LG G Pad 8.3 Back Panel Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. LG G Pad 8.3 Back Panel Replacement, Back Panel: step 1, image 1 of 2 LG G Pad 8.3 Back Panel Replacement, Back Panel: step 1, image 2 of 2
    • With the tablet face down, pull out the SD card slot cover.
    • Using a Philips #000 screwdriver, remove the 3mm screw in the SD card slot.
  2. LG G Pad 8.3 Back Panel Replacement: step 2, image 1 of 3 LG G Pad 8.3 Back Panel Replacement: step 2, image 2 of 3 LG G Pad 8.3 Back Panel Replacement: step 2, image 3 of 3
    • Insert a plastic opening tool in the small crevasse between the screen and the back.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Back Panel Replacement: step 3, image 1 of 2 LG G Pad 8.3 Back Panel Replacement: step 3, image 2 of 2
    • After using the plastic opening tools, pry open the device with your hands, removing the back panel from the screen.
Raenicia Haworth
387 Reputation
1 Guide authored
CSU Fullerton, Team 1-6, Bruce Fall 2015 Member of CSU Fullerton, Team 1-6, Bruce Fall 2015
CSUF-BRUCE-F15S1G6
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 133
