iPhone 16 Pro Charging Port Replacement
  1. iPhone 16 Pro Charging Port Replacement, Prepare the phone for disassembly: step 1, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Prepare the phone for disassembly: step 1, image 2 of 2
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
    Ask FixBot
  2. iPhone 16 Pro Charging Port Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Tape over any cracks: step 2, image 2 of 2
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Ask FixBot
  3. iPhone 16 Pro Charging Port Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  4. iPhone 16 Pro Charging Port Replacement, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Remove the pentalobe screws: step 4, image 2 of 2
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
    Ask FixBot
  5. iPhone 16 Pro Charging Port Replacement, Heat the bottom edge: step 5, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Heat the bottom edge: step 5, image 2 of 2
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Ask FixBot
  6. iPhone 16 Pro Charging Port Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  7. iPhone 16 Pro Charging Port Replacement, Back glass information: step 7, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Back glass information: step 7, image 2 of 2
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
    Ask FixBot
  8. iPhone 16 Pro Charging Port Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contact.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
    Ask FixBot
  9. iPhone 16 Pro Charging Port Replacement, Heat the right edge: step 9, image 1 of 1
    • Heat the right edge of the back glass until it's hot to the touch.
    Ask FixBot
  10. iPhone 16 Pro Charging Port Replacement, Separate the bottom right corner adhesive: step 10, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Separate the bottom right corner adhesive: step 10, image 2 of 2
    • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
    Ask FixBot
  11. iPhone 16 Pro Charging Port Replacement, Heat the left edge: step 11, image 1 of 1
    • Heat the left edge of the back glass until it's hot to the touch.
    Ask FixBot
  12. iPhone 16 Pro Charging Port Replacement, Separate the left edge adhesive: step 12, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Separate the left edge adhesive: step 12, image 2 of 2
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
    Ask FixBot
  13. iPhone 16 Pro Charging Port Replacement, Heat the top edge: step 13, image 1 of 1
    • Heat the top edge of the back glass, including the area around the volume buttons, until it's hot to the touch.
    Ask FixBot
  14. iPhone 16 Pro Charging Port Replacement, Separate the top edge adhesive: step 14, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Separate the top edge adhesive: step 14, image 2 of 2
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You'll hear and feel clicks as the top two clips release.
    Ask FixBot
  15. iPhone 16 Pro Charging Port Replacement, Swing open the back glass: step 15, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Swing open the back glass: step 15, image 2 of 2
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
    • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
    Ask FixBot
  16. iPhone 16 Pro Charging Port Replacement, Disconnect the battery: step 16, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Disconnect the battery: step 16, image 2 of 2
    • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
    • Two 1.2 mm‑long screws
    • One 1.0 mm‑long screw
    Ask FixBot
  17. iPhone 16 Pro Charging Port Replacement: step 17, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 17, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 17, image 3 of 3
    • Use tweezers or your fingers to pick up and remove the lower connector cover.
    Ask FixBot
  18. iPhone 16 Pro Charging Port Replacement: step 18, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 18, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 18, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    Ask FixBot
  19. iPhone 16 Pro Charging Port Replacement, Disconnect the back glass: step 19, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Disconnect the back glass: step 19, image 2 of 2
    • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
    • Two 1.0 mm‑long screws
    • One 1.2 mm‑long screw
    • One 1.6 mm‑long screw
    Ask FixBot
  20. iPhone 16 Pro Charging Port Replacement: step 20, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 20, image 2 of 2
    • Use tweezers or your fingers to pick up and remove the upper connector cover.
    Ask FixBot
  21. iPhone 16 Pro Charging Port Replacement: step 21, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 21, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the back glass press connector.
    Ask FixBot
  22. iPhone 16 Pro Charging Port Replacement, Remove the back glass: step 22, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Remove the back glass: step 22, image 2 of 2
    • Lift the back glass off the frame and remove it.
    Ask FixBot
  23. iPhone 16 Pro Charging Port Replacement, Remove the Taptic Engine cover: step 23, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Remove the Taptic Engine cover: step 23, image 2 of 2
    • Use a Phillips screwdriver to remove the three screws securing the Taptic Engine cover:
    • One 3.0 mm‑long screw
    • Two 1.7 mm‑long screws
    Ask FixBot
  24. iPhone 16 Pro Charging Port Replacement: step 24, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 24, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 24, image 3 of 3
    • Use tweezers or your fingers to lift the top edge of the Taptic Engine cover.
