Kobo Libra Colour (N428) Screen Replacement
    1. Kobo Libra Colour (N428) Screen Replacement, Before you begin: step 1, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Before you begin: step 1, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Before you begin: step 1, image 3 of 3
      • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
      • Optionally, to drain the battery faster, navigate to More → Settings → Energy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
      • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
      • Unplug all cables and fully shut down your eReader.
      • Your screen should be black and say Powered off.
      Ask FixBot
    1. Kobo Libra Colour (N428) Screen Replacement, Insert an opening pick: step 2, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Insert an opening pick: step 2, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Insert an opening pick: step 2, image 3 of 3
      • Flip your eReader over so the screen is facing down.
      • Angle an opening pick straight down, and insert its tip under the top right corner of the back cover, near the power button.
      • Push downward and pry up with the pick until you feel it slide between one of the clips and the frame.
      • You may have to test a few spots along the corner until the pick slides between one of the clips.
      Ask FixBot
    2. Kobo Libra Colour (N428) Screen Replacement, Release the right clips: step 3, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Release the right clips: step 3, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Release the right clips: step 3, image 3 of 3
      • Slide the pick toward the bottom right corner to release the clips along the right edge.
      Ask FixBot
    3. Kobo Libra Colour (N428) Screen Replacement: step 4, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement: step 4, image 2 of 2
      • Angle the pick flat under the back cover and rotate it around the bottom right corner to release its clips.
      • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
      Ask FixBot
    4. Kobo Libra Colour (N428) Screen Replacement, Release the bottom clips: step 5, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Release the bottom clips: step 5, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Release the bottom clips: step 5, image 3 of 3
      • Slide the pick toward the bottom left corner to release the clips along the bottom edge.
      Ask FixBot
    5. Kobo Libra Colour (N428) Screen Replacement, Remove the back cover: step 6, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the back cover: step 6, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the back cover: step 6, image 3 of 3
      • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
      • Grip the right edge of the back cover and lift it away from the eReader to release the remaining clips.
      • Remove the back cover.
      • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
      Ask FixBot
    1. Kobo Libra Colour (N428) Screen Replacement, Coating information: step 7, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Coating information: step 7, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Coating information: step 7, image 3 of 3
      • The entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
      • While this won't hurt your device, removing the coating compromises the device to potential water damage.
      • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
      • Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
      Ask FixBot
    2. Kobo Libra Colour (N428) Screen Replacement, Disconnect the battery: step 8, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Disconnect the battery: step 8, image 2 of 2
      • Use a spudger to pry up and disconnect the battery press connector.
      • Don't pry against the motherboard, as you risk breaking small, surface-mounted components.
      • Your E-ink screen will continue to say Powered off even after disconnection—this is normal!
      Ask FixBot
    1. Kobo Libra Colour (N428) Screen Replacement, Soften the power button board coating: step 9, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Soften the power button board coating: step 9, image 2 of 2
      • Heat an iOpener and lay it on the power button board at the top left corner for 90 seconds to soften the coating.
      • Alternatively, you can use a hair dryer or a heat gun for 30 seconds.
      Ask FixBot
    2. Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 10, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 10, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 10, image 3 of 3
      • Use the tip of a spudger to scrape the coating off the ZIF connector's locking tab—enough so you can grab clumps of it with pointed tweezers.
      Ask FixBot
    3. Kobo Libra Colour (N428) Screen Replacement: step 11, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 11, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 11, image 3 of 3
      • Use pointed tweezers to peel off the coating around the locking tab and its hinge on the ZIF connector.
      • If the coating becomes too brittle and hard to peel off, reheat the power button board and try again.
      • This is a meticulous process! Failure to remove enough of the coating could damage the locking tab during disconnection, so take your time!
      Ask FixBot
    4. Kobo Libra Colour (N428) Screen Replacement, Disconnect the power button board: step 12, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Disconnect the power button board: step 12, image 2 of 2
      • Use the tip of a spudger to lift up the locking tab on the ZIF connector.
      • The locking tab should be nearly vertical when unlocked. If not, remove more coating until the tab can move freely.
      Ask FixBot
    5. Kobo Libra Colour (N428) Screen Replacement: step 13, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement: step 13, image 2 of 2
      • The blue pull tab on the interconnect cable is lightly held in place by the coating.
      • Slide an arm of pointed tweezers under the blue pull tab on the interconnect cable to separate the coating.
