AirPods Max Battery Replacement
Views: 10K
View statistics:
Past 24 Hours:
78
Past 7 Days:
614
Past 30 Days:
2,346
All Time:
10,013
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Follow this guide to replace the battery in your AirPods Max headset, which is located in the right ear cup.
If your AirPods Max headset drains quickly, dies unexpectedly, or doesn't hold a charge, it may be time to replace the battery.
Parts
Tools
    1. AirPods Max Battery Replacement, Prepare your headset for disassembly: step 1, image 1 of 2 AirPods Max Battery Replacement, Prepare your headset for disassembly: step 1, image 2 of 2
      • Before starting your repair:
      • Unplug and remove all cables and accessories.
      • Let your AirPods Max's battery drain below 25%—a charged lithium‑ion battery may catch fire if damaged.
      • For information on how to check your AirPods Max battery status, go to this guide and scroll down to Check the charge status.
      • To help stabilize the ear cups and prevent scratching them, consider placing your AirPods Max on a soft, clean cloth.
      Ask FixBot
    1. AirPods Max Battery Replacement, Remove the right earpad: step 2, image 1 of 2 AirPods Max Battery Replacement, Remove the right earpad: step 2, image 2 of 2
      • The earpads are secured with magnets
      • Lift the right earpad (labeled R) straight up and remove it.
      Ask FixBot
    1. AirPods Max Battery Replacement, Remove the right ear cup: step 3, image 1 of 3 AirPods Max Battery Replacement, Remove the right ear cup: step 3, image 2 of 3 AirPods Max Battery Replacement, Remove the right ear cup: step 3, image 3 of 3
      • Removing the ear cup isn’t required, but can make the repair easier. You can leave the cup attached and remove it later if needed.
      • Insert a SIM eject tool, bit, or a small, straightened paperclip into the hole on the top edge of the right ear cup (labeled R).
      • Push down with your tool and pull the headband connector straight out of its socket.
      • The headband connector should slide out easily. If you're having trouble, reposition the tool and try again—you may need to angle the bit slightly.
      Ask FixBot
    1. AirPods Max Battery Replacement, Set the right ear cup down: step 4, image 1 of 1
      • Set the right ear cup down on a soft, clean cloth to prevent scratches and help stabilize the cup during your repair.
      Ask FixBot
    2. AirPods Max Battery Replacement, Turn the housing screws to the open position: step 5, image 1 of 2 AirPods Max Battery Replacement, Turn the housing screws to the open position: step 5, image 2 of 2
      • Turn these screws slowly and gently, stopping when you feel resistance—about 1/4 turn. If turned too far, the locking mechanism will break.
      • Use a P5 pentalobe screwdriver to turn (not remove) the four speaker housing screws to the unlocked position:
      • Turn the top left and bottom right screws counterclockwise.
      • Turn the top right and bottom left screws clockwise.
      Ask FixBot
    3. AirPods Max Battery Replacement, Soften the speaker housing adhesive: step 6, image 1 of 3 AirPods Max Battery Replacement, Soften the speaker housing adhesive: step 6, image 2 of 3 AirPods Max Battery Replacement, Soften the speaker housing adhesive: step 6, image 3 of 3
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • The perimeter of the speaker housing is secured to the cup with adhesive. This step shows a few methods to soften the adhesive so you can pry up the housing. If one isn't working, try a different method.
      • Option 1: Apply a few drops of high-concentration isopropyl alcohol (>90%) in the gap around the perimeter of the speaker housing. Wait one minute to allow the alcohol to soften the adhesive.
      • Option 2: Heat the speaker housing with an iOpener or hair dryer. Focus the heat around the perimeter, applying small amounts for short periods of time.
      • Don't heat the center of the speaker housing, or you'll damage the fragile mesh under the speaker cutouts and possibly the speaker.
      • For a detailed look at best practices for using a hair dryer, check out this guide.
      Ask FixBot
    4. AirPods Max Battery Replacement, Pry up the speaker housing: step 7, image 1 of 3 AirPods Max Battery Replacement, Pry up the speaker housing: step 7, image 2 of 3 AirPods Max Battery Replacement, Pry up the speaker housing: step 7, image 3 of 3
      iSesamo Opening Tool
      $10.99
      Buy
      • The gap between the speaker housing and ear cup is extremely small. You'll need a thin tool such as a metal opening pick, iSesamo, or iFlex to pry up the housing.
