Google Pixel 3 Antenna Cable Disconnect
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Google Pixel 3 Antenna Cable Disconnect, Disconnect the blue antenna cable: step 1, image 1 of 2 Google Pixel 3 Antenna Cable Disconnect, Disconnect the blue antenna cable: step 1, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
      Ask FixBot
    2. Google Pixel 3 Antenna Cable Disconnect: step 2, image 1 of 2 Google Pixel 3 Antenna Cable Disconnect: step 2, image 2 of 2
      • Use the point of a spudger to carefully pry up and release the blue antenna cable from its grounding clips.
      • The cable is fragile and prone to breaking. If it feels like the wire is firmly clamped in place, use the point of a spudger to push the clip open slightly, then try again.
      Ask FixBot
    3. Google Pixel 3 Antenna Cable Disconnect, Disconnect the black antenna cable: step 3, image 1 of 2 Google Pixel 3 Antenna Cable Disconnect, Disconnect the black antenna cable: step 3, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port.
      Ask FixBot
    4. Google Pixel 3 Antenna Cable Disconnect, De-route the antenna cables: step 4, image 1 of 1
      • Carefully de-route both antenna cables and move them away from the charging assembly.
      Ask FixBot
    5. Google Pixel 3 Antenna Cable Disconnect: step 5, image 1 of 3 Google Pixel 3 Antenna Cable Disconnect: step 5, image 2 of 3 Google Pixel 3 Antenna Cable Disconnect: step 5, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the charging assembly's connector from its motherboard socket, near the right edge of the phone.
      • Carefully peel the flex cable from the top of the SIM card reader.
      Ask FixBot
Arthur Shi
350,889 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 324
