DualSense Joystick Replacement
Views: 528K
View statistics:
Past 24 Hours:
635
Past 7 Days:
4,656
Past 30 Days:
18,533
All Time:
528,132
Comments: 136
95 comments on steps, 41 guide comments.
Go to guide comments
Completed: 145
145 people have marked this guide "completed." Will you be next?
Favorites: 46
46 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 4 hours
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace a broken or drifting joystick (aka thumbstick or analog stick) for the PlayStation DualSense controller. If you experience persistent stick drift, it's likely due to a worn out joystick module.
This repair requires intermediate soldering skills. Desoldering the joystick module is difficult, but can be done with some patience.
This guide shows you how to cut apart the joystick module so you can desolder the pieces individually with a soldering iron. The procedure will destroy the existing joystick module. If you have a hot air station, you'll have an easier time desoldering the module.
Consider replacing the drifting joystick with a TMR joystick module to fix stick wear and drift permanently.
Parts
Tools
    1. DualSense Joystick Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 DualSense Joystick Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. DualSense Joystick Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 DualSense Joystick Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 DualSense Joystick Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. DualSense Joystick Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 DualSense Joystick Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. DualSense Joystick Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 DualSense Joystick Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 DualSense Joystick Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. DualSense Joystick Replacement, Remove the middle trim: step 5, image 1 of 3 DualSense Joystick Replacement, Remove the middle trim: step 5, image 2 of 3 DualSense Joystick Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Ask FixBot
    1. DualSense Joystick Replacement, Remove the L1 button: step 6, image 1 of 3 DualSense Joystick Replacement, Remove the L1 button: step 6, image 2 of 3 DualSense Joystick Replacement, Remove the L1 button: step 6, image 3 of 3
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      Ask FixBot
    2. DualSense Joystick Replacement, Remove the R1 button: step 7, image 1 of 3 DualSense Joystick Replacement, Remove the R1 button: step 7, image 2 of 3 DualSense Joystick Replacement, Remove the R1 button: step 7, image 3 of 3
      • Repeat the previous step to remove the R1 button.
      Ask FixBot
    1. DualSense Joystick Replacement, Remove the rear case screws: step 8, image 1 of 2 DualSense Joystick Replacement, Remove the rear case screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      Ask FixBot
    2. DualSense Joystick Replacement: step 9, image 1 of 2 DualSense Joystick Replacement: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      Ask FixBot
    3. DualSense Joystick Replacement, Separate the rear case: step 10, image 1 of 3 DualSense Joystick Replacement, Separate the rear case: step 10, image 2 of 3 DualSense Joystick Replacement, Separate the rear case: step 10, image 3 of 3
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      Ask FixBot
    4. DualSense Joystick Replacement: step 11, image 1 of 3 DualSense Joystick Replacement: step 11, image 2 of 3 DualSense Joystick Replacement: step 11, image 3 of 3
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      Ask FixBot
    5. DualSense Joystick Replacement: step 12, image 1 of 3 DualSense Joystick Replacement: step 12, image 2 of 3 DualSense Joystick Replacement: step 12, image 3 of 3
      • Repeat the previous step on the right edge to release its clips.
      Ask FixBot
    6. DualSense Joystick Replacement: step 13, image 1 of 2 DualSense Joystick Replacement: step 13, image 2 of 2
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      Ask FixBot
    1. DualSense Joystick Replacement, Remove the rear case: step 14, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. DualSense Joystick Replacement, Disconnect the battery: step 15, image 1 of 2 DualSense Joystick Replacement, Disconnect the battery: step 15, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
      • Grip the connector, not the wires, when disconnecting.
      Ask FixBot
    2. DualSense Joystick Replacement, Remove the battery: step 16, image 1 of 2 DualSense Joystick Replacement, Remove the battery: step 16, image 2 of 2
      • Lift the battery straight out of the battery bracket.
