, image 2 of 2
      • Use a lint‑free cloth (or coffee filter) and some high‑concentration (>90%) isopropyl alcohol to thoroughly clean the frame where you removed the old screen adhesive.
      • If you're reusing the screen, repeat the process to clean its perimeter.
      Ask FixBot
    4. Microsoft Surface Pro 7+ Screen Replacement, Adhesive strips information: step 43, image 1 of 1
      • Before applying any screen adhesives, find their proper orientation on the frame. Use cutouts and notches in the adhesive to match each strip to its spot on the perimeter.
      • The top strip has lots of circular cutouts for the cameras and sensors.
      Ask FixBot
    5. Microsoft Surface Pro 7+ Screen Replacement, Apply the short edge adhesive strips: step 44, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Apply the short edge adhesive strips: step 44, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Apply the short edge adhesive strips: step 44, image 3 of 3
      • Take your time when applying the adhesive strips. Once the adhesive sticks to the frame, it can't be repositioned—you'll need to start over with a new strip.
      • Apply the shorter strips (left and right) first, as it makes it much easier to properly align the top and bottom ones.
      • Remove the white, paperlike liner (not the clear one) from one of the shorter strips.
      • Line up the strip and use your finger to secure one end to the frame.
      • With one end secured, gently lay the strip onto the frame and use your finger to lightly press down as you go.
      • Don't remove the remaining clear liner on top of the strip yet.
      Ask FixBot
    6. Microsoft Surface Pro 7+ Screen Replacement: step 45, image 1 of 1
      • Use the same process to apply the other short strip.
      Ask FixBot
    7. Microsoft Surface Pro 7+ Screen Replacement, Apply the long edge adhesive strips: step 46, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Apply the long edge adhesive strips: step 46, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Apply the long edge adhesive strips: step 46, image 3 of 3
      • To apply the top strip, align the middle cutouts over the front camera and lay the strip down starting in the center and working out to both sides.
      • Use the same process to apply the bottom strip.
      Ask FixBot
    8. Microsoft Surface Pro 7+ Screen Replacement: step 47, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 47, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 47, image 3 of 3
      • Press down on the strips with the flat end of a spudger and slide it along the length of the strips to secure them to the frame.
      • To secure the strips further, you can press down firmly with your finger.
      Ask FixBot
    9. Microsoft Surface Pro 7+ Screen Replacement: step 48, image 1 of 1
      • Lay the screen display-side-down on the device so you can reconnect the two cables.
      • The screen should be oriented so when you flip it over, the top edge of the screen is lined up with the top edge of the frame.
      Ask FixBot
    10. Microsoft Surface Pro 7+ Screen Replacement, Connect the screen: step 49, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Connect the screen: step 49, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Connect the screen: step 49, image 3 of 3
      • Use your finger to press down and reconnect both of the screen cable press connectors.
      • For the larger connector, press first on one short side, then the other, until it clicks into place.
      Ask FixBot
    11. Microsoft Surface Pro 7+ Screen Replacement: step 50, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 50, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 50, image 3 of 3
      • Lay the screen cable cover into place and press down firmly around the entire perimeter to secure it.
      Ask FixBot
    12. Microsoft Surface Pro 7+ Screen Replacement, Remove the adhesive liners: step 51, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the adhesive liners: step 51, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Remove the adhesive liners: step 51, image 3 of 3
      • Remove all the remaining adhesive liners, carefully holding the screen above your device as necessary.
      Ask FixBot
    13. Microsoft Surface Pro 7+ Screen Replacement, Install the screen: step 52, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Install the screen: step 52, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Install the screen: step 52, image 3 of 3
      • Flip the screen over and align the bottom edge, using the frame's lip to properly orient it.
      Ask FixBot
    14. Microsoft Surface Pro 7+ Screen Replacement: step 53, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement: step 53, image 2 of 2
      • Once the bottom edge is properly aligned, lay the screen onto the frame.
      Ask FixBot
    15. Microsoft Surface Pro 7+ Screen Replacement: step 54, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 54, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 54, image 3 of 3
      • Use your fingers to press down on the entire perimeter of the screen to secure it in the frame.
      • Check the edges of the screen and make sure they're sitting flush in the frame—there should be no gaps.
      Ask FixBot
    16. Microsoft Surface Pro 7+ Screen Replacement: step 55, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement: step 55, image 2 of 2
      Surface Display Bonding Frame (M1178723-001)
      $29.99
      Buy
      • Lay your Surface Pro screen down on a clean, flat surface.
      • If you're using a display bonding frame, lay the device down with the screen facing up.
      • Place 4–5 heavy books squarely on top of your device.
      • Leave the books in place for at least thirty minutes. The lighter the books, the longer they should be left. Ideally, leave them stacked overnight.
      • The pressure will help activate the adhesive, creating a stronger bond.
      Ask FixBot
    17. Microsoft Surface Pro 7+ Screen Replacement, Reinstall the SSD: step 56, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement, Reinstall the SSD: step 56, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement, Reinstall the SSD: step 56, image 3 of 3
      • Open the kickstand and remove the SSD door using a SIM eject tool.
      • Use your fingers to slide the SSD fully into its socket.
      Ask FixBot
    18. Microsoft Surface Pro 7+ Screen Replacement: step 57, image 1 of 2 Microsoft Surface Pro 7+ Screen Replacement: step 57, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the 2.2 mm‑long SSD screw.
      Ask FixBot
    19. Microsoft Surface Pro 7+ Screen Replacement: step 58, image 1 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 58, image 2 of 3 Microsoft Surface Pro 7+ Screen Replacement: step 58, image 3 of 3
      • Slide the SSD door into place and use your finger to press down on the bottom edge until it clicks into place.
      Ask FixBot
Spencer Day
207,305 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 68
Past 30 Days: 294
All Time: 1,116
