iPhone 16 Microphone Replacement
  1. iPhone 16 Microphone Replacement, Before you begin: step 1, image 1 of 2 iPhone 16 Microphone Replacement, Before you begin: step 1, image 2 of 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Ask FixBot
  2. iPhone 16 Microphone Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Microphone Replacement, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Ask FixBot
  3. iPhone 16 Microphone Replacement, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 16 Microphone Replacement, Remove the pentalobe screws: step 3, image 2 of 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
    Ask FixBot
  4. iPhone 16 Microphone Replacement, Mark your opening picks: step 4, image 1 of 3 iPhone 16 Microphone Replacement, Mark your opening picks: step 4, image 2 of 3 iPhone 16 Microphone Replacement, Mark your opening picks: step 4, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  5. iPhone 16 Microphone Replacement, Heat the bottom edge: step 5, image 1 of 1
    Tool used on this step:
    iOpener
    $14.95
    Buy
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
    Ask FixBot
  6. iPhone 16 Microphone Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 16 Microphone Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 16 Microphone Replacement, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction handle to the bottom edge of the back glass.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  7. iPhone 16 Microphone Replacement, Back glass information: step 7, image 1 of 1
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the phone.
    Ask FixBot
  8. iPhone 16 Microphone Replacement, Heat the right edge: step 8, image 1 of 1
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
    Ask FixBot
  9. iPhone 16 Microphone Replacement, Separate the bottom right adhesive: step 9, image 1 of 3 iPhone 16 Microphone Replacement, Separate the bottom right adhesive: step 9, image 2 of 3 iPhone 16 Microphone Replacement, Separate the bottom right adhesive: step 9, image 3 of 3
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
    • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
    • You'll hear and feel the metal clip release as you pass it.
    • Leave this pick inserted to prevent the adhesive from resealing.
    Ask FixBot
  10. iPhone 16 Microphone Replacement, Heat the left edge: step 10, image 1 of 1
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
    Ask FixBot
  11. iPhone 16 Microphone Replacement, Separate the left adhesive: step 11, image 1 of 3 iPhone 16 Microphone Replacement, Separate the left adhesive: step 11, image 2 of 3 iPhone 16 Microphone Replacement, Separate the left adhesive: step 11, image 3 of 3
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
    Ask FixBot
  12. iPhone 16 Microphone Replacement, Heat the top edge: step 12, image 1 of 1
    • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
    Ask FixBot
  13. iPhone 16 Microphone Replacement, Separate the top right adhesive: step 13, image 1 of 3 iPhone 16 Microphone Replacement, Separate the top right adhesive: step 13, image 2 of 3 iPhone 16 Microphone Replacement, Separate the top right adhesive: step 13, image 3 of 3
    • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
    • Continue sliding your pick around the top right corner until you reach the Action button.
    Ask FixBot
  14. iPhone 16 Microphone Replacement, Reposition the back glass: step 14, image 1 of 3 iPhone 16 Microphone Replacement, Reposition the back glass: step 14, image 2 of 3 iPhone 16 Microphone Replacement, Reposition the back glass: step 14, image 3 of 3
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the phone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
    • Remove the opening picks before continuing.
    Ask FixBot
  15. iPhone 16 Microphone Replacement, Remove the middle connector cover screws: step 15, image 1 of 2 iPhone 16 Microphone Replacement, Remove the middle connector cover screws: step 15, image 2 of 2
    • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
    Ask FixBot
  16. iPhone 16 Microphone Replacement, Remove the middle connector cover: step 16, image 1 of 3 iPhone 16 Microphone Replacement, Remove the middle connector cover: step 16, image 2 of 3 iPhone 16 Microphone Replacement, Remove the middle connector cover: step 16, image 3 of 3
    • Insert the point of a spudger in either cutout on the middle connector cover.
    • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
    Ask FixBot
  17. iPhone 16 Microphone Replacement, Disconnect the battery: step 17, image 1 of 2 iPhone 16 Microphone Replacement, Disconnect the battery: step 17, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    Ask FixBot
  18. iPhone 16 Microphone Replacement, Disconnect the wireless charging coil: step 18, image 1 of 2 iPhone 16 Microphone Replacement, Disconnect the wireless charging coil: step 18, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
    Ask FixBot
  19. iPhone 16 Microphone Replacement, Remove the back glass: step 19, image 1 of 1
    • Lift the back glass off the frame and remove it.