      Ask FixBot
    1. DualSense Joystick Replacement, Remove the lower microphone: step 17, image 1 of 2 DualSense Joystick Replacement, Remove the lower microphone: step 17, image 2 of 2
      Buy
      • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
      Ask FixBot
    2. DualSense Joystick Replacement, Remove the battery bracket: step 18, image 1 of 2 DualSense Joystick Replacement, Remove the battery bracket: step 18, image 2 of 2
      • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
      Ask FixBot
    3. DualSense Joystick Replacement: step 19, image 1 of 2 DualSense Joystick Replacement: step 19, image 2 of 2
      • Lift the battery bracket out of the motherboard.
      Ask FixBot
    4. DualSense Joystick Replacement, Disconnect the right trigger assembly: step 20, image 1 of 2 DualSense Joystick Replacement, Disconnect the right trigger assembly: step 20, image 2 of 2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      • Do not completely remove the ribbon cable yet.
      Ask FixBot
    5. DualSense Joystick Replacement: step 21, image 1 of 2 DualSense Joystick Replacement: step 21, image 2 of 2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      • Remove the ribbon cable.
      Ask FixBot
    6. DualSense Joystick Replacement, Disconnect the left trigger assembly: step 22, image 1 of 2 DualSense Joystick Replacement, Disconnect the left trigger assembly: step 22, image 2 of 2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      Ask FixBot
    7. DualSense Joystick Replacement: step 23, image 1 of 2 DualSense Joystick Replacement: step 23, image 2 of 2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      Ask FixBot
    8. DualSense Joystick Replacement, Disconnect the upper microphone: step 24, image 1 of 2 DualSense Joystick Replacement, Disconnect the upper microphone: step 24, image 2 of 2
      • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
      Ask FixBot
    9. DualSense Joystick Replacement, Disconnect the touchpad: step 25, image 1 of 2 DualSense Joystick Replacement, Disconnect the touchpad: step 25, image 2 of 2
      • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
      Ask FixBot
    10. DualSense Joystick Replacement, Lift out the motherboard: step 26, image 1 of 3 DualSense Joystick Replacement, Lift out the motherboard: step 26, image 2 of 3 DualSense Joystick Replacement, Lift out the motherboard: step 26, image 3 of 3
      • Carefully guide the joysticks through the front case and lift the motherboard out.
      • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
      • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
      Ask FixBot
    1. DualSense Joystick Replacement, Desolder the vibration motors: step 27, image 1 of 3 DualSense Joystick Replacement, Desolder the vibration motors: step 27, image 2 of 3 DualSense Joystick Replacement, Desolder the vibration motors: step 27, image 3 of 3
      FixHub Smart Soldering Iron
      $79.95
      Buy
      • The next few steps require desoldering and soldering connections. To learn how to solder, check out our soldering guide—if you've already soldered, you can still find some helpful tips and tricks in this guide!
      • Flip over the controller and motherboard.
      • Use a soldering iron to desolder the vibration motor wires from the motherboard:
      • Two red wires
      • Two black wires
      • During reassembly, remember to solder the wires back into the same position. The red wires belong closest to the edge and next to the Rs on the motherboard.
      Ask FixBot
    2. DualSense Joystick Replacement: step 28, image 1 of 1
      • Separate the controller from the motherboard.
      Ask FixBot
    1. DualSense Joystick Replacement, Remove the joystick covers: step 29, image 1 of 3 DualSense Joystick Replacement, Remove the joystick covers: step 29, image 2 of 3 DualSense Joystick Replacement, Remove the joystick covers: step 29, image 3 of 3
      • Pull the joystick covers straight off the joystick assemblies.
      • Only the motherboard remains.
      Ask FixBot
    1. DualSense Joystick Replacement, Solder joint overview: step 30, image 1 of 3 DualSense Joystick Replacement, Solder joint overview: step 30, image 2 of 3 DualSense Joystick Replacement, Solder joint overview: step 30, image 3 of 3
      • Your DualSense motherboard may look slightly different than the images in this guide, but you can still follow the procedure to replace it.
