Logitech Zone 305 Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
78
All Time:
425
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 45 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace a worn-out or dead battery in your Logitech Zone 305 headset. The li-ion battery resides within the right ear cup.
It’s natural for batteries to lose capacity as they age. If your headset dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Logitech Zone 305 Battery Replacement, Prepare the headset for disassembly: step 1, image 1 of 1
      • Power off the headset and unplug all cables.
      Ask FixBot
    2. Logitech Zone 305 Battery Replacement, Remove the ear pad: step 2, image 1 of 3 Logitech Zone 305 Battery Replacement, Remove the ear pad: step 2, image 2 of 3 Logitech Zone 305 Battery Replacement, Remove the ear pad: step 2, image 3 of 3
      • If you're replacing the headset battery, you only need to remove the right ear pad.
      • With one hand, firmly hold the ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Remove the ear pad from the ear cup.
      Ask FixBot
    1. Logitech Zone 305 Battery Replacement, Separate the speaker plate: step 3, image 1 of 3 Logitech Zone 305 Battery Replacement, Separate the speaker plate: step 3, image 2 of 3 Logitech Zone 305 Battery Replacement, Separate the speaker plate: step 3, image 3 of 3
      • Insert the point of an opening pick into the seam between the speaker plate and ear cup.
      • Slide the pick along the seam to release the four speaker plate clips.
      Ask FixBot
    2. Logitech Zone 305 Battery Replacement: step 4, image 1 of 3 Logitech Zone 305 Battery Replacement: step 4, image 2 of 3 Logitech Zone 305 Battery Replacement: step 4, image 3 of 3
      • Don't try to fully remove the speaker plate, as a wire connects it to the ear cup.
      • Use your fingers to move the speaker plate towards the right side of the ear cup so you can access the screw.
      Ask FixBot
    3. Logitech Zone 305 Battery Replacement, Separate the speaker housing: step 5, image 1 of 1
      • Use a Phillips screwdriver to remove the 7.1 mm‑long pancake screw securing the speaker housing.
      Ask FixBot
    4. Logitech Zone 305 Battery Replacement: step 6, image 1 of 1
      • This step reattaches the speaker plate temporarily to keep it from wobbling during repairs.
      • Align the speaker plate to the speaker housing and squeeze firmly to engage two of the four clips.
      Ask FixBot
    5. Logitech Zone 305 Battery Replacement: step 7, image 1 of 2 Logitech Zone 305 Battery Replacement: step 7, image 2 of 2
      • Use your fingers to grab the speaker housing from the back.
      • Pull firmly to pop the housing off from its ball joint.
      • Be careful not to pull too far—a speaker wire still connects the housing and the ear cup.
      Ask FixBot
    6. Logitech Zone 305 Battery Replacement, Remove the midplate screws: step 8, image 1 of 1
      • Use a Phillips screwdriver to remove the three 5.3 mm‑long screws securing the midplate.
      Ask FixBot
    7. Logitech Zone 305 Battery Replacement, Reposition the midplate: step 9, image 1 of 3 Logitech Zone 305 Battery Replacement, Reposition the midplate: step 9, image 2 of 3 Logitech Zone 305 Battery Replacement, Reposition the midplate: step 9, image 3 of 3
      • Be careful not to strain the speaker and battery cables during this step.
      • Insert an opening pick in the seam between the midplate and the ear cup.
      • Twist the pick to loosen the midplate.
      • Use your fingers to swing the midplate away from the ear cup.
      Ask FixBot
    8. Logitech Zone 305 Battery Replacement, Remove the battery: step 10, image 1 of 3 Logitech Zone 305 Battery Replacement, Remove the battery: step 10, image 2 of 3 Logitech Zone 305 Battery Replacement, Remove the battery: step 10, image 3 of 3
      • The battery's lightly adhered to the midplate.
      • Slide the tip of an opening pick under the battery and pry gently to separate it from the midplate.
      Ask FixBot
    9. Logitech Zone 305 Battery Replacement: step 11, image 1 of 2 Logitech Zone 305 Battery Replacement: step 11, image 2 of 2
      • Use your fingers to peel and remove the foam pad covering the circuit board.
      • Store this pad in a clean location for reassembly.
