Shop the Holiday Gift Guide
Framework Laptop 12 Mainboard Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
7
Past 7 Days:
37
Past 30 Days:
149
All Time:
1,673
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Follow this guide to replace or upgrade the Mainboard in your Framework Laptop 12.
The Mainboard (aka motherboard) is responsible for the primary functions for your laptop. If you want to upgrade your processor, you'll need to replace the Mainboard.
Replacement Mainboard kits come with the fan and heatsink pre-attached, so you don't need to worry about applying thermal compound to the processor.
You'll encounter some component terms in this guide:
  • The Input Cover is the part that contains the keyboard and trackpad.
    1. Framework Laptop 12 Mainboard Replacement, Software preparations: step 1, image 1 of 1
      • If you're running Windows, perform these steps before you begin repairs:
      • Make sure you back up your data.
      • If you’re running a Pro version of Windows, suspend BitLocker by following these directions.
      • If you're running a Home version of Windows and have enabled Windows Device Encryption, you will want to disable it. To disable it, press Win + I to open Settings and select Privacy & Security. Select Device Encryption, then toggle the Device Encryption setting to Off.
      • Find your product key or link your Windows license to a Microsoft account to make sure you can re-activate Windows after the change.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Power down your laptop: step 2, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Power down your laptop: step 2, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Power down your laptop: step 2, image 3 of 3
      • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
      • The indicator LEDs along the edges should be unlit. The laptop should be silent.
      • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
      • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Set your laptop down: step 3, image 1 of 1
      • Set your Framework Laptop face-down on a clean work surface.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Remove the Expansion Cards: step 4, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Remove the Expansion Cards: step 4, image 2 of 2
      • Use your fingers to flip the two Expansion Card latches (one for each side) into the unlocked position.
      • The latches display a red bar when they're unlocked.
      Ask FixBot
    3. Framework Laptop 12 Mainboard Replacement: step 5, image 1 of 3 Framework Laptop 12 Mainboard Replacement: step 5, image 2 of 3 Framework Laptop 12 Mainboard Replacement: step 5, image 3 of 3
      • Grip the lip of an Expansion Card with your fingers.
      • Pull the Expansion Card out of its slot and remove it.
      • If you have trouble pulling the Expansion Card out, you can also use the flat end of your Framework Screwdriver to push against the lip.
      • Repeat this procedure to remove all remaining Expansion Cards.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Loosen the bottom screws: step 6, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Loosen the bottom screws: step 6, image 2 of 2
      • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
      • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
      • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Flip your laptop over: step 7, image 1 of 1
      • Flip your laptop face-up on your work surface.
      Ask FixBot
    3. Framework Laptop 12 Mainboard Replacement, Open your laptop: step 8, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Open your laptop: step 8, image 2 of 2
      • Open the laptop lid so that both the screen and the base lie flat on your work surface.
      Ask FixBot
    4. Framework Laptop 12 Mainboard Replacement, Remove the Input Cover: step 9, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Remove the Input Cover: step 9, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Remove the Input Cover: step 9, image 3 of 3
      • Use your fingers to grip the Input Cover in the hinge cutouts.
      • Lift upwards to swing the Input Cover up from the base of the laptop.
      • You may feel resistance from the magnets. If the cover feels like it's snagged, check that you've fully loosened the screws on the bottom of your laptop.
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Loosen the battery screws: step 10, image 1 of 1
      • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Disconnect the battery: step 11, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Disconnect the battery: step 11, image 2 of 2
      • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
      • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
      Ask FixBot
    3. Framework Laptop 12 Mainboard Replacement, Remove the battery: step 12, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Remove the battery: step 12, image 2 of 2
      • Lift and remove the battery from the laptop.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Open the memory flap: step 13, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Open the memory flap: step 13, image 2 of 2
      • Use your fingers to flip open the memory flap.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Remove the memory module: step 14, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Remove the memory module: step 14, image 2 of 2
      • Use your fingers to spread the clips on both sides of the memory module apart to unclip the memory.
      • The memory module will pop up to an angle when it's unclipped.
      Ask FixBot
    3. Framework Laptop 12 Mainboard Replacement: step 15, image 1 of 2 Framework Laptop 12 Mainboard Replacement: step 15, image 2 of 2
      • Use your fingers to grab the memory module by its edges.
      • Slide the memory module out of its socket and remove it.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Unlatch the SSD: step 16, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Unlatch the SSD: step 16, image 2 of 2
      • Use your finger to press down on the black SSD latch to unlatch the SSD.
      • The SSD will pop up to an angle when it's unlatched.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Remove the SSD: step 17, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Remove the SSD: step 17, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Remove the SSD: step 17, image 3 of 3
      • Grab the SSD by its edges and pull it out of its socket.
      • Remove the SSD.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Loosen the Audio Board screw: step 18, image 1 of 1
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Audio Board along the left edge of the laptop.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Remove the Audio Board: step 19, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Remove the Audio Board: step 19, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Remove the Audio Board: step 19, image 3 of 3
      • Use your fingers to lift the right edge of the Audio Board and pull it out of its recess.
