Google Pixel 3 Antenna Cable Disconnect
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Google Pixel 3 Antenna Cable Disconnect, Google Pixel 3 Antenna Cable Disconnect: step 1, image 1 of 2 Google Pixel 3 Antenna Cable Disconnect, Google Pixel 3 Antenna Cable Disconnect: step 1, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
  2. Google Pixel 3 Antenna Cable Disconnect: step 2, image 1 of 2 Google Pixel 3 Antenna Cable Disconnect: step 2, image 2 of 2
    • Use the point of a spudger to carefully pry up and release the blue antenna cable from its grounding clips.
    • The cable is fragile and prone to breaking. If it feels like the wire is firmly clamped in place, use the point of a spudger to push the clip open slightly, then try again.
  3. Google Pixel 3 Antenna Cable Disconnect: step 3, image 1 of 2 Google Pixel 3 Antenna Cable Disconnect: step 3, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port.
  4. Google Pixel 3 Antenna Cable Disconnect: step 4, image 1 of 1
    • Carefully de-route both antenna cables and move them away from the charging assembly.
  5. Google Pixel 3 Antenna Cable Disconnect: step 5, image 1 of 3 Google Pixel 3 Antenna Cable Disconnect: step 5, image 2 of 3 Google Pixel 3 Antenna Cable Disconnect: step 5, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the charging assembly's connector from its motherboard socket, near the right edge of the phone.
    • Carefully peel the flex cable from the top of the SIM card reader.
Arthur Shi
252,821 Reputation
526 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 41