      • Each joystick module is secured with 14 solder joints:
      • Four anchor joints
      • Six joints connecting the two potentiometers
      • Four joystick push-button joints
      • The remaining steps will show how to replace the left joystick (with the controller facing you). You can follow the same procedure to replace the right joystick.
      Ask FixBot
    2. DualSense Joystick Replacement, Prepare the potentiometers: step 31, image 1 of 3 DualSense Joystick Replacement, Prepare the potentiometers: step 31, image 2 of 3 DualSense Joystick Replacement, Prepare the potentiometers: step 31, image 3 of 3
      • Each joystick module has two potentiometers—they're the colored square blocks along two sides of the joystick.
      • Insert the tips of a pair of angled tweezers between the top edge of a potentiometer and the joystick frame.
      • Pivot the tweezers down to bend the top edge of the potentiometer away from the joystick frame.
      Ask FixBot
    3. DualSense Joystick Replacement: step 32, image 1 of 3 DualSense Joystick Replacement: step 32, image 2 of 3 DualSense Joystick Replacement: step 32, image 3 of 3
      • Repeat the procedure on the second potentiometer.
      Ask FixBot
    4. DualSense Joystick Replacement: step 33, image 1 of 2 DualSense Joystick Replacement: step 33, image 2 of 2
      • Use tweezers to remove the wiper mechanisms out of both potentiometers.
      Ask FixBot
    5. DualSense Joystick Replacement, Secure the motherboard: step 34, image 1 of 1
      Helping Hands
      $9.99
      Buy
      • Secure the motherboard with helping hands or a similar tool so that the potentiometer solder joints face up.
      • Attach clips to the clear areas on the board to prevent damaging the surface-mounted components.
      Ask FixBot
    6. DualSense Joystick Replacement, Desolder the potentiometers: step 35, image 1 of 1
      No-Clean Flux
      $4.95
      Buy
      • Apply flux to the three solder joints securing one of the potentiometers.
      • Flux improves the flow of molten solder, which makes it easier to work with. If you're having trouble with goopy or sticky solder, apply more flux.
      Ask FixBot
    7. DualSense Joystick Replacement: step 36, image 1 of 1
      • Set the soldering iron to 375–400 °C (~700–750 °F).
      • The DualSense controller has lead-free solder, which requires a higher working temperature than leaded solder.
      Ask FixBot
      • For full instructions on how to desolder through-hole solder joints, follow this guide.
      • Press the soldering iron tip against a potentiometer joint to heat it.
      • Don't heat the joint longer than 15 seconds at a time, or you risk damaging the solder pad.
      • If you're having trouble melting the solder joint, apply some leaded solder onto the soldering iron tip and try again. The leaded solder helps with heat transfer while lowering the melting temperature of the existing lead-free solder joint.
      • Once the joint's molten, use a desoldering pump to suck away the solder.
      • Repeat the heating and sucking procedure a few times on the same joint to remove as much solder as possible. Be sure not to heat the joint longer than 15 seconds at a time.
      Ask FixBot
    8. DualSense Joystick Replacement: step 38, image 1 of 1
      • Repeat the procedure on the remaining two potentiometer joints.
      Ask FixBot
    9. DualSense Joystick Replacement: step 39, image 1 of 1
      • This step shows how to remove residual solder with a solder wick. If the potentiometer feels loose, skip this step.
      • Apply flux to the solder joint.
      • Lay a piece of clean solder wick over the solder joint.
      • Press the tip of the soldering iron over the wick so that the residual solder melts and transfers into the wick.
      • Repeat the process with the remaining two solder joints.
      Ask FixBot
    10. DualSense Joystick Replacement: step 40, image 1 of 3 DualSense Joystick Replacement: step 40, image 2 of 3 DualSense Joystick Replacement: step 40, image 3 of 3
      • Use tweezers or pliers to gently pull the potentiometer away from the board.