      Ask FixBot
    6. Kobo Libra Colour (N428) Screen Replacement: step 14, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 14, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 14, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers, or your fingers, to grip the blue pull tab on the interconnect cable.
      • You can also use blunt nose tweezers to get a better grip on the pull tab.
      • Pull the cable away from the ZIF connector slowly and steadily at a level angle to separate the coating and disconnect the cable.
      • If you're having trouble, try rocking the cable side-to-side while pulling, and reheat when necessary.
      Ask FixBot
    7. Kobo Libra Colour (N428) Screen Replacement, Soften the motherboard coating: step 15, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Soften the motherboard coating: step 15, image 2 of 2
      • If you aren't replacing the white interconnect cable skip to this step.
      • Apply a heated iOpener to the interconnect cable's ZIF connector on the motherboard for 90 seconds to soften the coating.
      Ask FixBot
    8. Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 16, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 16, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 16, image 3 of 3
      • Scrape off and remove the coating on the interconnect cable ZIF connector located on the motherboard.
      Ask FixBot
    9. Kobo Libra Colour (N428) Screen Replacement, Disconnect the interconnect cable: step 17, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Disconnect the interconnect cable: step 17, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Disconnect the interconnect cable: step 17, image 3 of 3
      • Use tweezers, or your fingers, to grip the blue pull tab on the interconnect cable and disconnect it.
      • During reassembly:
      • Inspect the ends of the cable and the ZIF connectors for any remaining coating that could prevent a good connection.
      • Peel off the coating, heating the cable and the ZIF connector when the coating becomes too brittle.
      • It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in the connector.
      Ask FixBot
    10. Kobo Libra Colour (N428) Screen Replacement, Soften the interconnect cable adhesive: step 18, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Soften the interconnect cable adhesive: step 18, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Soften the interconnect cable adhesive: step 18, image 3 of 3
      • Apply a heated iOpener to the top edge of the eReader for 90 seconds to soften the adhesive under the interconnect cable.
      Ask FixBot
    11. Kobo Libra Colour (N428) Screen Replacement, Remove the interconnect cable: step 19, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the interconnect cable: step 19, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the interconnect cable: step 19, image 3 of 3
      • Hold one end of the interconnect cable and use your other hand to insert the tip of an opening pick underneath it.
      • Peel the cable away from the frame while sliding the pick in the same direction to separate the adhesive.
      • Work slowly to avoid creasing or folding cable, and reheat when necessary.
      • Remove the interconnect cable.
      Ask FixBot
    12. Kobo Libra Colour (N428) Screen Replacement, Soften the power button board adhesive: step 20, image 1 of 1
      • The power button board is held in place with adhesive and aligned by two pegs in the frame.
      • Apply a heated iOpener to the power button board for 90 seconds to soften the adhesive underneath.
      Ask FixBot
    13. Kobo Libra Colour (N428) Screen Replacement, Remove the power button board: step 21, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the power button board: step 21, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the power button board: step 21, image 3 of 3
      • Insert the tip of an opening pick under a corner of the power button board.
      • Slide the pick along the long edge of the power button board to separate its adhesive.
      Ask FixBot
    14. Kobo Libra Colour (N428) Screen Replacement: step 22, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 22, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 22, image 3 of 3
      • Slide the opening pick under the center of the power button board and pry up separate the remaining adhesive.
      • Remove the power button board.
      • During reassembly, follow this guide to replace the adhesive for the power button board and the interconnect cable.
      Ask FixBot
    1. Kobo Libra Colour (N428) Screen Replacement, Peel up the battery cable: step 23, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Peel up the battery cable: step 23, image 2 of 2
      Buy
      • Use tweezers, or your fingers, to peel the battery cable away the motherboard and separate the coating.
      Ask FixBot
    2. Kobo Libra Colour (N428) Screen Replacement, Battery information: step 24, image 1 of 1
      • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery! A punctured battery can leak dangerous chemicals and catch fire.
      • If your battery comes with stretch release adhesive, follow the next two steps to remove them.
      • Otherwise, skip ahead two steps to remove the normal adhesive.
      Ask FixBot
    3. Kobo Libra Colour (N428) Screen Replacement, Remove the stretch release adhesive: step 25, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the stretch release adhesive: step 25, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the stretch release adhesive: step 25, image 3 of 3
      • Grip a black pull tab and pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
      • You can also wrap an adhesive strip around a spudger and "roll" it for a more consistent pull.
