Logitech MX Keys Battery Replacement
  1. Logitech MX Keys Battery Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 3 Logitech MX Keys Battery Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 3 Logitech MX Keys Battery Replacement, Prepare your keyboard for disassembly: step 1, image 3 of 3
    • Slide the keyboard's power switch into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from your keyboard.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface may scratch the keyboard, place a soft towel under it.
    Ask FixBot
  2. Logitech MX Keys Battery Replacement, Remove the feet: step 2, image 1 of 2 Logitech MX Keys Battery Replacement, Remove the feet: step 2, image 2 of 2
    • Heat an iOpener and lay it on the top left foot for one minute.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic.
    Ask FixBot
  3. Logitech MX Keys Battery Replacement: step 3, image 1 of 3 Logitech MX Keys Battery Replacement: step 3, image 2 of 3 Logitech MX Keys Battery Replacement: step 3, image 3 of 3
    • The foot should come up without much force. If it feels stuck, apply more heat and try again.
    • Insert the point of a spudger under an end of the foot.
    • Push the spudger underneath the foot and lift until you can grip it with your fingers.
    • Peel the foot up and remove it.
    • Repeat the process to remove the remaining feet.
    • If you're replacing the battery, you only need to remove the feet along the top edge.
    Ask FixBot
  4. Logitech MX Keys Battery Replacement, Reassembly information: step 4, image 1 of 2 Logitech MX Keys Battery Replacement, Reassembly information: step 4, image 2 of 2
    Tool used on this step:
    Tesa 61395 Tape
    $2.95
    Buy
    • To install the feet during reassembly:
    • Use a pair of angled tweezers to peel up and remove all the plastic film from the foot recesses.
    • If you're installing new feet, remove them from their backing and firmly press them into place.
    • If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
    Ask FixBot
  5. Logitech MX Keys Battery Replacement, Remove the battery cover: step 5, image 1 of 3 Logitech MX Keys Battery Replacement, Remove the battery cover: step 5, image 2 of 3 Logitech MX Keys Battery Replacement, Remove the battery cover: step 5, image 3 of 3
    • Plastic film may be covering the screws in the top edge foot recesses.
    • Use the pointed end of a spudger to poke through each film so you can access the screw underneath.
    Ask FixBot
  6. Logitech MX Keys Battery Replacement: step 6, image 1 of 2 Logitech MX Keys Battery Replacement: step 6, image 2 of 2
    • Use a Phillips screwdriver to remove the three 7.6 mm‑long screws securing the battery cover.
    Ask FixBot
  7. Logitech MX Keys Battery Replacement: step 7, image 1 of 3 Logitech MX Keys Battery Replacement: step 7, image 2 of 3 Logitech MX Keys Battery Replacement: step 7, image 3 of 3
    • Plastic clips secure the battery cover.
    • Insert an opening pick between the top edge of the battery cover and keyboard.
    • Slide the pick along the top edge to release the clips.
    Ask FixBot
  8. Logitech MX Keys Battery Replacement: step 8, image 1 of 2 Logitech MX Keys Battery Replacement: step 8, image 2 of 2
    • Insert an opening pick between the bottom edge of battery cover and keyboard.
    • Slide the pick along the bottom edge to release the remaining clips.
    Ask FixBot
  9. Logitech MX Keys Battery Replacement: step 9, image 1 of 2 Logitech MX Keys Battery Replacement: step 9, image 2 of 2
    • Remove the battery cover.
    • During reassembly:
    • Place the battery cover onto the keyboard assembly so the screw holes line up with their posts.
    • Press down firmly along the battery cover to engage its clips.
    • You should feel and hear distinct "clicks" as the clips engage.
    Ask FixBot
  10. Logitech MX Keys Battery Replacement, Remove the battery: step 10, image 1 of 3 Logitech MX Keys Battery Replacement, Remove the battery: step 10, image 2 of 3 Logitech MX Keys Battery Replacement, Remove the battery: step 10, image 3 of 3
    $3.99
    Buy
    • Use a pair of angled tweezers to firmly grip the battery connector and slide it straight out of its socket.
    • If you're having trouble, gently rock the connector side-to-side to help loosen it.
    • Insert the connector into its socket so the side with raised plastic in the center is facing up.
    • Push on the edges of the connector with the flat end of a spudger until it's fully seated in the socket.
    Ask FixBot
  11. Logitech MX Keys Battery Replacement: step 11, image 1 of 2 Logitech MX Keys Battery Replacement: step 11, image 2 of 2
    • Pull the three battery cables out of their channel in the keyboard.
    • During reassembly, route all three cables through their channel so they're on top of each other.
    Ask FixBot
  12. Logitech MX Keys Battery Replacement: step 12, image 1 of 3 Logitech MX Keys Battery Replacement: step 12, image 2 of 3 Logitech MX Keys Battery Replacement: step 12, image 3 of 3
    • Insert the flat end of a spudger underneath the right edge of the battery, opposite the cables.
    • Slide the spudger underneath the battery and gently lift to separate the adhesive securing it to the keyboard.
    • Make sure you push the spudger underneath the battery and not into it. Don't bend or deform the battery.
    • If the battery isn't separating, apply a few drops of isopropyl alcohol (>90%) to its edge and slightly tilt the keyboard. Wait one minute for the alcohol to soften the adhesive and try again.
    • Remove the battery.
    Ask FixBot
  13. Logitech MX Keys Battery Replacement, Reassembly information: step 13, image 1 of 2 Logitech MX Keys Battery Replacement, Reassembly information: step 13, image 2 of 2
    Tesa 61395 Tape
    $8.95
    Buy
    • To install a replacement battery:
    • Remove any bits of the old adhesive from the battery recess.
    • If your replacement battery doesn't come with tape pre-installed, apply double-sided tape to the battery recess (not directly to the battery).
    • If your replacement battery has adhesive pre-installed, remove the plastic liner.
    Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
43 other people completed this guide.
Spencer Day
196,368 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
18 Guide Comments
按照锂电池循环的寿命500次计算,mx key 充一次电至少可以用10天,那就是5000天,10几年后你才需要看这篇文章。
timo - Reply Share
这只是理论。实际上,电池可持续使用 3 年。
Carlos González Debia - Reply Share
O meu durou exatamente 4 anos
sergiooti - Reply Share
I wish ifixit would sell the battery as well.
Peter Liu - Reply Share
Though @timo is technically correct with his calculations, I use this keyboard so often that after only eight months, the battery needs to be recharged about once every two days. Time to replace it! Such calculations can never account for usability. I use the backlight feature constantly which I'm sure is why my battery degraded as quickly as it did.
Mike Sims - Reply Share
Past 24 Hours: 26
Past 7 Days: 298
Past 30 Days: 1,500
All Time: 80,234