      • Don't grip the iFlex or similar metal tools by the edges—they're sharp and may cut you. Consider wearing gloves to protect yourself.
      • Insert the flat side of your opening tool into the gap between the left side of the speaker housing and the lip of the ear cup (opposite the R marking).
      • Pry up the speaker housing until you can grip it with your fingers, applying constant pressure to allow the adhesive to separate.
      • If the housing isn't coming up, repeat the previous step and try again. Don't try and force the housing out or you may damage it.
      Ask FixBot
    5. AirPods Max Battery Replacement: step 8, image 1 of 3 AirPods Max Battery Replacement: step 8, image 2 of 3 AirPods Max Battery Replacement: step 8, image 3 of 3
      • Don't try to fully remove the speaker housing yet—a delicate ribbon cable still connects it to the ear cup.
      • Lift the speaker housing out of the ear cup to fully separate the remaining adhesive.
      • Flip the housing over the side of the cup and prop it up so you can access the cable.
      Ask FixBot
    6. AirPods Max Battery Replacement, Remove the speaker housing cable cover: step 9, image 1 of 2 AirPods Max Battery Replacement, Remove the speaker housing cable cover: step 9, image 2 of 2
      FixMat
      $36.95
      Buy
      • Don’t let any screws snap onto the speaker driver diaphragm or they'll damage it. The screws will be drawn towards the center by the speaker's magnet.
      • Use a Torx Plus 1IP screwdriver to remove the 1.7 mm‑long screw securing the speaker housing cable cover.
      Ask FixBot
    7. AirPods Max Battery Replacement: step 10, image 1 of 2 AirPods Max Battery Replacement: step 10, image 2 of 2
      • Use tweezers to remove the cover.
      Ask FixBot
    8. AirPods Max Battery Replacement, Disconnect the speaker housing: step 11, image 1 of 2 AirPods Max Battery Replacement, Disconnect the speaker housing: step 11, image 2 of 2
      • Use a spudger to pry up and disconnect the speaker housing press connector.
      Ask FixBot
    9. AirPods Max Battery Replacement, Remove the speaker housing: step 12, image 1 of 1
      • Remove the speaker housing.
      Ask FixBot
    1. AirPods Max Battery Replacement, Remove the speaker driver screws: step 13, image 1 of 3 AirPods Max Battery Replacement, Remove the speaker driver screws: step 13, image 2 of 3 AirPods Max Battery Replacement, Remove the speaker driver screws: step 13, image 3 of 3
      • Grip the screws with tweezers while loosening and removing them. Don’t let the screws snap onto the diaphragm.
      • Use a Torx Plus 3IP screwdriver to remove three speaker driver screws:
      • Two 6.0 mm‑long screws
      • One 6.0 mm‑long screw that's slightly thicker than the other two
      • Remove the 5.1 mm‑long standoff screw using one of the two methods below:
      • Apply constant downward force to avoid damaging the screw.
      • Option 1: Stick a small flathead screwdriver into one of the four notches on top of the screw and use it to slowly turn the screw.
      • Option 2: Use a Torq-Set 6 screwdriver to remove the screw, applying constant downward force to avoid damaging the screw.
      Ask FixBot
    2. AirPods Max Battery Replacement, Remove the speaker driver: step 14, image 1 of 3 AirPods Max Battery Replacement, Remove the speaker driver: step 14, image 2 of 3 AirPods Max Battery Replacement, Remove the speaker driver: step 14, image 3 of 3
      • Lift the top edge of the speaker and remove it, being careful not to touch the diaphragm.
      • If you're having trouble, use the point of a spudger to start lifting the speaker.
      • Set the speaker aside in a place where it won't attract small metal objects.
      Ask FixBot
    1. AirPods Max Battery Replacement, Remove the battery connector cover: step 15, image 1 of 2 AirPods Max Battery Replacement, Remove the battery connector cover: step 15, image 2 of 2
      • Remove the two connector cover screws:
      • One 7.0 mm‑long Torx Plus 3IP screw
      • You may need tweezers to remove this screw.
      • One 1.7 mm‑long Torx Plus 1IP screw
      Ask FixBot
    2. AirPods Max Battery Replacement: step 16, image 1 of 3 AirPods Max Battery Replacement: step 16, image 2 of 3 AirPods Max Battery Replacement: step 16, image 3 of 3
      • Two tabs slot into place and secure the cover.
      • Slide the cover out of the slots and remove it.
