Rota la impresora 90 grados a la derecha, para que el lado de panel correspondiente al panel de control esté frente a ti.
Remueve los dos tornillos Torx T10 de 12 mm del panel izquierdo.
Aparta el panel superior de la impresora.
Remueve los dos tornillos Torx T10 de 12 mm del frente superior de la impresora.
Para reensamblar tu dispositivo, sigue las instrucciones en orden inverso.
12 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
2 Comments
Thank You sooo much….Just what I needed
One of the 4 pins on this spring loaded plastic piece on the carriage farthest one to the right popped off and for some reason it raised up and was stopping the carriage from sliding left..So once I got the carriage off it dropped back down ,spring is fine so I snapped the pin back in…cool i thought it was broken…So I’ll clean it up put it back together and see what happens
Sure hope I can get those cables back in rite
I’ll let you know!!! >>—-@—->
Wpw its working
Got rid of the flashing orange light,carriage is sliding left an right ,printed a test page…WOOOHOOO!!!
Thank you all again so much