    • Once the bottom edge unlatches from the frame, remove the Taptic Engine cover.
    Ask FixBot
  25. iPhone 16 Pro Charging Port Replacement, Disconnect the lower assembly cable: step 25, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Disconnect the lower assembly cable: step 25, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the lower assembly cable press connector from the logic board.
    Ask FixBot
  26. iPhone 16 Pro Charging Port Replacement: step 26, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 26, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 26, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the two press connectors near the bottom right edge of the frame.
    Ask FixBot
  27. iPhone 16 Pro Charging Port Replacement: step 27, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 27, image 2 of 2
    • Use a tri-point Y000 screwdriver to remove the 1.0 mm‑long screw securing the lower assembly cable.
    Ask FixBot
  28. iPhone 16 Pro Charging Port Replacement: step 28, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 28, image 2 of 2
    • Use an iOpener or hair dryer to heat up the lower assembly cable section on top of the Taptic Engine until it's hot to the touch.
    Ask FixBot
  29. iPhone 16 Pro Charging Port Replacement: step 29, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 29, image 2 of 2
    • Slide an opening pick under the lower assembly cable to separate it from the Taptic Engine.
    • Carefully bend the cable out of the way so you can access the Taptic Engine.
    Ask FixBot
  30. iPhone 16 Pro Charging Port Replacement, Remove the Taptic Engine: step 30, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Remove the Taptic Engine: step 30, image 2 of 2
    • Use a Phillips screwdriver to remove the 1.9 mm‑long screw securing the Taptic Engine.
    Ask FixBot
  31. iPhone 16 Pro Charging Port Replacement: step 31, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 31, image 2 of 2
    • Slide the tip of an opening pick along the top edge of the Taptic Engine to separate the plastic buffer strip adhered to it.
    Ask FixBot
  32. iPhone 16 Pro Charging Port Replacement: step 32, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 32, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 32, image 3 of 3
    • Use the point of a spudger to pry up the Taptic Engine from its top-right corner.
    • Be careful not to pry against the battery.
    • Remove the Taptic Engine.
    Ask FixBot
  33. iPhone 16 Pro Charging Port Replacement, Remove the loudspeaker: step 33, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Remove the loudspeaker: step 33, image 2 of 2
    • Remove the four screws securing the loudspeaker:
    • Two 1.6 mm‑long Phillips screws
    • One 2.0 mm‑long Phillips screw
    • One 1.3 mm‑long tri-point Y000 screw
    Ask FixBot
  34. iPhone 16 Pro Charging Port Replacement: step 34, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 34, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 34, image 3 of 3
    • Insert the point of a spudger underneath the loudspeaker's bottom-right screw hole.
    • Pry up and remove the loudspeaker.
    Ask FixBot
  35. iPhone 16 Pro Charging Port Replacement, Battery adhesive information: step 35, image 1 of 1
    • The battery is secured with three stretch release adhesive strips. The next four steps show how to remove them and free the battery.
    • Be careful not to dent or puncture the battery. Even with its metal enclosure, the battery can catch fire if damaged.
    Ask FixBot
  36. iPhone 16 Pro Charging Port Replacement, Remove the battery: step 36, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Remove the battery: step 36, image 2 of 2
    • Insert the tip of angled tweezers under one of the black pull tabs.
    Ask FixBot
  37. iPhone 16 Pro Charging Port Replacement: step 37, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 37, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 37, image 3 of 3
    • Use your tweezers to slice through the black tab and peel the tab off the top of the battery.
    • Don't try to pull the tab out from under the battery just yet.
    Ask FixBot
  38. iPhone 16 Pro Charging Port Replacement: step 38, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 38, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 38, image 3 of 3
    • Use tweezers or your fingers to grab the pull tab and pull it down so it's flat against the frame.
    • Slowly pull the adhesive out from under the battery at as low of an angle as possible.
    • Give the strip plenty of time to stretch and re-grip it as necessary. When the strip becomes too long, wrap it around your tweezers and continue pulling.
