Shop the Holiday Gift Guide
How to Open the Logitech G703
Views: 40K
View statistics:
Past 24 Hours:
41
Past 7 Days:
232
Past 30 Days:
989
All Time:
39,681
Comments: 6
6 guide comments.
Go to guide comments
Completed: 19
19 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to open your Logitech G703 wireless mouse.
Opening your mouse gives you access to clean its internals, troubleshoot mechanical problems, or replace a part.
Tools
    1. How to Open the Logitech G703, Turn off the mouse: step 1, image 1 of 2 How to Open the Logitech G703, Turn off the mouse: step 1, image 2 of 2
      • Slide the mouse's power switch down so it's in the OFF position.
      • A red indicator should be visible beneath the switch.
      • Unplug all cables from the mouse.
      • Throughout the repair, it may be helpful to lay the mouse on a soft cloth to stabilize it and prevent damage while you work.
      Ask FixBot
    1. How to Open the Logitech G703, Heat the mouse feet: step 2, image 1 of 1
      • The feet are secured to the bottom of the mouse with strong adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
      • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
      • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
      • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
      Ask FixBot
    2. How to Open the Logitech G703, Remove the mouse feet: step 3, image 1 of 3 How to Open the Logitech G703, Remove the mouse feet: step 3, image 2 of 3 How to Open the Logitech G703, Remove the mouse feet: step 3, image 3 of 3
      • The feet have two layers—a rubberized one and an adhesive pad underneath.
      • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
      • Slide the tip of an opening pick under an edge of the bottom mouse foot, making sure it goes under both the foot and its adhesive pad.
      • If the foot feels stuck, apply more heat and try again.
      • Gently slide the pick farther under the foot and lift until you can grip it with your fingers.
      • Use your fingers to peel up and remove the foot.
      • Repeat the procedure to remove the top mouse foot.
      Ask FixBot
    3. How to Open the Logitech G703, Reassembly information: step 4, image 1 of 3 How to Open the Logitech G703, Reassembly information: step 4, image 2 of 3 How to Open the Logitech G703, Reassembly information: step 4, image 3 of 3
      • If the rubber layer separated from its adhesive pad:
      • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat it further.
      • Peel the adhesive off.
      • To install a new foot:
      • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
      • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
      • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
      • Remove the feet from their backing and firmly press them into place.
      Ask FixBot
    1. How to Open the Logitech G703, Remove the case screws: step 5, image 1 of 2 How to Open the Logitech G703, Remove the case screws: step 5, image 2 of 2
      • Use a Phillips screwdriver to remove the four 5.4 mm‑long screws securing the two halves of the mouse together.
      Ask FixBot
    2. How to Open the Logitech G703, Separate the cases: step 6, image 1 of 2 How to Open the Logitech G703, Separate the cases: step 6, image 2 of 2
      • Clips in front of the mouse wheel hold the two halves together. It's easiest to pull the halves apart at the back of the mouse before releasing the clips in the front.
      • Don't try to completely separate the two halves yet—they're still connected by a delicate cable.
      • Grasp the mouse cases near the back and pull the two halves apart slightly, so there's a gap at the back of the mouse.
      Ask FixBot
    3. How to Open the Logitech G703, Unclip the mouse case: step 7, image 1 of 2 How to Open the Logitech G703, Unclip the mouse case: step 7, image 2 of 2
      • The clips in the front of the mouse can be stubborn and may require some force to release. Apply steady, slowly increasing force to separate the halves.
      • Insert the flat end of a spudger into the small gap between the top and bottom cases, just above the charging port.
      • Use the spudger to pry the top case up to release the clip.
      • Don't apply too much force or you may crack the case. If you're having trouble, reinsert the spudger and try again.
      • Remember, the mouse halves are still tethered together by a delicate cable.
      Ask FixBot
    4. How to Open the Logitech G703, Disconnect the interconnect cable: step 8, image 1 of 3 How to Open the Logitech G703, Disconnect the interconnect cable: step 8, image 2 of 3 How to Open the Logitech G703, Disconnect the interconnect cable: step 8, image 3 of 3
      • Set the mouse down and position the top half so you can access the interconnect cable on the right side.
      • Use the flat end of a spudger to gently lift the black sliding tab on the interconnect cable socket until it's in the unlocked position.
      • You should feel the latch pop into the unlocked position. Don't push too far, or the latch may come completely off the connector.
      • Slide the interconnect cable straight up and out of its socket.
      Ask FixBot
    5. How to Open the Logitech G703, Remove the top half of the mouse: step 9, image 1 of 1
      • Remove the top half of the mouse.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
19 other people completed this guide.
Author
with
Dominik Schnabelrauch
267,301 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,955 Guides authored
6 Guide Comments
Thanks for this guide :)
It helped me diagnose the issue in my mouse and order the correct replacement parts.
One thing that I did find helpful is removing the ribbon cable before trying to unclip the top half
Duncan Sterken - Reply Share
How do you glue back the old adhesive feet?
Javi Alarcia - Reply Share
Where can I buy a replacement ribbon cable?
Emanuel Ibarra - Reply Share
worthless mouse. I tried every instruction out there and nothingg worked. I threw mine in the garbage and tot a new mouse.
William Proveaux - Reply Share
Simple disassembly guide that helped me out! I've had good luck with Logitech mice in the recent past with the adhesive pads on the bottom. I just set them aside sticky side up and had no problem sticking them back on. The clip in the front did give me some issue though.
Joe Willis - Reply Share
Past 24 Hours: 41
Past 7 Days: 232
Past 30 Days: 989
All Time: 39,681
