Google Stadia Controller Motherboard Replacement
    1. Google Stadia Controller Motherboard Replacement, Loosen the screw cover adhesive: step 1, image 1 of 1
      • Apply a heated iOpener to the rear side of the Stadia controller where the screw cover is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Google Stadia Controller Motherboard Replacement, Insert an opening pick: step 2, image 1 of 2 Google Stadia Controller Motherboard Replacement, Insert an opening pick: step 2, image 2 of 2
      • Insert the tip of an opening pick into the gap between the plastic screw cover and the rear case of the controller.
      Ask FixBot
    3. Google Stadia Controller Motherboard Replacement, Remove the screw cover: step 3, image 1 of 3 Google Stadia Controller Motherboard Replacement, Remove the screw cover: step 3, image 2 of 3 Google Stadia Controller Motherboard Replacement, Remove the screw cover: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Slide the opening pick along the screw cover to slice the adhesive.
      • Use a pair of tweezers or your fingers to remove the screw cover.
      • You might want to replace the screw cover adhesive during reassembly. Apply a bit of high-concentration isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the rear cover of the controller before installing new adhesive.
      Ask FixBot
    4. Google Stadia Controller Motherboard Replacement, Unfasten the rear case screw: step 4, image 1 of 1
      • Use a Torx T8 screwdriver to remove the 9.6 mm-long screw securing the rear case.
      Ask FixBot
    5. Google Stadia Controller Motherboard Replacement, Disassembly information: step 5, image 1 of 2 Google Stadia Controller Motherboard Replacement, Disassembly information: step 5, image 2 of 2
      • The front cover assembly of the Stadia controller is held in place by various tight plastic clamps. They are very hard to open and snap back in place easily.
      • The opening procedure requires some force, however, try to avoid damaging your controller case along the way.
      Ask FixBot
    6. Google Stadia Controller Motherboard Replacement, Pry open the stadia controller: step 6, image 1 of 3 Google Stadia Controller Motherboard Replacement, Pry open the stadia controller: step 6, image 2 of 3 Google Stadia Controller Motherboard Replacement, Pry open the stadia controller: step 6, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the left controller handle.
      • To make sure you insert the Jimmy at the correct position where the clamps are located, you can use this photo.
      • Tilt the Jimmy upwards and push it into the gap between the covers at the same time to pry open the plastic clamp. You should hear a clack noise once the clamp pops open.
      • Once the clamp is completely open, the gap between the two controller covers should be about 2-3 mm wide.
      Ask FixBot
    7. Google Stadia Controller Motherboard Replacement, Insert an opening pick: step 7, image 1 of 2 Google Stadia Controller Motherboard Replacement, Insert an opening pick: step 7, image 2 of 2
      • Insert an opening pick in a steep angle into the gap you created to prevent the first clamp from popping back into its closed position.
      Ask FixBot
    8. Google Stadia Controller Motherboard Replacement, Pry open the Stadia controller: step 8, image 1 of 3 Google Stadia Controller Motherboard Replacement, Pry open the Stadia controller: step 8, image 2 of 3 Google Stadia Controller Motherboard Replacement, Pry open the Stadia controller: step 8, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly at the outside of the left bottom end of the controller handle.
      • Repeat the previous opening procedure to open the three plastic clamps at the outside of the left controller handle.
      Ask FixBot
    9. Google Stadia Controller Motherboard Replacement: step 9, image 1 of 3 Google Stadia Controller Motherboard Replacement: step 9, image 2 of 3 Google Stadia Controller Motherboard Replacement: step 9, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly between the left shoulder button and the charging port at the top edge of the Stadia controller.
      • Repeat the previous procedure at the clamp between the right shoulder button and the charging port.
      Ask FixBot
    10. Google Stadia Controller Motherboard Replacement: step 10, image 1 of 3 Google Stadia Controller Motherboard Replacement: step 10, image 2 of 3 Google Stadia Controller Motherboard Replacement: step 10, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly at the right edge of the right controller handle.
      • Repeat the previous opening procedure to open the three plastic clamps at the outside of the right controller handle.
      Ask FixBot
    11. Google Stadia Controller Motherboard Replacement: step 11, image 1 of 2 Google Stadia Controller Motherboard Replacement: step 11, image 2 of 2
      • Insert a Jimmy into the gap between the front and back cover assembly at the inside of the right controller handle.