      • Remove the Audio Board.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Loosen the Fingerprint Reader screw: step 20, image 1 of 1
      • If your laptop doesn't have a Fingerprint Reader, skip the next two steps.
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Fingerprint Reader.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Remove the Fingerprint Reader: step 21, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Remove the Fingerprint Reader: step 21, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Remove the Fingerprint Reader: step 21, image 3 of 3
      • Use your fingers to lift and remove the Fingerprint Reader.
      • Skip the next two steps.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Loosen the Power Button Board screw: step 22, image 1 of 1
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Power Button Board (labeled "Power Board").
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Remove the Power Button Board: step 23, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Remove the Power Button Board: step 23, image 2 of 2
      • Use your fingers to lift and remove the Power Button Board.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Loosen the Wi-Fi card screw: step 24, image 1 of 1
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi card bracket.
      • The Wi-Fi card will pop up slightly when you unfasten the bracket.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Reposition the Wi-Fi card: step 25, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Reposition the Wi-Fi card: step 25, image 2 of 2
      • Be careful not to strain the two delicate antenna cables attached to the Wi-Fi card.
      • Grab the Wi-Fi card by its edges and slide it out of its socket.
      Ask FixBot
    3. Framework Laptop 12 Mainboard Replacement: step 26, image 1 of 2 Framework Laptop 12 Mainboard Replacement: step 26, image 2 of 2
      • Carefully reposition the Wi-Fi card away from the Mainboard.
      • If the clear bracket or an antenna cable detaches from the Wi-Fi card, don't worry! You can reattach it during reassembly.
      Ask FixBot
    4. Framework Laptop 12 Mainboard Replacement, Disconnect the webcam cable: step 27, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Disconnect the webcam cable: step 27, image 2 of 2
      • Use your fingers to grab the orange tab on the webcam cable, located near the left hinge.
      • Lift straight up to disconnect the cable.
      Ask FixBot
    5. Framework Laptop 12 Mainboard Replacement, Disconnect the display cable: step 28, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Disconnect the display cable: step 28, image 2 of 2
      • Use your fingers to grab the orange tab on the display cable, located near the right hinge.
      Ask FixBot
    6. Framework Laptop 12 Mainboard Replacement, Loosen the Mainboard screws: step 29, image 1 of 1
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Mainboard.
      • These screws are also physically marked with an orange ring on the Mainboard.
      Ask FixBot
    7. Framework Laptop 12 Mainboard Replacement, Remove the Mainboard: step 30, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Remove the Mainboard: step 30, image 2 of 2
      • Make sure you've removed all Expansion Cards. Installed cards will hold the Mainboard in place.
      • Use your fingers to grab the Mainboard by its edges.
      • Lift and remove the Mainboard.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Disassembly complete: step 31, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Install the Mainboard: step 32, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Install the Mainboard: step 32, image 2 of 2
      • Carefully lay the Mainboard in the laptop.
      • Use the two alignment pins to help align the Mainboard to the laptop.
      • Be careful not to trap the webcam or display cables under the Mainboard as you set it in place.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement: step 33, image 1 of 1
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws to secure the Mainboard.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
      Ask FixBot
    3. Framework Laptop 12 Mainboard Replacement: step 34, image 1 of 2 Framework Laptop 12 Mainboard Replacement: step 34, image 2 of 2
      • Use your fingers to grab the display cable by its orange tab.
      • Align and press the display cable straight down onto its connector.
      Ask FixBot
    4. Framework Laptop 12 Mainboard Replacement: step 35, image 1 of 2 Framework Laptop 12 Mainboard Replacement: step 35, image 2 of 2
      • Use your fingers to grab the webcam cable by its orange tab.
      • Align and press the webcam cable straight down onto its connector.
      Ask FixBot
    5. Framework Laptop 12 Mainboard Replacement, Install the Wi-Fi card: step 36, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Install the Wi-Fi card: step 36, image 2 of 2
      • Use your fingers to carefully move the Wi-Fi card over the Mainboard.
      Ask FixBot
    6. Framework Laptop 12 Mainboard Replacement: step 37, image 1 of 2 Framework Laptop 12 Mainboard Replacement: step 37, image 2 of 2
      • Hold the Wi-Fi card by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the Wi-Fi card's gold contacts and notch with the socket on the Mainboard.
      • Insert the Wi-Fi card into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • If the clear Wi-Fi card bracket or antenna cables got disconnected during the repair, go to the next step. If they're still attached, skip down three steps.
      Ask FixBot
    7. Framework Laptop 12 Mainboard Replacement, Reconnect a disconnected antenna cable: step 38, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Reconnect a disconnected antenna cable: step 38, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Reconnect a disconnected antenna cable: step 38, image 3 of 3
      • Follow the next two steps if an antenna cable disconnected from the Wi-Fi card.