      • If the potentiometer feels stuck, repeat the previous three steps to try to remove the residual solder holding the potentiometer in place.
      • You can also try heating each joint as you wiggle the potentiometer out of the board. This is best accomplished with help from a friend.
      Ask FixBot
    11. DualSense Joystick Replacement: step 41, image 1 of 3 DualSense Joystick Replacement: step 41, image 2 of 3 DualSense Joystick Replacement: step 41, image 3 of 3
      • Repeat the desoldering procedure to desolder and remove the second potentiometer.
      Ask FixBot
    12. DualSense Joystick Replacement, Cut apart the joystick frame: step 42, image 1 of 3 DualSense Joystick Replacement, Cut apart the joystick frame: step 42, image 2 of 3 DualSense Joystick Replacement, Cut apart the joystick frame: step 42, image 3 of 3
      • The next few steps show how to break apart and desolder the joystick frame.
      • Use flush cutters to cut the top corners of the joystick frame.
      • Be very careful not to cut yourself on the sharp edges. Bend any sharp edges down with pliers.
      Ask FixBot
    13. DualSense Joystick Replacement: step 43, image 1 of 1
      • Use pliers to bend the metal frame outwards from the module.
      Ask FixBot
    14. DualSense Joystick Replacement: step 44, image 1 of 2 DualSense Joystick Replacement: step 44, image 2 of 2
      • Remove the plastic components from the center of the joystick module.
      • Remove any loose pieces from the joystick module.
      Ask FixBot
    15. DualSense Joystick Replacement: step 45, image 1 of 2 DualSense Joystick Replacement: step 45, image 2 of 2
      • Use flush cutters to cut apart the top sections of the remaining frame walls, separating each wall into two pieces.
      Ask FixBot
    16. DualSense Joystick Replacement, Desolder the cut pins: step 46, image 1 of 3 DualSense Joystick Replacement, Desolder the cut pins: step 46, image 2 of 3 DualSense Joystick Replacement, Desolder the cut pins: step 46, image 3 of 3
      • Secure the motherboard so that the solder joints face upward.
      • Use the soldering iron to heat a solder joint securing one of the frame anchors.
      • Once the solder is molten, use pliers to grab and pull the frame anchor out of its through-hole.
      • Repeat the procedure to remove all four anchor joints.
      Ask FixBot
    17. DualSense Joystick Replacement, Remove the push-button: step 47, image 1 of 3 DualSense Joystick Replacement, Remove the push-button: step 47, image 2 of 3 DualSense Joystick Replacement, Remove the push-button: step 47, image 3 of 3
      • Slide the flat end of a spudger under the joystick module's plastic base.
      • Slowly pry up the base to bend and break it away from the motherboard.
      • Remove the plastic base.
      Ask FixBot
    18. DualSense Joystick Replacement: step 48, image 1 of 2 DualSense Joystick Replacement: step 48, image 2 of 2
      • Use flush cutters and pliers to break and remove the plastic base remnants from the push-button.
      • Use flush cutters to cut the four push-button pins securing it to the motherboard.
      Ask FixBot
    19. DualSense Joystick Replacement: step 49, image 1 of 2 DualSense Joystick Replacement: step 49, image 2 of 2
      • Remove the push-button.
      • Remove any plastic base remnants.
      Ask FixBot
    20. DualSense Joystick Replacement: step 50, image 1 of 2 DualSense Joystick Replacement: step 50, image 2 of 2
      • Use the soldering iron to heat a solder joint securing one of the push-button pins.
      • Once the solder is molten, use tweezers to grab the pin and pull it out of its through-hole.
      • Repeat the procedure to remove all four push-button pins.
      Ask FixBot
    21. DualSense Joystick Replacement, Clean up the through-holes: step 51, image 1 of 2 DualSense Joystick Replacement, Clean up the through-holes: step 51, image 2 of 2
      • Secure the motherboard so you can access both sides of it.
      • Use the soldering iron to heat one side of a through-hole.
