Samsung Galaxy S21+ Back Cover Replacement
Views: 20K
View statistics:
Past 24 Hours:
7
Past 7 Days:
82
Past 30 Days:
304
All Time:
19,826
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the back cover on your Samsung Galaxy S21+.
Note: Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Samsung Galaxy S21+ Back Cover Replacement, Heat the bottom edge: step 1, image 1 of 1
      • Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Samsung Galaxy S21+ Back Cover Replacement, Insert an opening pick: step 2, image 1 of 3 Samsung Galaxy S21+ Back Cover Replacement, Insert an opening pick: step 2, image 2 of 3 Samsung Galaxy S21+ Back Cover Replacement, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
      • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
      • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: step 3, image 1 of 2 Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: step 3, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Samsung Galaxy S21+ Back Cover Replacement, Heat the right edge: step 4, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      Ask FixBot
    5. Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: step 5, image 1 of 3 Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: step 5, image 2 of 3 Samsung Galaxy S21+ Back Cover Replacement, Slice the adhesive: step 5, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
      • Insert a third opening pick at the bottom right corner of your phone.
      • Slide the opening pick along the right edge of your phone to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Samsung Galaxy S21+ Back Cover Replacement, Heat the top edge: step 6, image 1 of 1
      • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
      Ask FixBot
    7. Samsung Galaxy S21+ Back Cover Replacement: step 7, image 1 of 3 Samsung Galaxy S21+ Back Cover Replacement: step 7, image 2 of 3 Samsung Galaxy S21+ Back Cover Replacement: step 7, image 3 of 3
      • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
      • Insert a fourth opening pick underneath the top right corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    8. Samsung Galaxy S21+ Back Cover Replacement, Heat the left edge: step 8, image 1 of 1
      • Heat an iOpener and apply it to the left edge of the back cover for two minutes.
      Ask FixBot
    9. Samsung Galaxy S21+ Back Cover Replacement: step 9, image 1 of 3 Samsung Galaxy S21+ Back Cover Replacement: step 9, image 2 of 3 Samsung Galaxy S21+ Back Cover Replacement: step 9, image 3 of 3
      • Insert a fifth opening pick underneath the bottom left corner.
      • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
      • When you slice near the power button, insert only the tip of the opening pick (~3-4 mm) to avoid damaging the power and volume button flex cable.
      Ask FixBot
    10. Samsung Galaxy S21+ Back Cover Replacement, Remove the back cover: step 10, image 1 of 2 Samsung Galaxy S21+ Back Cover Replacement, Remove the back cover: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the back cover.
      • During reassembly:
      • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
5 other people completed this guide.
Dominik Schnabelrauch
266,462 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,895 Guides authored
2 Guide Comments
I can't seem to find a good guide on how to affix the new glue for the back of a Galaxy S21+ (Plus). (USA - T-Mobile). The glue on the provided replacement looks different than the glue I removed, it goes around the cameras, whereas before there wasn't any glue there.
Sam C - Reply Share
In addition, even in your own video I found on YouTube, it shows a completely different adhesive layout being used. (https://www.youtube.com/watch?v=axCXYLE6... / "Samsung Galaxy S21 Plus Battery Replacement!"). Note, I have indeed have a Galaxy S21+ (SM-G996UZKATMB to be exact), but the back is plastic, not glass, like a like of guides for this phone allude to. I'm confused.
Sam C - Reply Share
Past 24 Hours: 7
Past 7 Days: 82
Past 30 Days: 304
All Time: 19,826
