Logitech G435 Battery Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
20
Past 7 Days:
182
Past 30 Days:
775
All Time:
5,385
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace a worn-out or dead battery in your Logitech G435 headset. The battery is located in the left ear cup.
It’s natural for batteries to lose capacity as they age. If your headset dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Logitech G435 Battery Replacement, Prepare the headset for disassembly: step 1, image 1 of 1
      • Power off the headset and unplug all cables.
      Ask FixBot
    2. Logitech G435 Battery Replacement, Remove the ear pads: step 2, image 1 of 3 Logitech G435 Battery Replacement, Remove the ear pads: step 2, image 2 of 3 Logitech G435 Battery Replacement, Remove the ear pads: step 2, image 3 of 3
      • If you're replacing the headset battery, you only need to remove the left ear pad (the side containing the power button).
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Repeat the process to remove the other ear pad.
      Ask FixBot
    1. Logitech G435 Battery Replacement, Remove the screw sticker: step 3, image 1 of 2 Logitech G435 Battery Replacement, Remove the screw sticker: step 3, image 2 of 2
      • Use angled tweezers to peel up and remove the sticker covering the top-left speaker plate screw.
      Ask FixBot
    2. Logitech G435 Battery Replacement, Remove the speaker plate screws: step 4, image 1 of 1
      • Use a T5 Torx driver to remove the four 6.1 mm‑long screws securing the speaker plate.
      Ask FixBot
    3. Logitech G435 Battery Replacement, Secure the speaker plate: step 5, image 1 of 3 Logitech G435 Battery Replacement, Secure the speaker plate: step 5, image 2 of 3 Logitech G435 Battery Replacement, Secure the speaker plate: step 5, image 3 of 3
      • Don't try to fully remove the speaker plate—it's still attached by some wires.
      • Use your fingers to swing the speaker plate out of the housing.
      • Use some tape to secure the speaker plate to the headband. This keeps the speaker plate out of the way while preventing the speaker wire from being strained.
      Ask FixBot
    4. Logitech G435 Battery Replacement, Remove the circuit board screws: step 6, image 1 of 1
      • Use a Phillips screwdriver to remove the two 4.6 mm‑long screws securing the circuit board.
      Ask FixBot
    5. Logitech G435 Battery Replacement, Detach the circuit board: step 7, image 1 of 3 Logitech G435 Battery Replacement, Detach the circuit board: step 7, image 2 of 3 Logitech G435 Battery Replacement, Detach the circuit board: step 7, image 3 of 3
      • The circuit board is still connected by many wires. Be gentle as you move the board to prevent damaging any wires.
      • Use your fingers to lift the circuit board slightly out of its recess.
      • Flip the circuit board over so you can access the underside.
      Ask FixBot
    6. Logitech G435 Battery Replacement, Disconnect the battery: step 8, image 1 of 3 Logitech G435 Battery Replacement, Disconnect the battery: step 8, image 2 of 3 Logitech G435 Battery Replacement, Disconnect the battery: step 8, image 3 of 3
      • Use tweezers to firmly grip the edges of the battery connector.
      • Gently rock the connector side-to-side and slide it out of its socket.
      Ask FixBot
    7. Logitech G435 Battery Replacement, Remove the battery: step 9, image 1 of 3 Logitech G435 Battery Replacement, Remove the battery: step 9, image 2 of 3 Logitech G435 Battery Replacement, Remove the battery: step 9, image 3 of 3
      • The battery is lightly adhered to the ear cup.
      • Insert the flat end of a spudger underneath the battery.
      • Pry gently to release the battery from the ear cup.
      • Remove the battery.
      Ask FixBot
    8. Logitech G435 Battery Replacement, Transfer the battery pad: step 10, image 1 of 2 Logitech G435 Battery Replacement, Transfer the battery pad: step 10, image 2 of 2
      • Use your fingers to peel the foam pad from the battery.
      • Transfer the pad onto the same side of the replacement battery.
      Ask FixBot
    9. Logitech G435 Battery Replacement, Attach the battery: step 11, image 1 of 3 Logitech G435 Battery Replacement, Attach the battery: step 11, image 2 of 3 Logitech G435 Battery Replacement, Attach the battery: step 11, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Cut and attach a small strip of double-sided tape onto the battery.
      • Use your finger to press the battery onto the ear cup such that the wires face towards the circuit board socket.
      Ask FixBot
    10. Logitech G435 Battery Replacement, Reconnect the battery: step 12, image 1 of 2 Logitech G435 Battery Replacement, Reconnect the battery: step 12, image 2 of 2
      • Use your fingers to slide the battery connector fully into its circuit board socket.
      Ask FixBot
    11. Logitech G435 Battery Replacement, Install the circuit board: step 13, image 1 of 2 Logitech G435 Battery Replacement, Install the circuit board: step 13, image 2 of 2
      • Use your fingers to gently flip the circuit board back over its recess.
      Ask FixBot
    12. Logitech G435 Battery Replacement: step 14, image 1 of 3 Logitech G435 Battery Replacement: step 14, image 2 of 3 Logitech G435 Battery Replacement: step 14, image 3 of 3
      • Align the circuit board notch on the right side of the USB-C port to the ridge on the ear cup.
      • Insert the circuit board at a downward angle and guide the USB-C port into its cutout.
      • Press the bottom edge of the board against the ear cup and tilt the board down.
      • This is a tight fit, as the board has to clear the screw post next to the port to be properly seated.
      Ask FixBot
    13. Logitech G435 Battery Replacement: step 15, image 1 of 1
      • Use a Phillips screwdriver to install the two 4.6 mm‑long screws to secure the circuit board.
      Ask FixBot
    14. Logitech G435 Battery Replacement, Install the speaker plate: step 16, image 1 of 2 Logitech G435 Battery Replacement, Install the speaker plate: step 16, image 2 of 2
      • Use your fingers to swing the speaker plate back into place.
      Ask FixBot
    15. Logitech G435 Battery Replacement: step 17, image 1 of 1
      • Use a T5 Torx driver to install the four 6.1 mm‑long screws to secure the speaker plate.
      Ask FixBot
    1. Logitech G435 Battery Replacement, Install the ear pad: step 18, image 1 of 3 Logitech G435 Battery Replacement, Install the ear pad: step 18, image 2 of 3 Logitech G435 Battery Replacement, Install the ear pad: step 18, image 3 of 3
      • Installing an ear pad onto the cup can be tricky. Be patient and work slowly—it may take a couple tries.
      • Orient the ear pad so the wider part is at the top.
      • With your free hand, place the pad over the top of the cup, so the black fabric flap slips over the cup's plastic lip.
      • The ear pad has a clear plastic stiffener. This piece should not slip over the ear cup lip.
      Ask FixBot
    2. Logitech G435 Battery Replacement: step 19, image 1 of 2 Logitech G435 Battery Replacement: step 19, image 2 of 2
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      Ask FixBot
Congratulations on completing your repair!
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
3 other people completed this guide.
Arthur Shi
352,539 Reputation
937 Guides authored
2 Guide Comments
Sehr gute Beschreibung - In 15min war alles fertig! TOP
BigRob - Reply Share
Thank you very much. This was an easy repair thanks to your guide.
Thanks Logitech for doing the right thing as well.
Robert Basantsov - Reply Share
Past 24 Hours: 20
Past 7 Days: 182
Past 30 Days: 775
All Time: 5,385
