Shop the Holiday Gift Guide
Logitech G535 Battery Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
52
Past 30 Days:
227
All Time:
1,881
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace a worn-out or dead battery in your Logitech G535 headset.
It’s natural for batteries to lose capacity as they age. If your headset dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Logitech G535 Battery Replacement, Prepare the headset for disassembly: step 1, image 1 of 1
      • Power off the headset and unplug all cables.
      Ask FixBot
    2. Logitech G535 Battery Replacement, Remove the ear pads: step 2, image 1 of 3 Logitech G535 Battery Replacement, Remove the ear pads: step 2, image 2 of 3 Logitech G535 Battery Replacement, Remove the ear pads: step 2, image 3 of 3
      • If you're replacing the headset battery, you only need to remove the left ear pad.
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Repeat the process to remove the other ear pad.
      Ask FixBot
    1. Logitech G535 Battery Replacement, Remove the screw sticker: step 3, image 1 of 2 Logitech G535 Battery Replacement, Remove the screw sticker: step 3, image 2 of 2
      • Use angled tweezers to peel up and remove the sticker covering the bottom-right speaker plate screw.
      Ask FixBot
    2. Logitech G535 Battery Replacement, Remove the speaker plate screws: step 4, image 1 of 1
      • Use a T5 Torx driver to remove the four 6.1 mm‑long screws securing the speaker plate.
      Ask FixBot
    3. Logitech G535 Battery Replacement, Move the speaker plate: step 5, image 1 of 3 Logitech G535 Battery Replacement, Move the speaker plate: step 5, image 2 of 3 Logitech G535 Battery Replacement, Move the speaker plate: step 5, image 3 of 3
      • Don't try to fully remove the speaker plate—it's still attached by a cable.
      • Use your fingers to swing the speaker plate to the side of the housing, making sure not to strain the cable.
      Ask FixBot
    4. Logitech G535 Battery Replacement, Disconnect the battery: step 6, image 1 of 3 Logitech G535 Battery Replacement, Disconnect the battery: step 6, image 2 of 3 Logitech G535 Battery Replacement, Disconnect the battery: step 6, image 3 of 3
      • Use tweezers to firmly grip the edges of the battery connector.
      • Gently rock the connector side-to-side and slide it out of its socket.
      Ask FixBot
    5. Logitech G535 Battery Replacement, Remove the battery: step 7, image 1 of 3 Logitech G535 Battery Replacement, Remove the battery: step 7, image 2 of 3 Logitech G535 Battery Replacement, Remove the battery: step 7, image 3 of 3
      • The battery is lightly adhered to the ear cup.
      • Insert the flat end of a spudger underneath the battery.
      • Pry gently to release the battery from the ear cup.
      • Remove the battery.
      Ask FixBot
    6. Logitech G535 Battery Replacement, Prep the replacement battery: step 8, image 1 of 3 Logitech G535 Battery Replacement, Prep the replacement battery: step 8, image 2 of 3 Logitech G535 Battery Replacement, Prep the replacement battery: step 8, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Use your fingers to peel the foam pad from the battery.
      • Transfer the pad onto the replacement battery.
      • Apply a strip of double-sided tape to the foam pad.
      Ask FixBot
    7. Logitech G535 Battery Replacement, Install the battery: step 9, image 1 of 2 Logitech G535 Battery Replacement, Install the battery: step 9, image 2 of 2
      • Use your finger to press the battery onto the ear cup such that the wires face towards the circuit board socket.
      Ask FixBot
    8. Logitech G535 Battery Replacement: step 10, image 1 of 2 Logitech G535 Battery Replacement: step 10, image 2 of 2
      • Use your fingers to slide the battery connector fully into its circuit board socket.
      Ask FixBot
    9. Logitech G535 Battery Replacement, Install the speaker plate: step 11, image 1 of 2 Logitech G535 Battery Replacement, Install the speaker plate: step 11, image 2 of 2
      • Use your fingers to swing the speaker plate back into place.
      Ask FixBot
    10. Logitech G535 Battery Replacement: step 12, image 1 of 1
      • Use a T5 Torx driver to install the four 6.1 mm‑long screws to secure the speaker plate.
      Ask FixBot
    1. Logitech G535 Battery Replacement, Install the ear pad: step 13, image 1 of 3 Logitech G535 Battery Replacement, Install the ear pad: step 13, image 2 of 3 Logitech G535 Battery Replacement, Install the ear pad: step 13, image 3 of 3
      • Installing an ear pad onto the cup can be tricky. Be patient and work slowly—it may take a couple tries.
      • Orient the ear pad so the wider part is at the top.
      • With your free hand, place the pad over the top of the cup, so the black fabric flap slips over the cup's plastic lip.
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      Ask FixBot
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Author
with
Arthur Shi
353,466 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 52
Past 30 Days: 227
All Time: 1,881