      • If the adhesive strip breaks off, try to retrieve it using your fingers and continue pulling—but don’t pry under the battery.
      • If you can't retrieve a strip, don't worry! Remove as much adhesive as possible and skip down two steps for an alternate method.
      Ask FixBot
    4. Kobo Libra Colour (N428) Screen Replacement, Remove the battery: step 26, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the battery: step 26, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the battery: step 26, image 3 of 3
      • The battery is still lightly held to the frame by the coating.
      • Insert the long side of an opening pick under different edges of the battery to separate the coating.
      • Don't bend or crease the battery! Make sure all of the coating is separated before removing the battery.
      • Remove the battery.
      Ask FixBot
    5. Kobo Libra Colour (N428) Screen Replacement, Apply isopropyl alcohol: step 27, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Apply isopropyl alcohol: step 27, image 2 of 2
      • The next five steps show how to remove the battery using isopropyl alcohol and a plastic card.
      • Apply a few drops of isopropyl alcohol under the edge of the battery closest to the white interconnect cable.
      Ask FixBot
    6. Kobo Libra Colour (N428) Screen Replacement: step 28, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement: step 28, image 2 of 2
      • Tilt the eReader up to let the isopropyl alcohol flow under the battery.
      • Wait one minute for the alcohol to soften the adhesive.
      Ask FixBot
    7. Kobo Libra Colour (N428) Screen Replacement, Separate the adhesive: step 29, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Separate the adhesive: step 29, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Separate the adhesive: step 29, image 3 of 3
      • Slide a plastic card under the battery to separate the adhesive and the coating.
      • Don't bend or crease the battery! Avoid prying or lifting up with the plastic card.
      • If you're having trouble, apply a few more drops of isopropyl alcohol and try again.
      Ask FixBot
    8. Kobo Libra Colour (N428) Screen Replacement: step 30, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement: step 30, image 2 of 2
      • Slide the plastic card under the opposite end of the battery to separate any remaining adhesive and coating.
      Ask FixBot
    9. Kobo Libra Colour (N428) Screen Replacement, Remove the battery: step 31, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the battery: step 31, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the battery: step 31, image 3 of 3
      • Lift the battery out of the frame and remove it.
      • Never reuse a soft shell battery! Even if your battery doesn't show any signs of damage, get a new one.
      • During reassembly, follow this guide to install a new battery.
      Ask FixBot
    1. Kobo Libra Colour (N428) Screen Replacement, Soften the digitizer cables coating: step 32, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Soften the digitizer cables coating: step 32, image 2 of 2
      • Heat an iOpener and lay it on the digitizer cable ZIF connectors for 90 seconds to soften the coating.
      Ask FixBot
    2. Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 33, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 33, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 33, image 3 of 3
      Buy
      • Use the tip of a spudger to scrape the coating along the ZIF connectors' black locking tabs—enough so you can grab clumps of it with pointed tweezers.
      • Use pointed tweezers to peel off the coating around the black locking tabs and their hinges on the ZIF connector.
      • If the coating becomes too brittle and hard to peel off, reheat the connectors and try again.
      Ask FixBot
    3. Kobo Libra Colour (N428) Screen Replacement, Disconnect the digitizer cables: step 34, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Disconnect the digitizer cables: step 34, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Disconnect the digitizer cables: step 34, image 3 of 3
      • Use the point of a spudger to lift up the locking tabs on the ZIF connectors.
      • The locking tabs should be nearly vertical when unlocked. If not, remove more coating until the tabs can move freely.
      Ask FixBot
    4. Kobo Libra Colour (N428) Screen Replacement, Reheat the digitizer cables: step 35, image 1 of 1
      • Apply a heated iOpener to the digitizer cable ZIF connectors for 90 seconds to soften the coating.
      Ask FixBot
    5. Kobo Libra Colour (N428) Screen Replacement: step 36, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 36, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 36, image 3 of 3
      • Slide one arm of a pair of pointed tweezers underneath the cables to separate the coating securing them to the motherboard.
      • You only need to separate enough coating so you can grip the cables with blunt nose tweezers.
      Ask FixBot
    6. Kobo Libra Colour (N428) Screen Replacement: step 37, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 37, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 37, image 3 of 3
      • Because of the awkward angle, this step requires some patience to avoid tearing the cables. Work slowly and apply heat regularly.
      • Use blunt nose tweezers to pull the cables away from their ZIF connectors slowly and steadily at a level angle to separate the coating.
