Shop the Holiday Gift Guide
MacBook Neo Screen Replacement
Views: 7.9K
View statistics:
Past 24 Hours:
27
Past 7 Days:
170
Past 30 Days:
1,113
All Time:
7,876
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace a broken screen on a MacBook Neo. The screen also includes the integrated cables for the display and camera.
For your safety, discharge the battery below 25% before disassembly. This reduces the risk of a dangerous fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Parts
Tools
    1. MacBook Neo Screen Replacement, Prepare the MacBook for disassembly: step 1, image 1 of 3 MacBook Neo Screen Replacement, Prepare the MacBook for disassembly: step 1, image 2 of 3 MacBook Neo Screen Replacement, Prepare the MacBook for disassembly: step 1, image 3 of 3
      • Fully shut down the MacBook and close the lid. Keep the lid closed until you've physically disconnected the battery.
      • Disconnect any cables and accessories.
      • Flip the computer upside‑down on a clean work surface.
      Ask FixBot
    1. MacBook Neo Screen Replacement, Remove the bottom cover screws: step 2, image 1 of 1
      • Use a P5 pentalobe driver to remove the eight screws securing the bottom cover:
      • Six 4.1 mm‑long screws
      • Two 4.5 mm‑long screws
      • During reassembly, partially install the screws to ensure alignment, then tighten the screws at each corner (like top‑right, bottom‑left, etc.) before the rest.
      Ask FixBot
    2. MacBook Neo Screen Replacement, Pry up the bottom cover: step 3, image 1 of 3 MacBook Neo Screen Replacement, Pry up the bottom cover: step 3, image 2 of 3 MacBook Neo Screen Replacement, Pry up the bottom cover: step 3, image 3 of 3
      • The bottom cover is held in place with two clips, one on each side.
      • Use your fingers to lift the top right corner of the bottom cover, near the USB‑C ports, until the clip along the right edge releases.
      • If you're having trouble, use the flat end of a spudger to pry up the corner until you can grab it with your fingers. You can also slide an opening pick down each edge to release the clips.
      • Repeat this process on the left side to release its clip.
      Ask FixBot
    3. MacBook Neo Screen Replacement, Remove the bottom cover: step 4, image 1 of 2 MacBook Neo Screen Replacement, Remove the bottom cover: step 4, image 2 of 2
      • Remove the bottom cover.
      • During reassembly, align the bottom cover with its screw holes, then press on the two short sides until the clip on each side snaps into place.
      Ask FixBot
    1. MacBook Neo Screen Replacement, Remove the battery connector cover: step 5, image 1 of 1
      • Use a Torx Plus 3IP driver to remove the two 1.7 mm‑long screws securing the battery connector cover.
      • While the MacBook Neo uses Torx Plus screws, standard Torx bits also work (T3 in place of 3IP, for example). Apply constant, downward force to prevent stripping the screw.
      Ask FixBot
    2. MacBook Neo Screen Replacement: step 6, image 1 of 2 MacBook Neo Screen Replacement: step 6, image 2 of 2
      • Use tweezers or your fingers to remove the battery connector cover.
      Ask FixBot
    3. MacBook Neo Screen Replacement, Disconnect the battery: step 7, image 1 of 2 MacBook Neo Screen Replacement, Disconnect the battery: step 7, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the battery press connector.
      • To reconnect, align the connector carefully over its socket and press down—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    1. MacBook Neo Screen Replacement, Remove the antenna connector cover: step 8, image 1 of 1
      • Use a Torx Plus 3IP driver to remove the 1.7 mm‑long screw securing the antenna connector cover.
      Ask FixBot
    2. MacBook Neo Screen Replacement: step 9, image 1 of 2 MacBook Neo Screen Replacement: step 9, image 2 of 2
      • Use tweezers or your fingers to remove the antenna connector cover.
      Ask FixBot
    3. MacBook Neo Screen Replacement, Disconnect the antenna: step 10, image 1 of 3 MacBook Neo Screen Replacement, Disconnect the antenna: step 10, image 2 of 3 MacBook Neo Screen Replacement, Disconnect the antenna: step 10, image 3 of 3
      • Insert one arm of angled tweezers under the metal neck of one of the antenna coaxial connectors and lift straight up to disconnect it.
      • Repeat the process to disconnect the second antenna cable.
      • To reconnect, use tweezers to hold each connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
      Ask FixBot
    4. MacBook Neo Screen Replacement, Remove the antenna: step 11, image 1 of 1
      • Use a Torx Plus 5IP driver to remove the four 2.9 mm‑long screws securing the antenna.
      Ask FixBot
    5. MacBook Neo Screen Replacement: step 12, image 1 of 2 MacBook Neo Screen Replacement: step 12, image 2 of 2
      • Pick up the antenna by its edges and remove it.