    Ask FixBot
  20. iPhone 16 Microphone Replacement, Remove the Taptic Engine bracket screws: step 20, image 1 of 2 iPhone 16 Microphone Replacement, Remove the Taptic Engine bracket screws: step 20, image 2 of 2
    • Use a Phillips screwdriver to remove the two 1.8 mm‑long screws securing the Taptic Engine bracket.
    Ask FixBot
  21. iPhone 16 Microphone Replacement, Remove the bracket: step 21, image 1 of 2 iPhone 16 Microphone Replacement, Remove the bracket: step 21, image 2 of 2
    • Use tweezers, or your fingers, to remove the Taptic Engine bracket.
    Ask FixBot
  22. iPhone 16 Microphone Replacement, Disconnect the Taptic Engine: step 22, image 1 of 2 iPhone 16 Microphone Replacement, Disconnect the Taptic Engine: step 22, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the Taptic Engine press connector.
    Ask FixBot
  23. iPhone 16 Microphone Replacement, Remove the Taptic Engine screws: step 23, image 1 of 2 iPhone 16 Microphone Replacement, Remove the Taptic Engine screws: step 23, image 2 of 2
    • Use a Phillips screwdriver to remove the two screws securing the Taptic Engine:
    • One 2.2 mm‑long screw
    • One 1.7 mm‑long screw
    Ask FixBot
  24. iPhone 16 Microphone Replacement, Remove the Taptic Engine: step 24, image 1 of 3 iPhone 16 Microphone Replacement, Remove the Taptic Engine: step 24, image 2 of 3 iPhone 16 Microphone Replacement, Remove the Taptic Engine: step 24, image 3 of 3
    • Use the point of a spudger to lift the Taptic Engine out of the frame.
    • Remove the Taptic Engine.
    Ask FixBot
  25. iPhone 16 Microphone Replacement, Remove the loudspeaker screws: step 25, image 1 of 2 iPhone 16 Microphone Replacement, Remove the loudspeaker screws: step 25, image 2 of 2
    • Remove the five screws securing the loudspeaker:
    • Two 1.5 mm‑long Phillips screws
    • One 2.0 mm‑long Phillips screw
    • One 2.9 mm‑long Phillips screw
    • One 1.2 mm‑long tri‑point Y000 screw
    Ask FixBot
  26. iPhone 16 Microphone Replacement, Remove the loudspeaker: step 26, image 1 of 3 iPhone 16 Microphone Replacement, Remove the loudspeaker: step 26, image 2 of 3 iPhone 16 Microphone Replacement, Remove the loudspeaker: step 26, image 3 of 3
    • Use the point of a spudger to lift the loudspeaker out of the frame.
    • Remove the loudspeaker.
    Ask FixBot
  27. iPhone 16 Microphone Replacement, Disconnect the microphone: step 27, image 1 of 2 iPhone 16 Microphone Replacement, Disconnect the microphone: step 27, image 2 of 2
    • Use the tip of a spudger to disconnect the microphone press connector.
    Ask FixBot
  28. iPhone 16 Microphone Replacement, Remove the microphone screws: step 28, image 1 of 2 iPhone 16 Microphone Replacement, Remove the microphone screws: step 28, image 2 of 2
    • Remove the four screws securing the microphone:
    • Two 3.3 mm‑long standoff screws
    • One 1.1 mm‑long tri‑point Y000 screw
    • One 1.5 mm‑long Phillips screw
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
    Ask FixBot
  29. iPhone 16 Microphone Replacement, Remove the microphone: step 29, image 1 of 3 iPhone 16 Microphone Replacement, Remove the microphone: step 29, image 2 of 3 iPhone 16 Microphone Replacement, Remove the microphone: step 29, image 3 of 3
    • Use the flat end of a spudger to lift the microphone enough to grip it with your fingers.
    Ask FixBot
  30. iPhone 16 Microphone Replacement: step 30, image 1 of 2 iPhone 16 Microphone Replacement: step 30, image 2 of 2
    • Pull the microphone away from the frame to separate the adhesive.