    • If the strip breaks off, try to retrieve it from under the battery. If you can't retrieve it, move onto the next strip.
    Ask FixBot
  39. iPhone 16 Pro Charging Port Replacement: step 39, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 39, image 2 of 2
    • Repeat the procedure with the two remaining adhesive strips.
    • Carefully bend the lower assembly cable out of the way as needed to access the adhesive strips.
    Ask FixBot
  40. iPhone 16 Pro Charging Port Replacement: step 40, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 40, image 2 of 2
    • If you removed all three stretch release adhesive strips, congratulations! Lift and remove the battery.
    • If one or more adhesive strips broke, skip to the next step to remove them with isopropyl alcohol.
    Ask FixBot
  41. iPhone 16 Pro Charging Port Replacement, Alternate method to remove the battery: step 41, image 1 of 1
    • The next two steps show how to remove the battery if the adhesive strips broke.
    • Lift the bottom edge of the frame to tilt the phone.
    • Use a pipette or a syringe to apply 2–3 drops of high concentration (>90%) isopropyl alcohol along the bottom edge of the battery, close to where each broken adhesive strip came out.
    • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
    Ask FixBot
  42. iPhone 16 Pro Charging Port Replacement: step 42, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 42, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 42, image 3 of 3
    • Insert the tip of an opening pick between the bottom of the battery and the frame.
    • Insert a second opening pick between the left edge of the battery and the frame. Use this pick to pry the battery upwards slowly with steady force. Work your way up the edge of the battery, giving the adhesive time to release.
    • Don't bend or crease the battery. If it feels stubborn, apply a few more drops of isopropyl alcohol and try again.
    • Once the adhesive loosens, grab and remove the battery.
    Ask FixBot
  43. iPhone 16 Pro Charging Port Replacement, Remove the charging port: step 43, image 1 of 1
    • Use a standoff screwdriver to remove the 3.6 mm‑long screw securing the charging port to the frame.
    Ask FixBot
  44. iPhone 16 Pro Charging Port Replacement: step 44, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 44, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 44, image 3 of 3
    • Use a Phillips screwdriver to remove the two 3.4 mm‑long screws securing the charging port to the frame.
    • These screws are tight and can be difficult to reach. Angle your screwdriver at as shallow of an angle as you can.
    Ask FixBot
  45. iPhone 16 Pro Charging Port Replacement: step 45, image 1 of 1
    • Use a tri-point Y000 screwdriver to remove the 1.3 mm‑long screw securing the charging port to the frame.
    Ask FixBot
  46. iPhone 16 Pro Charging Port Replacement: step 46, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 46, image 2 of 2
    • The charging port has an adhesive gasket that seals it against the bottom and edge of the frame. It's also tucked behind two prongs, which prevents you from pulling the port away from the frame.
    • Insert the point of a spudger under one side of the charging port.
    • Pry up gently to separate the gasket and lift the port up.
    Ask FixBot
  47. iPhone 16 Pro Charging Port Replacement: step 47, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 47, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 47, image 3 of 3
    • Don't pull the port directly away from its cut-out in the frame. There are two prongs holding it in place.
    • Pull the charging port away from the microphone.
    • Remove the charging port.
    Ask FixBot
  48. iPhone 16 Pro Charging Port Replacement, Disassembly complete: step 48, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone. Some of the reassembly photos show the Pro Max model, but the procedure is correct for the Pro.
    Ask FixBot
  49. iPhone 16 Pro Charging Port Replacement, Reassembly tips: step 49, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Reassembly tips: step 49, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Reassembly tips: step 49, image 3 of 3
    • Grounding clips clip on top of both screw posts under the charging port. Make sure they're still clipped in place. The clips should face towards the bottom edge of the iPhone.
    • Make sure the two black prongs on either side of the charging port are standing straight up. If they were bent when you removed the port, use the point of a spudger to carefully straighten them.
    • If you have replacement adhesive, use tweezers to remove all of the original adhesive securing the port to the frame before installing it.
    • If you don't have new adhesive, you can leave the old adhesive in place, but the phone will no longer be water-resistant.