      • Gripping the tweezers closer to the tip can help get a tighter hold on the cables.
      • Keep pulling on the cables until they're completely disconnected.
      • Inspect the ends of the cables and the ZIF connectors for any remaining coating that could prevent a good connection.
      • Peel off the coating, heating the cable and the ZIF connectors when the coating becomes too brittle.
      • It doesn't have to look pretty! You just need to remove enough coating to have the cables sit properly in their connectors.
      Ask FixBot
    7. Kobo Libra Colour (N428) Screen Replacement, Soften the display cable coating: step 38, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Soften the display cable coating: step 38, image 2 of 2
      • Apply a heated iOpener to the display cable ZIF connector for 90 seconds to soften the coating.
      Ask FixBot
    8. Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 39, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 39, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the coating: step 39, image 3 of 3
      • The display cable ZIF connector is larger and requires a different procedure to disconnect properly.
      • Use the tip of a spudger to scrape the coating along the ZIF connector's black locking tab—enough so you can grab clumps of it with pointed tweezers.
      Ask FixBot
    9. Kobo Libra Colour (N428) Screen Replacement: step 40, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 40, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 40, image 3 of 3
      • If the coating becomes too brittle and hard to peel off, reheat the connector and try again.
      Ask FixBot
    10. Kobo Libra Colour (N428) Screen Replacement: step 41, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement: step 41, image 2 of 2
      • Use the flat end of a spudger to gently pry along the length of the locking tab to separate any remaining coating.
      • Don't pry hard at the corners of the locking tab to avoid snapping it.
      Ask FixBot
    11. Kobo Libra Colour (N428) Screen Replacement, Disconnect the display cable: step 42, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Disconnect the display cable: step 42, image 2 of 2
      • Insert the flat end of a spudger under the middle of the locking tab and lift to unlock it.
      Ask FixBot
    12. Kobo Libra Colour (N428) Screen Replacement: step 43, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement: step 43, image 2 of 2
      • Use blunt nose tweezers to grip the corner of the display cable closest to the charging port.
      • Pull the cable away from the ZIF connector slowly and steadily at a level angle to separate the coating at the corner.
      • If you're having trouble, try rocking the cable side-to-side while pulling.
      • Gripping the tweezers closer to the tip can help with getting a tighter hold on the cable.
      Ask FixBot
    13. Kobo Libra Colour (N428) Screen Replacement: step 44, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 44, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 44, image 3 of 3
      • Repeat the previous step for the other corner until the entire cable is disconnected.
      • Lift up the cable and peel off any remaining coating holding it to the motherboard.
      Ask FixBot
    1. Kobo Libra Colour (N428) Screen Replacement, Remove the motherboard screws: step 45, image 1 of 2 Kobo Libra Colour (N428) Screen Replacement, Remove the motherboard screws: step 45, image 2 of 2
      • Use a Phillips screwdriver to remove the seven screws securing the motherboard:
      • Four 2.4Ā mm‑long screws
      • Three 3.9Ā mm‑long screws
      Ask FixBot
    2. Kobo Libra Colour (N428) Screen Replacement, Remove the motherboard: step 46, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the motherboard: step 46, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the motherboard: step 46, image 3 of 3
      • Use a spudger to pry up the motherboard enough so you can grip it with your fingers.
      • Pull the motherboard toward the opposite side of the eReader to slide it out of its two clips.
      • Remove the motherboard.
      Ask FixBot
    3. Kobo Libra Colour (N428) Screen Replacement, Soften the motherboard buffer adhesive: step 47, image 1 of 1
      • Apply a heated iOpener to the plastic motherboard buffer for 90 seconds to soften the adhesive securing it to the frame.
      Ask FixBot
    4. Kobo Libra Colour (N428) Screen Replacement, Remove the motherboard buffer: step 48, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the motherboard buffer: step 48, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the motherboard buffer: step 48, image 3 of 3
      • Grip one end of the motherboard buffer and peel it away from the frame to separate the adhesive.
      • If you're having trouble, reheat the buffer for one minute before trying again.
      Ask FixBot
    5. Kobo Libra Colour (N428) Screen Replacement, Soften the front cover adhesive: step 49, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Soften the front cover adhesive: step 49, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Soften the front cover adhesive: step 49, image 3 of 3
      • The front cover is secured with clips and adhesive.
      • Flip your eReader over so the screen is facing up.
