LG G3 Battery Replacement
  1. LG G3 Battery Replacement, Back Cover: step 1, image 1 of 2 LG G3 Battery Replacement, Back Cover: step 1, image 2 of 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Battery Replacement: step 2, image 1 of 2 LG G3 Battery Replacement: step 2, image 2 of 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Battery Replacement, Battery: step 3, image 1 of 2 LG G3 Battery Replacement, Battery: step 3, image 2 of 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Battery Replacement: step 4, image 1 of 2 LG G3 Battery Replacement: step 4, image 2 of 2
    • Lift the battery out of its recess and remove it.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21 other people completed this guide.
Dominik Schnabelrauch
203,362 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
One Comment
Thank you very much!
ItayDigital - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 17,573
