Apple Watch Adhesive Replacement
  1. Apple Watch Adhesive Replacement, Adhesive: step 1, image 1 of 2 Apple Watch Adhesive Replacement, Adhesive: step 1, image 2 of 2
    • Use a plastic opening tool to scrape adhesive off the back of the screen.
  2. Apple Watch Adhesive Replacement: step 2, image 1 of 2 Apple Watch Adhesive Replacement: step 2, image 2 of 2
    • You may be able to peel up the adhesive with tweezers.
    • Once you have all of the pieces of adhesive removed, you may want to use an alcohol soaked q-tip to clean any residue off the back of the screen.
  3. Apple Watch Adhesive Replacement: step 3, image 1 of 2 Apple Watch Adhesive Replacement: step 3, image 2 of 2
    • Use tweezers to peel the outer ring off of one of the adhesive strip pads.
    • Be sure to get both the double-sided adhesive and the brown backing paper.
    • The double-sided adhesive adheres to each side of a thin black gasket. One side covered by brown backing paper; the other side covered by thin blue film, which is hard to see against the black gasket, but can be gently lifted up with pointy tweezers. You might find this iFixIt “Apple Watch Reassembly!” video helpful… https://youtu.be/s5-5pGfRgVc
    • Be very careful not to fold, bend, or stretch the adhesive tape, as this will make it too thick to seal the screen without a ridge between the screen and the case.
  4. Apple Watch Adhesive Replacement: step 4, image 1 of 3 Apple Watch Adhesive Replacement: step 4, image 2 of 3 Apple Watch Adhesive Replacement: step 4, image 3 of 3
    • Lay the backed adhesive tape down on the Force Touch sensor, around the edge of the case where the screen rests.
    • Start in a corner with the tape as close to the corner wall as possible.
    • Press on the brown backing paper with a plastic opening tool to secure the adhesive around the entire perimeter.
  5. Apple Watch Adhesive Replacement: step 5, image 1 of 2 Apple Watch Adhesive Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to reconnect the display data and digitizer cable connectors.
    • Be careful not to touch any of the contacts directly, as your finger oils may impede connectivity.
  6. Apple Watch Adhesive Replacement: step 6, image 1 of 3 Apple Watch Adhesive Replacement: step 6, image 2 of 3 Apple Watch Adhesive Replacement: step 6, image 3 of 3
    • To reinstall the metal bracket, line up the single tab with the slot in the top of the lower half, and slide the bracket down.
    • Snap the upper bracket in place.
  7. Apple Watch Adhesive Replacement: step 7, image 1 of 3 Apple Watch Adhesive Replacement: step 7, image 2 of 3 Apple Watch Adhesive Replacement: step 7, image 3 of 3
    • Line the battery connector up with its mate on the cable inside the watch body.
    • Use tweezers to press the two connectors together.
  8. Apple Watch Adhesive Replacement: step 8, image 1 of 3 Apple Watch Adhesive Replacement: step 8, image 2 of 3 Apple Watch Adhesive Replacement: step 8, image 3 of 3
    • If your replacement battery came with pre-installed adhesive, peel off the protective tab now, exposing the adhesive.
    • Rotate the battery down into its slot, and press it into position.
    • Press the battery down against the S1 to re-adhere it in place.
    • Now is the best time to test powering on your watch—if it doesn't turn on, double check all three connectors and try again.
  9. Apple Watch Adhesive Replacement: step 9, image 1 of 1
    • Use tweezers to peel off the adhesive backing strip.
    • Peel the backing strip up halfway, then snip it with scissors so you can peel the rest off without it snagging on the display.
  10. Apple Watch Adhesive Replacement: step 10, image 1 of 3 Apple Watch Adhesive Replacement: step 10, image 2 of 3 Apple Watch Adhesive Replacement: step 10, image 3 of 3
    • Move the screen back to the right, folding the display data and digitizer cables neatly.
    • Center the screen over the case and press it down firmly onto the adhesive.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
Andrew Optimus Goldheart
503,287 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
Past 24 Hours: 40
Past 7 Days: 378
Past 30 Days: 1,728
All Time: 329,661