      • Use a desoldering pump on the opposite side of the through-hole to suck up any remaining solder.
      • Don't heat the through-hole continuously for longer than 15 seconds at a time to avoid damaging the pad.
      • If needed, use solder wick to remove any residual solder.
      • Repeat this for all through-holes and both sides of the motherboard.
      Ask FixBot
    22. DualSense Joystick Replacement: step 52, image 1 of 1
      • Visually inspect each through-hole and make sure they're not blocked by residual solder. If some holes look blocked, repeat the previous step to clear the blockage.
      Ask FixBot
    23. DualSense Joystick Replacement, Clean the surface of the motherboard: step 53, image 1 of 2 DualSense Joystick Replacement, Clean the surface of the motherboard: step 53, image 2 of 2
      • Apply a few drops of high concentration (>90%) isopropyl alcohol to the top side of the motherboard, where the new joystick module will sit.
      • Use a cotton swab or a soft brush and cloth to wipe away the flux residue.
      Ask FixBot
    24. DualSense Joystick Replacement, Solder the replacement joystick: step 54, image 1 of 2 DualSense Joystick Replacement, Solder the replacement joystick: step 54, image 2 of 2
      • Place the replacement joystick module onto the motherboard so that all the pins thread through the through-holes.
      • Gently press the joystick onto the board so that the joystick sits flush with the board surface.
      Ask FixBot
    25. DualSense Joystick Replacement: step 55, image 1 of 1
      • Flip the motherboard over and secure it so that you can solder the joystick module pins.
      • Apply flux to one of the frame anchors to prep it for soldering.
      Ask FixBot
      • For full instructions on how to solder through-hole solder joints, follow this guide.
      • Solder one of the frame anchors to the motherboard.
      Ask FixBot
    26. DualSense Joystick Replacement: step 57, image 1 of 1
      • Check that the joystick module is still sitting flush on top of the motherboard (as shown). If it isn't, reheat the soldered pin and reposition the module.
      Ask FixBot
    27. DualSense Joystick Replacement: step 58, image 1 of 1
      • Solder the remaining joystick module pins (14 total) to the motherboard. Apply flux as you solder to help create good bonds.
      Ask FixBot
    28. DualSense Joystick Replacement, Clean and inspect your work: step 59, image 1 of 2 DualSense Joystick Replacement, Clean and inspect your work: step 59, image 2 of 2
      • Apply a few drops of high concentration (>90%) isopropyl alcohol to the motherboard wherever you can see flux residue.
      • Visually inspect your work:
      • Make sure each solder joint looks well-formed.
      • Make sure no solder joints are shorting each other.
      Ask FixBot
Congratulations! You've replaced the controller's joystick and, in the process, leveled up your soldering skills.
To reassemble the controller, go to this step and follow the instructions in reverse order.
You'll need to run the calibration tool to calibrate the new joystick.
145 other people completed this guide.
Arthur Shi
351,653 Reputation
937 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,895 Guides authored
41 Guide Comments
can I use Dualshock 4 joystick in the Dualsense ?
Kia - Reply Share
Yes, the joysticks are the same in both controllers.
Wes - Reply Share
How do you differentiate a real joystick part from fake ones? Since in my situation i can't order straight from sony.
TryJak - Reply Share
I would suggest getting a PS4 Dualshock controller from the classifieds since there's a pile of them available for cheap and take the analogue stick from there.
Philip Sedlmair - Reply Share
Thanks for the tutorial! I wonder if anyone has a problem after replacing the joystick? The controller simply won't turn on. If I connect the controller to either ps5 or my pc via usb, it will blink 3 times in orange and turn off. If I press the PS button when connected with usb, it will also blink orange 3 times and nothing happens. I've tried hard reset by using the hole on the back but it didn't help. Any advice??
zirimark - Reply Share
Past 24 Hours: 635
Past 7 Days: 4,656
Past 30 Days: 18,533
All Time: 528,132
