Introduction
Use this guide to remove the screen of the Huawei Honor 9.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
This guide involves removing the rear glass cover and the battery—you will need replacement adhesive to reattach both and/or a new battery. If your replacement part does not come with adhesive, use a strong double-sided tape to secure it.
Switch off your phone.
Heat an iOpener and apply it to the back of the phone for around two minutes. This will help soften the adhesive securing the rear glass.
You might need to reheat and reapply the iOpener several times during the rear glass removal.
Tool used on this step:Tesa 61395 Tape$5.99
Carefully lift the rear glass and remove it.
Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Remove the three Phillips #00 screws (3.45 mm length).
Remove the five Phillips #00 screws (2.9 mm length).
Slide an opening pick under the right side of the motherboard shield.
Twist the opening pick sideways to release the clips that hold the shield in place.
Repeat the previous process and work your way around the motherboard shield until it pops out.
There’s another screw to remove before you can lift the shield out. It’s hidden by the thermal foil and is at the bottom centre of the motherboard shield.
Hey Ryan,
thanks for mentioning. That’s right and I added a bullet for this action.
Apply an iOpener to the center of the display, to loosen the adhesive beneath the battery.
Display flex cable
Interconnect flex cable
Tool used on this step:Plastic Cards$2.99
Insert an opening pick or plastic card between the frame and the battery.
Cut any remaining adhesive underneath the battery.
Pry up the battery until you can get a good grip.
Remove the battery.
Hallo!Ich habe die Akku gekauft und alle so wie hier steht gemacht.Nichts beschädigt. Nach einschaltung meine Display funktioniert, aber nicht empfinden.Ich kann nicht meine Android Pin code geben,keine Reboot machen und kann ich die Hisuite auch nicht verbinden(braucht Code)….Was meinen Sie,was ist die Problem?Momentan kann Mann nicht im Service bringen….
Apply an iOpener to the bottom end of the display to soften the adhesive beneath the loudspeaker.
Apply a heated iOpener to the display for around two minutes to soften the adhesive underneath.
Once the screen is warm to the touch, apply a suction cup near the top edge of the phone right under the earpiece speaker.
Pull up on the suction cup and insert the tip of an opening pick under the display near the earpiece speaker.
Slide the opening pick to the top left corner of the phone to cut the adhesive.
4 other people completed this guide.