    • Remove the microphone.
    Ask FixBot
  31. iPhone 16 Microphone Replacement, End of disassembly: step 31, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Ask FixBot
  32. iPhone 16 Microphone Replacement, Remove the old adhesive: step 32, image 1 of 2 iPhone 16 Microphone Replacement, Remove the old adhesive: step 32, image 2 of 2
    • Use tweezers or your fingers to remove the old adhesive from the bottom of the frame.
    Ask FixBot
  33. iPhone 16 Microphone Replacement, Clean the microphone opening: step 33, image 1 of 1
    • Use high concentration isopropyl alcohol (greater than 90%) and a microfiber or lint-free cloth to clean the adhesive residue off the microphone opening in the frame.
    Ask FixBot
  34. iPhone 16 Microphone Replacement, Remove the white liner: step 34, image 1 of 2 iPhone 16 Microphone Replacement, Remove the white liner: step 34, image 2 of 2
    • If your microphone comes with adhesive installed, skip this step.
    • While holding the microphone adhesive with one hand, use your fingers or a pair of tweezers to remove the white liner from the adhesive.
    Ask FixBot
  35. iPhone 16 Microphone Replacement, Apply the adhesive to the microphone: step 35, image 1 of 3 iPhone 16 Microphone Replacement, Apply the adhesive to the microphone: step 35, image 2 of 3 iPhone 16 Microphone Replacement, Apply the adhesive to the microphone: step 35, image 3 of 3
    • Hold the microphone so the metal side is facing up.
    • Apply the adhesive to the microphone with the pull tab pointing up.
    Ask FixBot
  36. iPhone 16 Microphone Replacement: step 36, image 1 of 2 iPhone 16 Microphone Replacement: step 36, image 2 of 2
    • Remove the blue liner from the microphone adhesive.
    Ask FixBot
  37. iPhone 16 Microphone Replacement, Install the microphone: step 37, image 1 of 3 iPhone 16 Microphone Replacement, Install the microphone: step 37, image 2 of 3 iPhone 16 Microphone Replacement, Install the microphone: step 37, image 3 of 3
    • Insert the microphone at a downward angle so the adhesive adheres firmly to the frame around the opening.
    • Press the microphone firmly into place.
    Ask FixBot
  38. iPhone 16 Microphone Replacement, Install the microphone screws: step 38, image 1 of 2 iPhone 16 Microphone Replacement, Install the microphone screws: step 38, image 2 of 2
    • Install the four screws securing the microphone:
    Ask FixBot
  39. iPhone 16 Microphone Replacement, Connect the microphone: step 39, image 1 of 2 iPhone 16 Microphone Replacement, Connect the microphone: step 39, image 2 of 2
    • Use the flat end of a spudger to connect the microphone press connector.
    Ask FixBot
  40. iPhone 16 Microphone Replacement, Install the loudspeaker: step 40, image 1 of 2 iPhone 16 Microphone Replacement, Install the loudspeaker: step 40, image 2 of 2
    • Place the loudspeaker into the frame.
    Ask FixBot
  41. iPhone 16 Microphone Replacement, Install the loudspeaker screws: step 41, image 1 of 2 iPhone 16 Microphone Replacement, Install the loudspeaker screws: step 41, image 2 of 2
    • Install the five screws securing the loudspeaker:
    Ask FixBot
  42. iPhone 16 Microphone Replacement, Place the Taptic Engine: step 42, image 1 of 2 iPhone 16 Microphone Replacement, Place the Taptic Engine: step 42, image 2 of 2
    • Place the Taptic Engine into its recess in the frame.
    Ask FixBot
  43. iPhone 16 Microphone Replacement, Install the Taptic Engine screws: step 43, image 1 of 2 iPhone 16 Microphone Replacement, Install the Taptic Engine screws: step 43, image 2 of 2
    • Use a Phillips screwdriver to install the two screws securing the Taptic Engine:
    Ask FixBot
  44. iPhone 16 Microphone Replacement, Connect the Taptic Engine: step 44, image 1 of 2 iPhone 16 Microphone Replacement, Connect the Taptic Engine: step 44, image 2 of 2
    • Use the flat end of a spudger to connect the Taptic Engine press connector.