      • Hold the Wi-Fi card down with your finger.
      • Position the black antenna cable connector over the left Wi-Fi card's coaxial socket.
      • Tweezers can help position the connector.
      • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
      • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
      • Repeat the procedure with the white antenna cable.
      Ask FixBot
    8. Framework Laptop 12 Mainboard Replacement: step 39, image 1 of 2 Framework Laptop 12 Mainboard Replacement: step 39, image 2 of 2
      • Slide the Wi-Fi bracket over the top edge of the Wi-Fi card.
      Ask FixBot
    9. Framework Laptop 12 Mainboard Replacement, Tighten the Wi-Fi card screw: step 40, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Wi-Fi card.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Install the Fingerprint Reader: step 41, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Install the Fingerprint Reader: step 41, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Install the Fingerprint Reader: step 41, image 3 of 3
      • Use your fingers to lay the Fingerprint Reader in place.
      • Use the two plastic pins on the laptop to align the Fingerprint Reader.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement: step 42, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Fingerprint Reader.
      • Tighten the screw until it's snug. Don't over-tighten it, or you may strip the screw.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Install the Power Button Board: step 43, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Install the Power Button Board: step 43, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Install the Power Button Board: step 43, image 3 of 3
      • Use your fingers to lay the Power Button Board in place.
      • Use the two plastic pins on the laptop to align the Power Button Board.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement: step 44, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Power Button Board.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Install the Audio Board: step 45, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Install the Audio Board: step 45, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Install the Audio Board: step 45, image 3 of 3
      • Insert the Audio Board into the laptop at an angle to help align the headphone jack.
      • Use the two plastic alignment pins on the laptop to help with final alignment.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement: step 46, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Audio Board.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Install the SSD: step 47, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Install the SSD: step 47, image 2 of 2
      • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the SSD's gold contacts with its socket.
      • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement: step 48, image 1 of 3 Framework Laptop 12 Mainboard Replacement: step 48, image 2 of 3 Framework Laptop 12 Mainboard Replacement: step 48, image 3 of 3
      • Use your finger to press down on the black SSD latch to keep it open.
      • Use another finger to press the SSD down until it lays flat.
      • If the SSD doesn't fit in the latch, you may need to insert the SSD further into its socket.
      • Use your finger to close the latch to secure the SSD.
      • You should hear a click, and the SSD should no longer pop up.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Install the memory module: step 49, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Install the memory module: step 49, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Install the memory module: step 49, image 3 of 3
      • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Orient the module with the label facing down and align the gold contacts with the socket.
      • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • Press the edges of the memory module down until the side clips lock it in place.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement: step 50, image 1 of 2 Framework Laptop 12 Mainboard Replacement: step 50, image 2 of 2
      • Flip the memory flap back over the memory module.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Install the battery: step 51, image 1 of 1
      • Lay the battery in its recess in the laptop.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement: step 52, image 1 of 2 Framework Laptop 12 Mainboard Replacement: step 52, image 2 of 2
      • Use your finger to push the battery down near its connector to reconnect it.
      Ask FixBot
    3. Framework Laptop 12 Mainboard Replacement: step 53, image 1 of 1
      • Use your Framework Screwdriver to tighten the six captive T5 Torx screws to secure the battery.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Install the Input Cover: step 54, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Install the Input Cover: step 54, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Install the Input Cover: step 54, image 3 of 3
      • Angle the bottom edge of the Input Cover towards the base of the laptop.
      • Align and insert the bottom edge of the Input Cover into the base of the laptop.
      • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
      • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
      • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement: step 55, image 1 of 2 Framework Laptop 12 Mainboard Replacement: step 55, image 2 of 2
      • Close the laptop lid.
      • Flip your laptop face-down on a clean work surface.
      Ask FixBot
    3. Framework Laptop 12 Mainboard Replacement, Tighten the bottom screws: step 56, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Tighten the bottom screws: step 56, image 2 of 2
      • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
      Ask FixBot
    1. Framework Laptop 12 Mainboard Replacement, Install the Expansion Cards: step 57, image 1 of 3 Framework Laptop 12 Mainboard Replacement, Install the Expansion Cards: step 57, image 2 of 3 Framework Laptop 12 Mainboard Replacement, Install the Expansion Cards: step 57, image 3 of 3
      • Slide each Expansion Card into its Expansion Card slot.
      Ask FixBot
    2. Framework Laptop 12 Mainboard Replacement, Lock the Expansion Card slots: step 58, image 1 of 2 Framework Laptop 12 Mainboard Replacement, Lock the Expansion Card slots: step 58, image 2 of 2
      • If there's a red bar showing under either Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
      • Locking the Expansion Card slots helps keep the cards in place when you unplug cables from them.
      Ask FixBot
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Author
with
Arthur Shi
353,603 Reputation
938 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,190 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 149
All Time: 1,673