      Ask FixBot
    3. AirPods Max Battery Replacement, Disconnect the battery: step 17, image 1 of 2 AirPods Max Battery Replacement, Disconnect the battery: step 17, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector (the smaller one, not the one that folds under the board).
      Ask FixBot
    4. AirPods Max Battery Replacement, Remove the battery screws: step 18, image 1 of 3 AirPods Max Battery Replacement, Remove the battery screws: step 18, image 2 of 3 AirPods Max Battery Replacement, Remove the battery screws: step 18, image 3 of 3
      Flexible Extension
      $6.99
      Buy
      • Use a Torx Plus 5IP screwdriver to remove the two screws securing the sides of the battery cells.
      • Depending on your screwdriver, you may need to use a flexible extension to get a proper fit in the screw.
      • If the screw isn't coming out once fully loosened, use tweezers to pull it out.
      Ask FixBot
    5. AirPods Max Battery Replacement: step 19, image 1 of 3 AirPods Max Battery Replacement: step 19, image 2 of 3 AirPods Max Battery Replacement: step 19, image 3 of 3
      • Use a Torx Plus 3IP screwdriver to remove the three screws securing the battery cells:
      • Two 4.0 mm‑long screws
      • One 7.0 mm‑long screw
      • Make sure you remove the correct screw (which goes through the board), and not the one just to the left of it.
      • You may need to use tweezers to remove this screw.
      Ask FixBot
    6. AirPods Max Battery Replacement, Remove the battery: step 20, image 1 of 3 AirPods Max Battery Replacement, Remove the battery: step 20, image 2 of 3 AirPods Max Battery Replacement, Remove the battery: step 20, image 3 of 3
      • Slide the battery cells out of their recesses one at a time and remove them.
      • If either of the battery cells are swollen, take appropriate precautions.
      Ask FixBot
    1. AirPods Max Battery Replacement, Disassembly complete: step 21, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your AirPods Max.
      Ask FixBot
    1. AirPods Max Battery Replacement, Slide the battery into place: step 22, image 1 of 3 AirPods Max Battery Replacement, Slide the battery into place: step 22, image 2 of 3 AirPods Max Battery Replacement, Slide the battery into place: step 22, image 3 of 3
      • With the exposed sides of the battery cells facing down, slide the battery cable under the lip of the ear cup so it sits on top of the charging port.
      • Place both battery cells into their recesses.
      Ask FixBot
    2. AirPods Max Battery Replacement, Install the battery screws: step 23, image 1 of 2 AirPods Max Battery Replacement, Install the battery screws: step 23, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to install the three screws securing the battery cells:
      Ask FixBot
    3. AirPods Max Battery Replacement: step 24, image 1 of 3 AirPods Max Battery Replacement: step 24, image 2 of 3 AirPods Max Battery Replacement: step 24, image 3 of 3
      • Use a Torx Plus 5IP screwdriver to install the two screws securing the sides of the battery cells.
      • You may need to use tweezers to slide the screws into their holes.
      Ask FixBot
    4. AirPods Max Battery Replacement, Connect the battery: step 25, image 1 of 1
      • Use a spudger or your fingers to press down and connect the battery press connector.
      Ask FixBot
    5. AirPods Max Battery Replacement, Install the battery cable cover: step 26, image 1 of 3 AirPods Max Battery Replacement, Install the battery cable cover: step 26, image 2 of 3 AirPods Max Battery Replacement, Install the battery cable cover: step 26, image 3 of 3
      • Slide the battery connector cover's two tabs into their slots and lay the cover in place.
      Ask FixBot
    6. AirPods Max Battery Replacement: step 27, image 1 of 2 AirPods Max Battery Replacement: step 27, image 2 of 2
      • Install the two connector cover screws:
      Ask FixBot
    1. AirPods Max Battery Replacement, Lay the speaker driver in place: step 28, image 1 of 3 AirPods Max Battery Replacement, Lay the speaker driver in place: step 28, image 2 of 3 AirPods Max Battery Replacement, Lay the speaker driver in place: step 28, image 3 of 3
      • Gently lay the speaker driver into place, making sure the side with gold connector pins lines up with their contacts in the shell.
      Ask FixBot
    2. AirPods Max Battery Replacement, Install the speaker driver screws: step 29, image 1 of 3 AirPods Max Battery Replacement, Install the speaker driver screws: step 29, image 2 of 3 AirPods Max Battery Replacement, Install the speaker driver screws: step 29, image 3 of 3
      • Grip the screws with tweezers while installing them so they don't snap onto the speaker.