      • Apply a heated iOpener and lay it on the top edge of the front cover for 90 seconds to soften the adhesive underneath.
      Ask FixBot
    6. Kobo Libra Colour (N428) Screen Replacement, Unclip the front cover: step 50, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Unclip the front cover: step 50, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Unclip the front cover: step 50, image 3 of 3
      • Hold the eReader so your thumbs can push the underside of the front cover off its clips while your other fingers can pull the screen in the opposite direction.
      • Push the top left corner of the front cover while pulling the screen in the opposite direction to release the clips and separate the adhesive.
      • You'll hear and feel the adhesive slowly separate as you push on the front cover.
      • If you're having trouble, reheat the top edge for one minute before trying again.
      Ask FixBot
    7. Kobo Libra Colour (N428) Screen Replacement: step 51, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 51, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 51, image 3 of 3
      • While keeping the corner of the front cover separated with one hand, use your other hand to peel the left edge of the front cover off the frame.
      Ask FixBot
    8. Kobo Libra Colour (N428) Screen Replacement: step 52, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 52, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 52, image 3 of 3
      • Continue working around the perimeter of the front cover until all of the clips release and the adhesive is completely separated.
      • Heat the edges of the front cover when necessary.
      • The larger, rounded corners take more force to release their clips.
      Ask FixBot
    9. Kobo Libra Colour (N428) Screen Replacement, Remove the front cover: step 53, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the front cover: step 53, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the front cover: step 53, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • Lift the front cover off the frame and remove it.
      • During reassembly, align the front cover over the frame and press down around the perimeter until the clips snap back into place.
      • If the adhesive isn't sticky anymore, you can use a thin double-sided tape like Tesa tape to replace it.
      Ask FixBot
    10. Kobo Libra Colour (N428) Screen Replacement, Remove the light sealing tape: step 54, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the light sealing tape: step 54, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the light sealing tape: step 54, image 3 of 3
      • Your replacement screen may come with the following components already installed. If it does, you don't need to transfer them from the old display, and you can skip the final two steps.
      • Use tweezers to peel up the light sealing tape along the right edge of the screen enough to grip it with your fingers.
      Ask FixBot
    11. Kobo Libra Colour (N428) Screen Replacement: step 55, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement: step 55, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement: step 55, image 3 of 3
      • Peel the light sealing tape off the button bracket and the screen.
      Ask FixBot
    12. Kobo Libra Colour (N428) Screen Replacement, Remove the button board: step 56, image 1 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the button board: step 56, image 2 of 3 Kobo Libra Colour (N428) Screen Replacement, Remove the button board: step 56, image 3 of 3
      • Remove the button board from the screen.
      • You've now disassembled your eReader enough to transfer the internals to your new screen.
      • During reassembly, perform the following:
      • Before you reinstall your front cover, follow this guide to transfer your motherboard, motherboard buffer, and button bracket to your new screen.
      • Follow this guide to calibrate your new screen.
      Ask FixBot
Remember: after repairs, your eReader is no longer IPX8 waterproof.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Make sure each of your device's main functions still work, e.g., LED backlight, touch, page-turn buttons, Wi-Fi, etc.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
15 other people completed this guide.
Alex Diaz-Kokaisl
247,012 Reputation
1,203 Guides authored
iFixit Member of iFixit
Staff
123 Members
56,274 Guides authored
9 Guide Comments
Hallo,
wie kann man den Wasserschutz wieder herstellen? Gibt es eventuell den genannten Plastik, was man mit einer Heissluft dann auf den Steckern / Platine verlaufen lassen kann?
Klaus - Reply Share
Works like a charm! Thanks a lot!
Jan - Reply Share
@jan15181 I’m just replying to surface this video guide link since new comments get hidden 😩. Thank you to the maker and be sure to view the extra comments to see my additional tips too! https://youtu.be/9Tt9tXsBllk
Aimee L - Reply Share
Very comprehensive and intuitive guide! I didn't had to remove the motherboard buffer or the light sealing tape but the rest of the procedure was straightforward.
A little aside, the first screen Ifixit sent me had multiple pinholes but to Ifixit credit they immediately sent another one when I informed them of my issue. Overall a great first experience with the company!
Yasha - Reply Share
Is there a way to get the replacement with cheaper shipping to Malaysia? The price of the part including shipping cost the same as a new unit!
chunting toh - Reply Share
Past 24 Hours: 24
Past 7 Days: 213
Past 30 Days: 951
All Time: 21,477
