Introduction
Use this guide to replace a worn-out or dead battery in your Huawei P8 Lite (2017).
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Apply a suction cup to the rear glass, as close to the right edge as possible.
Pull up on the suction up with strong, steady force to create a gap.
Insert the tip of an opening pick into the gap between the rear glass and frame.
Slide the tip of the opening pick to the bottom right corner to cut the adhesive.
Leave it there to prevent the adhesive from resealing.
Insert a second opening pick at the bottom right corner.
Slide the tip of the opening pick to the top right corner to slice the adhesive.
Leave the opening pick at its place to prevent the adhesive from resealing.
Insert a third opening pick at the top right corner.
Slide it to the top left corner to cut the adhesive.
Insert a fourth opening pick at the top left corner.
Slide the tip of the opening pick to the bottom left corner to cut the adhesive.
Leave the opening pick in its place to prevent the adhesive from resealing.
Insert a fifth opening pick at the bottom left corner.
Slide it to the bottom right corner to cut the remaining adhesive.
Open the P8 Lite by swinging the rear glass up from the left side, like the back cover of a book.
Place the rear glass on the top of the battery.
Use a Phillips #00 screwdriver to remove the 2.9 mm screw.
Use the tip of an opening pick to pry up and loosen the metal shield.
Use a Phillips #00 screwdriver to remove the two 2.9 mm-long screws securing the battery connector shield.
Use the tip of an opening pick to pry up the battery connector shield.
Remove the metal shield.
Heat an iOpener and apply it to the display to loosen the adhesive beneath the battery for two minutes.
Insert the wide edge of an opening pick on the bottom left corner into the gap between the battery and the frame.
Slide the opening pick at a flat angle as far under the battery as possible. Be careful not to deform the battery.
Once the battery has slightly lifted, insert a second opening pick at the bottom left corner.
Slide the opening pick along the edge to the left center and slide it under the battery.
Insert a third opening in the center of the right edge and slide it under the battery to cut the remaining adhesive.