      • Repeat the previous opening procedure to open plastic clamps at the inside of the left controller handle.
      Ask FixBot
    12. Google Stadia Controller Motherboard Replacement: step 12, image 1 of 3 Google Stadia Controller Motherboard Replacement: step 12, image 2 of 3 Google Stadia Controller Motherboard Replacement: step 12, image 3 of 3
      • Insert a Jimmy into the gap between the front and back cover assembly at the bottom edge of the Stadia controller right to the headphone jack.
      • Repeat the previous procedure at the clamp left to the headphone jack.
      • Do not try to remove the front cover assembly all the way yet. It's still connected to the rear cover assembly.
      Ask FixBot
    13. Google Stadia Controller Motherboard Replacement, Unfold the front cover assembly: step 13, image 1 of 3 Google Stadia Controller Motherboard Replacement, Unfold the front cover assembly: step 13, image 2 of 3 Google Stadia Controller Motherboard Replacement, Unfold the front cover assembly: step 13, image 3 of 3
      • Avoid straining the front cover assembly cable during this step.
      • Carefully lift the front cover assembly and fold it to the left side of the Google Stadia controller.
      Ask FixBot
    1. Google Stadia Controller Motherboard Replacement, Remove the adhesive tape: step 14, image 1 of 2 Google Stadia Controller Motherboard Replacement, Remove the adhesive tape: step 14, image 2 of 2
      Buy
      • Use a pair of tweezers to peel the clear protective tape off the ZIF connector on the left side of the rear case.
      Ask FixBot
    2. Google Stadia Controller Motherboard Replacement, Open the ZIF connector: step 15, image 1 of 2 Google Stadia Controller Motherboard Replacement, Open the ZIF connector: step 15, image 2 of 2
      • Use the pointed end of a spudger to open the ZIF connector holding the button contact board cable in place.
      Ask FixBot
    3. Google Stadia Controller Motherboard Replacement, Disconnect the flex cable: step 16, image 1 of 3 Google Stadia Controller Motherboard Replacement, Disconnect the flex cable: step 16, image 2 of 3 Google Stadia Controller Motherboard Replacement, Disconnect the flex cable: step 16, image 3 of 3
      • Use a pair of tweezers to carefully disconnect the flex cable of the button unit by pulling it out of the ZIF connector in a flat angle.
      • Separate the front from the rear assembly.
      • Remove the thumbsticks by pulling them straight upwards for an easier handling in case you want to do further disassembly.
      Ask FixBot
    1. Google Stadia Controller Motherboard Replacement, Unfasten the screws: step 17, image 1 of 1
      • Use a Torx T8 screwdriver to remove the seven 9.6 mm-long screws securing the motherboard assembly.
      Ask FixBot
    2. Google Stadia Controller Motherboard Replacement, Pry up the motherboard assembly: step 18, image 1 of 2 Google Stadia Controller Motherboard Replacement, Pry up the motherboard assembly: step 18, image 2 of 2
      • The motherboard assembly is held in place at four points in the controller's rear cover.
      • Make sure to use the long and not the curved edge of the Jimmy during the following prying procedure.
      • Insert a Jimmy next to the right shoulder button and black plastic clamp of the motherboard assembly.
      • Align the long edge of the Jimmy with the corner of the black plastic clamp.
      • Pry up the motherboard assembly by tilting the Jimmy downwards to open the plastic clamp.
      Ask FixBot
    3. Google Stadia Controller Motherboard Replacement: step 19, image 1 of 2 Google Stadia Controller Motherboard Replacement: step 19, image 2 of 2
      • Insert a Jimmy next to the left shoulder button and black plastic clamp of the motherboard assembly.
      Ask FixBot
    4. Google Stadia Controller Motherboard Replacement: step 20, image 1 of 3 Google Stadia Controller Motherboard Replacement: step 20, image 2 of 3 Google Stadia Controller Motherboard Replacement: step 20, image 3 of 3
      • Insert a Jimmy at the top edge of the Google Stadia controller just above the charging port.
      • Pry up the top edge of the motherboard assembly by tilting the Jimmy downwards.