      • Use a Torx Plus 3IP screwdriver to install three speaker driver screws:
      • Install the 5.1 mm‑long standoff screw using a small flathead or Torq-Set 6 screwdriver.
      Ask FixBot
    1. AirPods Max Battery Replacement, Replace the speaker housing adhesive: step 30, image 1 of 3 AirPods Max Battery Replacement, Replace the speaker housing adhesive: step 30, image 2 of 3 AirPods Max Battery Replacement, Replace the speaker housing adhesive: step 30, image 3 of 3
      • Before installing the speaker housing, check the condition of its adhesive—it will be on the underside of the housing, on the metal lip of the ear cup, or on both.
      • Use tweezers and scissors to remove any sections of bunched-up or overlapping adhesive that would prevent the housing from sitting perfectly flat.
      • Try to remove as little adhesive as possible. If all the adhesive looks fine, you can skip this step.
      • Apply thin, double-sided adhesive where you removed the original, using short sections to help match the curve of the lip.
      • Don't remove the top adhesive liners yet—the adhesive should not be exposed.
      • Make sure not to double up on any sections (i.e. don't apply adhesive on the ear cup if it's already on the corresponding spot on the housing).
      Ask FixBot
    2. AirPods Max Battery Replacement, Connect the speaker housing: step 31, image 1 of 2 AirPods Max Battery Replacement, Connect the speaker housing: step 31, image 2 of 2
      • Hold the speaker housing up and use your finger to press down and reconnect its press connector.
      Ask FixBot
    3. AirPods Max Battery Replacement, Install the housing cable cover: step 32, image 1 of 2 AirPods Max Battery Replacement, Install the housing cable cover: step 32, image 2 of 2
      • Slide the tab on the connector cover into its slot and lay the cover down.
      Ask FixBot
    4. AirPods Max Battery Replacement: step 33, image 1 of 2 AirPods Max Battery Replacement: step 33, image 2 of 2
      • Use a Torx Plus 1IP screwdriver to install the 1.7 mm‑long screw securing the speaker housing cable cover.
      Ask FixBot
    5. AirPods Max Battery Replacement, Secure the speaker housing: step 34, image 1 of 3 AirPods Max Battery Replacement, Secure the speaker housing: step 34, image 2 of 3 AirPods Max Battery Replacement, Secure the speaker housing: step 34, image 3 of 3
      • If you installed replacement adhesive, remove any liners to expose the adhesive.
      • Flip the speaker housing into the cup and press it into place around the perimeter.
      • Don't press on the center of the housing or you may damage the grille and/or speaker underneath.
      Ask FixBot
    6. AirPods Max Battery Replacement, Turn the housing screws to the locked position: step 35, image 1 of 2 AirPods Max Battery Replacement, Turn the housing screws to the locked position: step 35, image 2 of 2
      • Use a P5 pentalobe screwdriver to turn the four speaker housing screws to the locked position:
      • Turn the top left and bottom right screws clockwise.
      • Turn the top right and bottom left screws counterclockwise.
      Ask FixBot
    1. AirPods Max Battery Replacement, Install the right ear cup: step 36, image 1 of 3 AirPods Max Battery Replacement, Install the right ear cup: step 36, image 2 of 3 AirPods Max Battery Replacement, Install the right ear cup: step 36, image 3 of 3
      • The headband and ear cup should be oriented in the "closed" position (how they would be when stored in a case) when installing them.
      • Hold the ear cup steady with one hand, and use your free hand to firmly push the headband connector into its slot, twisting it slightly—it should click into place.
      • The connector should slide in easily. If it's not, make sure you're installing the ear cup on the correct side.
      Ask FixBot
    1. AirPods Max Battery Replacement, Install the right earpad: step 37, image 1 of 2 AirPods Max Battery Replacement, Install the right earpad: step 37, image 2 of 2
      • Place the earpad into its cup—it should "snap" into place.
      Ask FixBot
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed battery after completing this guide.
2 other people completed this guide.
Spencer Day
206,558 Reputation
1,266 Guides authored
1 Guide Comment
Is there a difference between approach in Gen 1 (lightning) and Gen 2 (Usb C)? Is the battery the same?
Kristoffer Seyffarth - Reply Share
Past 24 Hours: 78
Past 7 Days: 614
Past 30 Days: 2,346
All Time: 10,013