    Ask FixBot
  45. iPhone 16 Microphone Replacement, Install the Taptic Engine bracket: step 45, image 1 of 2 iPhone 16 Microphone Replacement, Install the Taptic Engine bracket: step 45, image 2 of 2
    • Use tweezers or your fingers to place the bracket over the Taptic Engine press connector.
    Ask FixBot
  46. iPhone 16 Microphone Replacement: step 46, image 1 of 2 iPhone 16 Microphone Replacement: step 46, image 2 of 2
    • Use a Phillips screwdriver to install the two 1.8 mm‑long screws securing the Taptic Engine bracket.
    Ask FixBot
  47. iPhone 16 Microphone Replacement, Remove the back glass adhesive: step 47, image 1 of 3 iPhone 16 Microphone Replacement, Remove the back glass adhesive: step 47, image 2 of 3 iPhone 16 Microphone Replacement, Remove the back glass adhesive: step 47, image 3 of 3
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
    Ask FixBot
  48. iPhone 16 Microphone Replacement: step 48, image 1 of 2 iPhone 16 Microphone Replacement: step 48, image 2 of 2
    • Use the tweezers to pull the adhesive off of the phone.
    • Repeat the previous step and this step until all of the adhesive is removed.
    Ask FixBot
  49. iPhone 16 Microphone Replacement, Clean the frame: step 49, image 1 of 3 iPhone 16 Microphone Replacement, Clean the frame: step 49, image 2 of 3 iPhone 16 Microphone Replacement, Clean the frame: step 49, image 3 of 3
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth over the point of a spudger and apply a few drops of high-concentration isopropyl alcohol (over 90%) to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    Ask FixBot
  50. iPhone 16 Microphone Replacement, Clean the back glass: step 50, image 1 of 2 iPhone 16 Microphone Replacement, Clean the back glass: step 50, image 2 of 2
    • If you're not reusing your back glass, skip this step.
    • Apply a few drops of high-concentration isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter of the back glass to prepare the surface for new adhesive.
    • If any clips on the back glass are bent, gently straighten them with your fingers.
    Ask FixBot
  51. iPhone 16 Microphone Replacement, Orient the adhesive: step 51, image 1 of 2 iPhone 16 Microphone Replacement, Orient the adhesive: step 51, image 2 of 2
    • Orient your replacement adhesive over the frame with the larger blue liner on the underside and its pull tab in the bottom-right corner.
    • The color of your liner and the pull tab locations may be different on your adhesive.
    • Use features such as the camera cutout and notches along the edges to ensure the adhesive is oriented correctly.
    Ask FixBot
  52. iPhone 16 Microphone Replacement, Expose the bottom edge of the adhesive: step 52, image 1 of 1
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
    Ask FixBot
  53. iPhone 16 Microphone Replacement, Apply the adhesive: step 53, image 1 of 3 iPhone 16 Microphone Replacement, Apply the adhesive: step 53, image 2 of 3 iPhone 16 Microphone Replacement, Apply the adhesive: step 53, image 3 of 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
    Ask FixBot
  54. iPhone 16 Microphone Replacement: step 54, image 1 of 3 iPhone 16 Microphone Replacement: step 54, image 2 of 3 iPhone 16 Microphone Replacement: step 54, image 3 of 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    Ask FixBot
  55. iPhone 16 Microphone Replacement, Press the adhesive into place: step 55, image 1 of 3 iPhone 16 Microphone Replacement, Press the adhesive into place: step 55, image 2 of 3 iPhone 16 Microphone Replacement, Press the adhesive into place: step 55, image 3 of 3
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
    Ask FixBot
  56. iPhone 16 Microphone Replacement, Remove the pink liner: step 56, image 1 of 3 iPhone 16 Microphone Replacement, Remove the pink liner: step 56, image 2 of 3 iPhone 16 Microphone Replacement, Remove the pink liner: step 56, image 3 of 3
    • Use the small pull tab in the top-right corner to remove the pink adhesive liner.
    Ask FixBot
  57. iPhone 16 Microphone Replacement: step 57, image 1 of 2 iPhone 16 Microphone Replacement: step 57, image 2 of 2
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the back glass.