      Ask FixBot
    1. MacBook Neo Screen Replacement, Disconnect the display cable: step 13, image 1 of 2 MacBook Neo Screen Replacement, Disconnect the display cable: step 13, image 2 of 2
      • Use the flat end of a spudger to gently push under the metal buckle of the display cable connector, located on the top‑right corner of the logic board, to unclip it.
      Ask FixBot
    2. MacBook Neo Screen Replacement: step 14, image 1 of 2 MacBook Neo Screen Replacement: step 14, image 2 of 2
      • Grab the buckle and cable together and gently pull the connector straight out of its socket.
      Ask FixBot
    3. MacBook Neo Screen Replacement, Disconnect the camera cable: step 15, image 1 of 3 MacBook Neo Screen Replacement, Disconnect the camera cable: step 15, image 2 of 3 MacBook Neo Screen Replacement, Disconnect the camera cable: step 15, image 3 of 3
      • Repeat this procedure to disconnect the camera cable, located on the left edge of the logic board.
      • To reconnect:
      • Grip the buckle and insert the connector fully into its socket. Realign it as necessary and don't try to force it in.
      • Flip the buckle over the socket and press it down until it clicks into place.
      Ask FixBot
    4. MacBook Neo Screen Replacement, Free the camera cable: step 16, image 1 of 3 MacBook Neo Screen Replacement, Free the camera cable: step 16, image 2 of 3 MacBook Neo Screen Replacement, Free the camera cable: step 16, image 3 of 3
      • Pick up the buckle and cable together and gently pull the camera cable out of its channel securing it to the frame.
      • Free the cable so it's not wrapped around the corner of the laptop frame.
      Ask FixBot
    5. MacBook Neo Screen Replacement, Free the display cable: step 17, image 1 of 2 MacBook Neo Screen Replacement, Free the display cable: step 17, image 2 of 2
      • Hold the display cable's buckle and cable together and free it from the laptop frame.
      Ask FixBot
    6. MacBook Neo Screen Replacement, Loosen the hinge screws: step 18, image 1 of 2 MacBook Neo Screen Replacement, Loosen the hinge screws: step 18, image 2 of 2
      • Use a Torx Plus 8IP driver to loosen (not remove) all four hinge screws.
      Ask FixBot
    7. MacBook Neo Screen Replacement, Reassembly information: step 19, image 1 of 3 MacBook Neo Screen Replacement, Reassembly information: step 19, image 2 of 3 MacBook Neo Screen Replacement, Reassembly information: step 19, image 3 of 3
      • During reassembly:
      • Loosen the hinge screws at least one full turn.
      • Adjust the screen until it's correctly centered and aligned on each side. The screen should sit flush with the rest of the laptop.
      • You can stand the laptop up on one side to help align the screen. Support it with one hand while tightening the screws with the other.
      • Fully tighten the four hinge screws.
      • If the screen clicks or snaps upon opening, loosen the hinge screws and adjust the alignment. Make sure the screen doesn't sit too far forward, or it can catch on the body when opening and closing.
      • If desired, add a little blue threadlocker to the screw threads to prevent them from loosening over time.
      Ask FixBot
    8. MacBook Neo Screen Replacement, Open the laptop: step 20, image 1 of 2 MacBook Neo Screen Replacement, Open the laptop: step 20, image 2 of 2
      • Open the laptop all the way and gently place it keyboard side down on a table, so the screen hangs over the edge.
      • You can place a soft cloth under the keyboard to protect it.
      Ask FixBot
    9. MacBook Neo Screen Replacement, Remove the hinge screws: step 21, image 1 of 3 MacBook Neo Screen Replacement, Remove the hinge screws: step 21, image 2 of 3 MacBook Neo Screen Replacement, Remove the hinge screws: step 21, image 3 of 3
      • Keep a firm grip on the laptop, as it can easily fall off the table.
      • Support the screen with one hand.
      • With your free hand, use a Torx Plus 8IP driver to remove the four 6.2 mm–long screws securing the hinges.
      Ask FixBot
    10. MacBook Neo Screen Replacement, Remove the screen: step 22, image 1 of 3 MacBook Neo Screen Replacement, Remove the screen: step 22, image 2 of 3 MacBook Neo Screen Replacement, Remove the screen: step 22, image 3 of 3
      • Hold the screen with both hands and lift the hinges out of their recesses to remove it.
      • During reassembly, be careful not to scratch the new screen on the edge of the laptop frame. If the screen itself has any plastic liners, leave them in place until reassembly is complete.
      Ask FixBot
Compare the new replacement part to the original part—you may need to remove plastic liners from the new part before you install it.
To reassemble the MacBook, follow these instructions in reverse order.
3 other people completed this guide.
Nick Schultz
70,424 Reputation
363 Guides authored
1 Guide Comment
Bonjour à tous, j'aimerais savoir si la dalle LCD seule est "facilement" dissociable du bloc écran complet où si c'est collé à mort comme sur les Air M1 par exemple ?
EJR soirée du 31 - Reply Share
Past 24 Hours: 27
Past 7 Days: 170
Past 30 Days: 1,113
All Time: 7,876