      Ask FixBot
    10. Logitech Zone 305 Battery Replacement: step 12, image 1 of 3 Logitech Zone 305 Battery Replacement: step 12, image 2 of 3 Logitech Zone 305 Battery Replacement: step 12, image 3 of 3
      • Use angled tweezers to grip the edges of the battery connector.
      • Gently rock the connector side-to-side and slide the battery connector out of its socket.
      • This connector can be difficult to disconnect. Squeeze the tweezers close to the tips to help grip the connector.
      Ask FixBot
    11. Logitech Zone 305 Battery Replacement: step 13, image 1 of 1
      • Remove the battery.
      Ask FixBot
    12. Logitech Zone 305 Battery Replacement, Install the battery: step 14, image 1 of 2 Logitech Zone 305 Battery Replacement, Install the battery: step 14, image 2 of 2
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • The remaining instructions show how to reassemble the headset.
      • Cut and attach a small strip of double-sided tape onto the battery.
      • Remove the liner to expose the adhesive.
      Ask FixBot
    13. Logitech Zone 305 Battery Replacement: step 15, image 1 of 2 Logitech Zone 305 Battery Replacement: step 15, image 2 of 2
      • Use your fingers to slide the battery connector fully into its circuit board socket.
      Ask FixBot
    14. Logitech Zone 305 Battery Replacement: step 16, image 1 of 1
      • Place the foam pad over the circuit board and use your finger to press it in place.
      Ask FixBot
    15. Logitech Zone 305 Battery Replacement: step 17, image 1 of 1
      • Align the battery in the midplate recess such that the battery cable reaches its circuit board connector.
      • Use your fingers to press the battery onto the midplate.
      Ask FixBot
    16. Logitech Zone 305 Battery Replacement, Install the midplate: step 18, image 1 of 2 Logitech Zone 305 Battery Replacement, Install the midplate: step 18, image 2 of 2
      • Swing the midplate back in place over the ear cup.
      Ask FixBot
    17. Logitech Zone 305 Battery Replacement: step 19, image 1 of 1
      • Use a Phillips screwdriver to install the three 5.3 mm‑long screws to secure the midplate.
      Ask FixBot
    18. Logitech Zone 305 Battery Replacement: step 20, image 1 of 1
      • At this point, you'll need to separate the speaker plate you partially reattached earlier to reinstall the pancake screw.
      • Use your fingers to unclip the speaker plate from the housing.
      Ask FixBot
    19. Logitech Zone 305 Battery Replacement, Install the speaker housing: step 21, image 1 of 1
      • Align the speaker housing to the midplate such that the speaker wire threads through both parts without twisting.
      Ask FixBot
    20. Logitech Zone 305 Battery Replacement: step 22, image 1 of 2 Logitech Zone 305 Battery Replacement: step 22, image 2 of 2
      • Align the ball joint to the speaker housing's center cutout.
      • Use your fingers to firmly press the speaker housing onto the ball joint to pop it back in place.
      Ask FixBot
    21. Logitech Zone 305 Battery Replacement: step 23, image 1 of 1
      • Use a Phillips screwdriver to install the 7.1 mm‑long pancake screw to secure the speaker housing.
      Ask FixBot
    22. Logitech Zone 305 Battery Replacement: step 24, image 1 of 2 Logitech Zone 305 Battery Replacement: step 24, image 2 of 2
      • Use your fingers to move the speaker plate back over the speaker housing.
      • The top clip is wider than the rest of the clips. Use this to help align the speaker plate to the housing.
      Ask FixBot
    23. Logitech Zone 305 Battery Replacement: step 25, image 1 of 3 Logitech Zone 305 Battery Replacement: step 25, image 2 of 3 Logitech Zone 305 Battery Replacement: step 25, image 3 of 3
      • Use your fingers to squeeze and engage the four clips to secure the speaker plate to the housing.
      Ask FixBot
    1. Logitech Zone 305 Battery Replacement, Install the ear pad: step 26, image 1 of 3 Logitech Zone 305 Battery Replacement, Install the ear pad: step 26, image 2 of 3 Logitech Zone 305 Battery Replacement, Install the ear pad: step 26, image 3 of 3
      • Installing the ear pad can be tricky. Be patient and work slowly—it may take a couple tries.
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, place the pad over the top of the cup, so the fabric flap slips over the cup's plastic lip.
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Arthur Shi
352,663 Reputation
937 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 78
All Time: 425