    Ask FixBot
  58. iPhone 16 Microphone Replacement, Connect the charging coil: step 58, image 1 of 3 iPhone 16 Microphone Replacement, Connect the charging coil: step 58, image 2 of 3 iPhone 16 Microphone Replacement, Connect the charging coil: step 58, image 3 of 3
    • Prop up the back glass along the right edge of your iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the charging coil press connector.
    Ask FixBot
  59. iPhone 16 Microphone Replacement, Connect the battery: step 59, image 1 of 2 iPhone 16 Microphone Replacement, Connect the battery: step 59, image 2 of 2
    • Use the flat end of a spudger or your finger to connect the battery.
    Ask FixBot
  60. iPhone 16 Microphone Replacement, Install the cover: step 60, image 1 of 3 iPhone 16 Microphone Replacement, Install the cover: step 60, image 2 of 3 iPhone 16 Microphone Replacement, Install the cover: step 60, image 3 of 3
    • The connector cover has two hooks that slide into slots on the logic board.
    • Lay the connector cover on the phone so the hooks are slightly to the left of their slots in the logic board.
    • Use your finger to press the connector cover down and to the right until both hooks slide into their slots.
    Ask FixBot
  61. iPhone 16 Microphone Replacement, Install the cover screws: step 61, image 1 of 2 iPhone 16 Microphone Replacement, Install the cover screws: step 61, image 2 of 2
    • Use a tri-point Y000 driver to install the two 1 mm‑long screws securing the middle connector cover.
    Ask FixBot
  62. iPhone 16 Microphone Replacement, Remove the final adhesive liners: step 62, image 1 of 3 iPhone 16 Microphone Replacement, Remove the final adhesive liners: step 62, image 2 of 3 iPhone 16 Microphone Replacement, Remove the final adhesive liners: step 62, image 3 of 3
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use the blue tabs to remove the liners from the bottom, left, and top edges of your iPhone. Wait to remove the liner along the right edge.
    Ask FixBot
  63. iPhone 16 Microphone Replacement: step 63, image 1 of 2 iPhone 16 Microphone Replacement: step 63, image 2 of 2
    • Without letting the back glass touch the adhesive, hold the back glass over the phone so you can access the final liner along the right edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the right edge of the phone.
    Ask FixBot
  64. iPhone 16 Microphone Replacement, Place the back glass: step 64, image 1 of 3 iPhone 16 Microphone Replacement, Place the back glass: step 64, image 2 of 3 iPhone 16 Microphone Replacement, Place the back glass: step 64, image 3 of 3
    • Hold the back glass above the phone and align it with the frame.
    • Lay the glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all clips.
    Ask FixBot
  65. iPhone 16 Microphone Replacement, Heat the back glass: step 65, image 1 of 3 iPhone 16 Microphone Replacement, Heat the back glass: step 65, image 2 of 3 iPhone 16 Microphone Replacement, Heat the back glass: step 65, image 3 of 3
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
    Ask FixBot
  66. iPhone 16 Microphone Replacement, Press the back glass: step 66, image 1 of 3 iPhone 16 Microphone Replacement, Press the back glass: step 66, image 2 of 3 iPhone 16 Microphone Replacement, Press the back glass: step 66, image 3 of 3
    • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    Ask FixBot
  67. iPhone 16 Microphone Replacement: step 67, image 1 of 2 iPhone 16 Microphone Replacement: step 67, image 2 of 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    Ask FixBot
  68. iPhone 16 Microphone Replacement: step 68, image 1 of 3 iPhone 16 Microphone Replacement: step 68, image 2 of 3 iPhone 16 Microphone Replacement: step 68, image 3 of 3
    • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    Ask FixBot
  69. iPhone 16 Microphone Replacement: step 69, image 1 of 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Ask FixBot
  70. iPhone 16 Microphone Replacement, Install the pentalobe screws: step 70, image 1 of 2 iPhone 16 Microphone Replacement, Install the pentalobe screws: step 70, image 2 of 2
    • Use a P2 pentalobe driver to install the two 7.7 mm-long screws on either side of the charging port.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Answers Community for help.
2 other people completed this guide.
Alex Diaz-Kokaisl
238,862 Reputation
1,171 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 68
Past 30 Days: 316
All Time: 5,440
