Shop the Holiday Gift Guide
Battery Blocking
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
12
All Time:
287
Comments: 6
6 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Battery Blocking
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Tools
    1. Battery Blocking, Screen removal information: step 1, image 1 of 3 Battery Blocking, Screen removal information: step 1, image 2 of 3 Battery Blocking, Screen removal information: step 1, image 3 of 3
      • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
      • Camera module, ambient light sensors, proximity senor, and front microphone
      • Display cables
      • Screen magnets
      • LCD edges
      Ask FixBot
    2. Battery Blocking, Heat the right edge: step 2, image 1 of 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
      Ask FixBot
    3. Battery Blocking, Anti-Clamp instructions: step 3, image 1 of 3 Battery Blocking, Anti-Clamp instructions: step 3, image 2 of 3 Battery Blocking, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backward to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      Ask FixBot
    4. Battery Blocking: step 4, image 1 of 3 Battery Blocking: step 4, image 2 of 3 Battery Blocking: step 4, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    5. Battery Blocking: step 5, image 1 of 2 Battery Blocking: step 5, image 2 of 2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      Ask FixBot
    6. Battery Blocking, Insert an opening pick: step 6, image 1 of 3 Battery Blocking, Insert an opening pick: step 6, image 2 of 3 Battery Blocking, Insert an opening pick: step 6, image 3 of 3
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display.
      • Apply a suction handle to the right edge of the display, about 5 cm from the bottom edge.
      • Pull up on the suction handle with firm, constant pressure to create a gap just small enough to insert an opening pick.
      • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
      • Insert the tip of an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm or you'll damage the LCD.
      Ask FixBot
    7. Battery Blocking, Separate the right edge adhesive: step 7, image 1 of 3 Battery Blocking, Separate the right edge adhesive: step 7, image 2 of 3 Battery Blocking, Separate the right edge adhesive: step 7, image 3 of 3
      • Insert a new opening pick in the gap you just created.
      • Slide the pick along the right edge to separate the adhesive.
      • When sliding near the volume buttons, don't insert the pick more than 2 mm or you'll damage the screen magnets.
      • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    8. Battery Blocking, Heat the top edge: step 8, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      Ask FixBot
    9. Battery Blocking, Top edge information: step 9, image 1 of 3 Battery Blocking, Top edge information: step 9, image 2 of 3 Battery Blocking, Top edge information: step 9, image 3 of 3
      • The top edge of the iPad contains the camera module, two ambient light sensors, the proximity sensor, and front microphone. These components are fragile and easily damaged if an opening pick is inserted too far. Only separate the adhesive in the marked locations to avoid damage.
      • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
      • Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
      • Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
      Ask FixBot
    10. Battery Blocking, Separate the top edge adhesive: step 10, image 1 of 2 Battery Blocking, Separate the top edge adhesive: step 10, image 2 of 2
      • Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
      • Don't insert the opening pick more than 5 mm.
      • Leave the pick to the right of the sensor to prevent the adhesive from re-sealing.
      Ask FixBot
    11. Battery Blocking: step 11, image 1 of 3 Battery Blocking: step 11, image 2 of 3 Battery Blocking: step 11, image 3 of 3
      • Insert a new opening pick to the right of the ambient light sensor.
      • Slide the pick along the middle section of the top, stopping when you reach the left ambient light sensor.
      • Don't insert the pick more than 1 mm or you'll damage the proximity sensor and front microphone.
      • Leave the pick in to prevent the adhesive from re-sealing.
      Ask FixBot
    12. Battery Blocking: step 12, image 1 of 2 Battery Blocking: step 12, image 2 of 2
      • Insert a new opening pick to the left of the ambient light sensor.
      • Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
      • Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
      Ask FixBot
    13. Battery Blocking, Heat the bottom edge: step 13, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      Ask FixBot
    14. Battery Blocking, Separate the bottom edge adhesive: step 14, image 1 of 2 Battery Blocking, Separate the bottom edge adhesive: step 14, image 2 of 2
      • Insert a new opening pick in the bottom right corner below the existing pick.
      • Don't insert the opening pick more than 2 mm when sliding on the right edge.
      • Slide the pick around the bottom right corner to separate the adhesive.
      Ask FixBot
    15. Battery Blocking: step 15, image 1 of 2 Battery Blocking: step 15, image 2 of 2
      • Slide the opening pick along the bottom edge, stopping at the USB-C port.
      • Don't insert the opening pick more than 5 mm when separating the bottom edge adhesive.
      • Leave the pick in to prevent the bottom edge adhesive from re-sealing.
      Ask FixBot
    16. Battery Blocking: step 16, image 1 of 2 Battery Blocking: step 16, image 2 of 2
      • Insert a new opening pick to the left of the USB-C port.
      • Separate the remaining bottom edgeadhesive.
      • Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
      Ask FixBot
    17. Battery Blocking, Heat the left edge: step 17, image 1 of 1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      Ask FixBot
    18. Battery Blocking, Left edge information: step 18, image 1 of 3 Battery Blocking, Left edge information: step 18, image 2 of 3 Battery Blocking, Left edge information: step 18, image 3 of 3
      • The left edge of the iPad contains several display cables. These cables are extremely fragile and easily damaged if an opening pick is inserted too far or at the wrong angle. Follow the instructions exactly as written to avoid damage.
      • The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
      • There are flat sections of the frame which require an opening pick to be inserted horizontally.
      Ask FixBot
    19. Battery Blocking, Separate the left edge adhesive: step 19, image 1 of 2 Battery Blocking, Separate the left edge adhesive: step 19, image 2 of 2
      • Insert an opening pick at a 45˚ angle just above the bottom left corner.
      • Don't insert the pick more than 5 mm or you'll damage the display cables.
      • Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
      Ask FixBot
    20. Battery Blocking: step 20, image 1 of 2 Battery Blocking: step 20, image 2 of 2
      • Lower the opening pick so it is horizontal to the display.
      • Don't insert the pick more than 5 mm.
      • Continue separating the left edge adhesive until you reach the next indented section of the frame.
      Ask FixBot
    21. Battery Blocking, Separate the remaining adhesive: step 21, image 1 of 1
      • Separate the remaining adhesive, making sure to follow the instructions exactly as written.
      • Slide the pick at a 45Ëš downward angle and don't insert the pick more than 5 mm.
      • Slide the pick horizontally and don't insert the pick more than 5 mm.
      Ask FixBot
    22. Battery Blocking, Separate the screen from the frame: step 22, image 1 of 3 Battery Blocking, Separate the screen from the frame: step 22, image 2 of 3 Battery Blocking, Separate the screen from the frame: step 22, image 3 of 3
      • Grab two opposing corners of the screen and gently separate the rest of the adhesive.
      • Don't fully remove the screen as it is held in place by several ribbon cables underneath.
      • Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
      Ask FixBot
    23. Battery Blocking, Unscrew the ambient light sensor cable bracket: step 23, image 1 of 2 Battery Blocking, Unscrew the ambient light sensor cable bracket: step 23, image 2 of 2
      FixMat
      $36.95
      Buy
      • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
      • One 1.3 mm screw
      • One 2.0 mm screw
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      Ask FixBot
    24. Battery Blocking, Remove the ambient light sensor cable bracket: step 24, image 1 of 1
      Buy
      • Use a pair of tweezers or your fingers to remove the bracket.
      Ask FixBot
    25. Battery Blocking, Disconnect the ambient light sensor cable: step 25, image 1 of 2 Battery Blocking, Disconnect the ambient light sensor cable: step 25, image 2 of 2
      • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Ask FixBot
    26. Battery Blocking, Reposition the screen: step 26, image 1 of 3 Battery Blocking, Reposition the screen: step 26, image 2 of 3 Battery Blocking, Reposition the screen: step 26, image 3 of 3
      • Don't try to remove the screen yet, as it's still attached by delicate ribbon cables.
      • Grip the right edge of the screen and fold it open like a book.
      • Lay the screen down over the left edge of the iPad.
      Ask FixBot
    1. Battery Blocking, Unfasten the lower cable shield: step 27, image 1 of 2 Battery Blocking, Unfasten the lower cable shield: step 27, image 2 of 2
      • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the lower cable shield to the logic board.
      Ask FixBot
    2. Battery Blocking, Remove the lower cable shield: step 28, image 1 of 3 Battery Blocking, Remove the lower cable shield: step 28, image 2 of 3 Battery Blocking, Remove the lower cable shield: step 28, image 3 of 3
      Buy
      • Use tweezers, or your fingers, to remove the lower cable shield.
      Ask FixBot
    3. Battery Blocking, Unfasten the battery connector: step 29, image 1 of 2 Battery Blocking, Unfasten the battery connector: step 29, image 2 of 2
      • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
      Ask FixBot
    4. Battery Blocking, Battery connector information: step 30, image 1 of 3 Battery Blocking, Battery connector information: step 30, image 2 of 3 Battery Blocking, Battery connector information: step 30, image 3 of 3
      • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
      • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
      Ask FixBot
    5. Battery Blocking, Create a battery blocker: step 31, image 1 of 3 Battery Blocking, Create a battery blocker: step 31, image 2 of 3 Battery Blocking, Create a battery blocker: step 31, image 3 of 3
      • Cut two 6 mm wide strips from a playing card or cardstock to use as a battery blocker.
      • The strips should be about 4 cm long so you can easily grip them.
      Ask FixBot
    6. Battery Blocking, Insert the card strips: step 32, image 1 of 3 Battery Blocking, Insert the card strips: step 32, image 2 of 3 Battery Blocking, Insert the card strips: step 32, image 3 of 3
      • Insert the card strips on each side of the battery connector until they stop.
      Ask FixBot
Author
with
Chayton Ritter
28,391 Reputation
105 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 287