    Ask FixBot
  50. iPhone 16 Pro Charging Port Replacement, Install the charging port: step 50, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Install the charging port: step 50, image 2 of 2
    • Slide the charging port in place so its screw posts sit between the black prongs and the bottom of the frame.
    • Slide the charging port screw tabs on the cable-side of the port between the screw posts and the screw tabs on the microphone.
    Ask FixBot
  51. iPhone 16 Pro Charging Port Replacement: step 51, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 51, image 2 of 2
    • Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the charging port from outside the phone.
    • Ensure the two screws are sticking through the holes in the black prongs. This will help align the port with the frame.
    Ask FixBot
  52. iPhone 16 Pro Charging Port Replacement: step 52, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 52, image 2 of 2
    • Use a tri-point Y000 screwdriver to install the 1.3 mm‑long screw in the bottom-right corner of the charging port to secure it to the frame.
    Ask FixBot
  53. iPhone 16 Pro Charging Port Replacement: step 53, image 1 of 1
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the charging port from outside the phone.
    Ask FixBot
  54. iPhone 16 Pro Charging Port Replacement: step 54, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 54, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 54, image 3 of 3
    • Use a Phillips screwdriver to install the two 3.4 mm‑long screws securing the charging port to the frame.
    • These screws are tight and can be difficult to reach. Angle your screwdriver at as shallow of an angle as you can to avoid stripping them.
    Ask FixBot
  55. iPhone 16 Pro Charging Port Replacement: step 55, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 55, image 2 of 2
    • Use a standoff screwdriver to install the 3.6 mm‑long screw securing the charging port and microphone to the frame.
    Ask FixBot
  56. iPhone 16 Pro Charging Port Replacement, Clean the frame: step 56, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Clean the frame: step 56, image 2 of 2
    • Remove any remaining adhesive from the battery recess.
    • Wipe the frame surface with a lint-free cloth and a few drops of isopropyl alcohol. Wait for the alcohol to fully evaporate before installing the new battery.
    • Before removing any liners on the adhesive, place the battery in its recess to check that it fits and that its cable reaches its socket on the logic board. Don't connect the battery yet!
    Ask FixBot
  57. iPhone 16 Pro Charging Port Replacement, Install new adhesive: step 57, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Install new adhesive: step 57, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Install new adhesive: step 57, image 3 of 3
    Tool used on this step:
    Stretch Release Battery Adhesive
    $3.99
    Buy
    • The next four steps show how to apply custom-cut adhesive to the battery. If your battery comes with adhesive pre-installed, skip the next four steps.
    • If needed, follow this guide to apply generic stretch release adhesive strips instead. Ensure the position of these strips lines up with the adhesive wells in the phone's frame. Use this photo as a reference.
    • Align the new adhesive with your battery to see how it needs to be applied. Set all strips fully on the battery, and align the top edges of the black pull tabs with the bottom edge of the battery.
    • Your adhesive may look slightly different or have different liners.
    • If the battery‑side of your adhesive has two liners, remove the top liner.
    • If the battery‑side of your adhesive has one liner, remove it.
    Ask FixBot
  58. iPhone 16 Pro Charging Port Replacement: step 58, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 58, image 2 of 2
    • Lay the adhesive onto the battery and press each strip firmly into place.
    Ask FixBot
  59. iPhone 16 Pro Charging Port Replacement: step 59, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 59, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 59, image 3 of 3
    • If the battery‑side of your adhesive still has a bottom liner on it, remove it now, and press each strip firmly into place.
    Ask FixBot
  60. iPhone 16 Pro Charging Port Replacement: step 60, image 1 of 1
    • Use your finger to fold each black pull tab around the bottom edge of the battery and press it into place.
    Ask FixBot
  61. iPhone 16 Pro Charging Port Replacement, Remove the adhesive film: step 61, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Remove the adhesive film: step 61, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Remove the adhesive film: step 61, image 3 of 3
    • Remove the iPhone‑side liner off of the battery adhesive.
    Ask FixBot
  62. iPhone 16 Pro Charging Port Replacement, Align the battery: step 62, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Align the battery: step 62, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Align the battery: step 62, image 3 of 3
    • The battery adhesive is very sticky! Be careful as you align the battery in its recess—once it sticks, you won't be able to realign it.
    • Lower the battery partially into its recess, making sure the adhesive doesn't touch the frame.