      • The charging port is clamped into an opening in the rear cover of the stadia controller. Make sure the charging port is not stuck in its recess during the prying procedure.
      • During reassembly make sure the charging port snaps back into its recess.
      Ask FixBot
    5. Google Stadia Controller Motherboard Replacement, Insert an opening pick: step 21, image 1 of 2 Google Stadia Controller Motherboard Replacement, Insert an opening pick: step 21, image 2 of 2
      • Insert an opening pick at the top edge of the Stadia controller to prevent the charging port from snapping back into place.
      Ask FixBot
    6. Google Stadia Controller Motherboard Replacement, Warning: step 22, image 1 of 2 Google Stadia Controller Motherboard Replacement, Warning: step 22, image 2 of 2
      • In the following step you'll free the headphone jack from its recess in the controller housing:
      • Avoid prying onto the black plastic cover during the following procedure.
      • Pry at the edge of the motherboard instead.
      Ask FixBot
    7. Google Stadia Controller Motherboard Replacement, Insert a Jimmy: step 23, image 1 of 2 Google Stadia Controller Motherboard Replacement, Insert a Jimmy: step 23, image 2 of 2
      • Insert a Jimmy into the gap between the rear cover and the motherboard left of the headphone jack.
      Ask FixBot
    8. Google Stadia Controller Motherboard Replacement, Pry up the motherboard assembly: step 24, image 1 of 2 Google Stadia Controller Motherboard Replacement, Pry up the motherboard assembly: step 24, image 2 of 2
      • Pry up the motherboard assembly by tilting the Jimmy downwards.
      • The headphone jack is clamped into an opening in the rear cover of the controller. Make sure the headphone jack is not stuck in its recess during the prying procedure.
      • During reassembly make sure the headphone jack snaps back into its recess.
      • Do not try to remove the motherboard assembly all the way yet. It is still connected to the rear cover by the battery cable.
      Ask FixBot
    9. Google Stadia Controller Motherboard Replacement, Lift the motherboard assembly: step 25, image 1 of 2 Google Stadia Controller Motherboard Replacement, Lift the motherboard assembly: step 25, image 2 of 2
      • Carefully lift the left edge of the motherboard assembly in order to access the battery connector.
      Ask FixBot
    10. Google Stadia Controller Motherboard Replacement, Separate the motherboard assembly: step 26, image 1 of 3 Google Stadia Controller Motherboard Replacement, Separate the motherboard assembly: step 26, image 2 of 3 Google Stadia Controller Motherboard Replacement, Separate the motherboard assembly: step 26, image 3 of 3
      Buy
      • Use a pair of tweezers to disconnect the battery cable from the motherboard.
      • Separate the rear cover from the motherboard assembly.
      Ask FixBot
    1. Google Stadia Controller Motherboard Replacement, Unfasten the screw: step 27, image 1 of 1
      • Use a T6 Torx screwdriver to remove the single 6.1 mm-long screw securing the motherboard.
      Ask FixBot
    2. Google Stadia Controller Motherboard Replacement, Free the motherboard clamps: step 28, image 1 of 3 Google Stadia Controller Motherboard Replacement, Free the motherboard clamps: step 28, image 2 of 3 Google Stadia Controller Motherboard Replacement, Free the motherboard clamps: step 28, image 3 of 3
      Buy
      • The motherboard is held onto the midframe by two tight plastic clamps which require a lot of force to press together.
      • Use a pair of tweezers to press both sides of the plastic clamp beneath the right trigger button together.
      • Slide the motherboard over the closed clamp.
      Ask FixBot
    3. Google Stadia Controller Motherboard Replacement: step 29, image 1 of 3 Google Stadia Controller Motherboard Replacement: step 29, image 2 of 3 Google Stadia Controller Motherboard Replacement: step 29, image 3 of 3
      • Use a pair of tweezers to press both sides of the plastic clamp beneath the left trigger button together.
      Ask FixBot
    4. Google Stadia Controller Motherboard Replacement, Remove the motherboard: step 30, image 1 of 2 Google Stadia Controller Motherboard Replacement, Remove the motherboard: step 30, image 2 of 2
      • Remove the motherboard.
      Ask FixBot
Dominik Schnabelrauch
264,288 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
86,005 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 65
All Time: 2,348