    • Use a spudger or your finger to connect the battery cable's press connector to ensure that the cable reaches.
    Ask FixBot
  63. iPhone 16 Pro Charging Port Replacement, Install the battery: step 63, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Install the battery: step 63, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Install the battery: step 63, image 3 of 3
    • Push the battery towards the top of the iPhone, and lay it in its recess.
    • Use your fingers to press firmly against the battery for ten seconds to bond it to the frame.
    • Use a spudger or your finger to disconnect the battery from the logic board.
    Ask FixBot
  64. iPhone 16 Pro Charging Port Replacement, Transfer the battery shim: step 64, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Transfer the battery shim: step 64, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Transfer the battery shim: step 64, image 3 of 3
    • If the black plastic shim beneath the battery didn't come out with the loudspeaker, skip this step.
    • Align the battery shim so it's flush with the new loudspeaker's left edge and underside. Press it onto the loudspeaker to adhere it.
    • If the shim isn't sticky, set it into the phone alongside the loudspeaker in the next step.
    Ask FixBot
  65. iPhone 16 Pro Charging Port Replacement, Install the loudspeaker: step 65, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Install the loudspeaker: step 65, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Install the loudspeaker: step 65, image 3 of 3
    • Align the bottom edge of the loudspeaker with the frame.
    • Set the loudspeaker into its recess.
    Ask FixBot
  66. iPhone 16 Pro Charging Port Replacement: step 66, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 66, image 2 of 2
    • Install the four screws securing the loudspeaker:
    Ask FixBot
  67. iPhone 16 Pro Charging Port Replacement, Install the Taptic Engine: step 67, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Install the Taptic Engine: step 67, image 2 of 2
    • Use blunt-nose tweezers or your fingers to align the Taptic Engine with its screw posts and place it in the frame.
    Ask FixBot
  68. iPhone 16 Pro Charging Port Replacement: step 68, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 68, image 2 of 2
    • Use a Phillips screwdriver to install the 1.9 mm‑long screw securing the Taptic Engine, located on its right edge.
    Ask FixBot
  69. iPhone 16 Pro Charging Port Replacement, Connect the lower assembly cable: step 69, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Connect the lower assembly cable: step 69, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Connect the lower assembly cable: step 69, image 3 of 3
    • Use your finger or a spudger to connect the two lower assembly press connectors.
    • These press connectors can be tricky. Align each connector over its socket and press down—first on one side, then the other—until it clicks into place. Don't try to force them. If you're having trouble, reposition them and try again.
    Ask FixBot
  70. iPhone 16 Pro Charging Port Replacement: step 70, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 70, image 2 of 2
    • Use a tri-point Y000 screwdriver to install the 1.0 mm‑long screw securing the lower assembly cable.
    Ask FixBot
  71. iPhone 16 Pro Charging Port Replacement: step 71, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 71, image 2 of 2
    • Use your finger or a spudger to connect the lower assembly cable press connector, located in the bottom-right corner of the logic board.
    Ask FixBot
  72. iPhone 16 Pro Charging Port Replacement, Install the Taptic Engine cover: step 72, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Install the Taptic Engine cover: step 72, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Install the Taptic Engine cover: step 72, image 3 of 3
    Ask FixBot
  73. iPhone 16 Pro Charging Port Replacement: step 73, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 73, image 2 of 2
    • Use a Phillips screwdriver to install the three screws securing the Taptic Engine cover:
    Ask FixBot
  74. iPhone 16 Pro Charging Port Replacement, Remove the leftover adhesive: step 74, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Remove the leftover adhesive: step 74, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Remove the leftover adhesive: step 74, image 3 of 3
    Buy
    • Work around the fragile grounding clips as you're cleaning the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
    • Use a spudger to scrape the adhesive residue off of the frame.
    • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
    Ask FixBot
  75. iPhone 16 Pro Charging Port Replacement, Clean the back glass: step 75, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Clean the back glass: step 75, image 2 of 2
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
    Ask FixBot
  76. iPhone 16 Pro Charging Port Replacement, Clean the frame: step 76, image 1 of 1
    • Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
    Ask FixBot
  77. iPhone 16 Pro Charging Port Replacement, Apply the replacement adhesive: step 77, image 1 of 1
    • Lay the adhesive sheet over the frame to determine its proper orientation.
    • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
    Ask FixBot
  78. iPhone 16 Pro Charging Port Replacement: step 78, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 78, image 2 of 2
    • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
    • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
    Ask FixBot
  79. iPhone 16 Pro Charging Port Replacement: step 79, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 79, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 79, image 3 of 3
    • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
    Ask FixBot
  80. iPhone 16 Pro Charging Port Replacement: step 80, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 80, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 80, image 3 of 3
    • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
    • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
    • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
    • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
    Ask FixBot
  81. iPhone 16 Pro Charging Port Replacement: step 81, image 1 of 2 iPhone 16 Pro Charging Port Replacement: step 81, image 2 of 2
    • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
    • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Don't press too hard, or you'll stretch and deform the adhesive.
    Ask FixBot
  82. iPhone 16 Pro Charging Port Replacement: step 82, image 1 of 3 iPhone 16 Pro Charging Port Replacement: step 82, image 2 of 3 iPhone 16 Pro Charging Port Replacement: step 82, image 3 of 3
    • Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
    • Use the pull tab to peel off the large front liner from the adhesive.
    • At this point, you may still have a liner covering the perimeter, which prevents the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
    Ask FixBot
  83. iPhone 16 Pro Charging Port Replacement, Connect the back glass: step 83, image 1 of 1
    • Prop up the back glass along the right edge of your iPhone.
    Ask FixBot
  84. iPhone 16 Pro Charging Port Replacement: step 84, image 1 of 1
    • Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
    Ask FixBot
  85. iPhone 16 Pro Charging Port Replacement, Connect the battery: step 85, image 1 of 1
    • Use your finger or a spudger to press and connect the battery press connector onto the logic board.
    • This is a good point to test your repair before sealing up your iPhone. Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
    • If your iPhone doesn't turn on, connect it to a power source and try again.
    • If you've replaced the logic board and the screen fails to turn on, you'll need to follow the screen guide to manually connect the display connector.
    Ask FixBot
  86. iPhone 16 Pro Charging Port Replacement, Install the connector covers: step 86, image 1 of 1
    • Align the back glass connector cover by its screw holes and lay it in place.
    Ask FixBot
  87. iPhone 16 Pro Charging Port Replacement: step 87, image 1 of 1
    • Use a tri-point Y000 driver to install the four screws securing the back glass connector cover:
    • Two 1.3 mm‑long screws
    Ask FixBot
  88. iPhone 16 Pro Charging Port Replacement: step 88, image 1 of 1
    • Align the battery connector cover by its screw holes and lay it in place.
    Ask FixBot
  89. iPhone 16 Pro Charging Port Replacement: step 89, image 1 of 1
    • Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
    Ask FixBot
  90. iPhone 16 Pro Charging Port Replacement, Remove the final adhesive liners: step 90, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Remove the final adhesive liners: step 90, image 2 of 2
    • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
    • As you remove the liners, make sure nothing touches the exposed adhesive.
    • Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
    Ask FixBot
  91. iPhone 16 Pro Charging Port Replacement, Install the back glass: step 91, image 1 of 3 iPhone 16 Pro Charging Port Replacement, Install the back glass: step 91, image 2 of 3 iPhone 16 Pro Charging Port Replacement, Install the back glass: step 91, image 3 of 3
    • Lower the back glass onto the frame, beginning with the top edge.
    • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
    • Press along the edges of the iPhone until the back glass sits flush against the frame.
    Ask FixBot
  92. iPhone 16 Pro Charging Port Replacement, Apply heat to the perimeter: step 92, image 1 of 1
    • Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
    • The heat softens the adhesive and helps create a better bond.
    Ask FixBot
  93. iPhone 16 Pro Charging Port Replacement, Install the pentalobe screws: step 93, image 1 of 2 iPhone 16 Pro Charging Port Replacement, Install the pentalobe screws: step 93, image 2 of 2
    • Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the USB-C port.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
5 other people completed this guide.
Nick Schultz
56,893 Reputation
321 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
0 Guide Comments
Past 24 Hours: 32
Past 7 Days: 281
Past 30 Days: 1,234
All Time: 9,780
