iPhone 15 Pro Taptic Engine Replacement
  1. iPhone 15 Pro Taptic Engine Replacement, Prepare your iPhone for disassembly: step 1, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Prepare your iPhone for disassembly: step 1, image 2 of 2
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
    Ask FixBot
  2. iPhone 15 Pro Taptic Engine Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Ask FixBot
  3. iPhone 15 Pro Taptic Engine Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  4. iPhone 15 Pro Taptic Engine Replacement, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Remove the pentalobe screws: step 4, image 2 of 2
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
    Ask FixBot
  5. iPhone 15 Pro Taptic Engine Replacement, Heat the bottom edge: step 5, image 1 of 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Ask FixBot
  6. iPhone 15 Pro Taptic Engine Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  7. iPhone 15 Pro Taptic Engine Replacement, Screen information: step 7, image 1 of 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    Ask FixBot
  8. iPhone 15 Pro Taptic Engine Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Ask FixBot
  9. iPhone 15 Pro Taptic Engine Replacement, Heat the right edge: step 9, image 1 of 1
    • Heat the right edge of the screen until it's hot to the touch.
    Ask FixBot
  10. iPhone 15 Pro Taptic Engine Replacement, Position the opening pick: step 10, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Position the opening pick: step 10, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Position the opening pick: step 10, image 3 of 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
    Ask FixBot
  11. iPhone 15 Pro Taptic Engine Replacement, Release the right clip: step 11, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Release the right clip: step 11, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Release the right clip: step 11, image 3 of 3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
    Ask FixBot
  12. iPhone 15 Pro Taptic Engine Replacement, Separate the right edge adhesive: step 12, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Separate the right edge adhesive: step 12, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Separate the right edge adhesive: step 12, image 3 of 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
    Ask FixBot
  13. iPhone 15 Pro Taptic Engine Replacement, Heat the top edge: step 13, image 1 of 1
    • Heat the top edge of the screen until it's hot to the touch.
    Ask FixBot
  14. iPhone 15 Pro Taptic Engine Replacement, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Separate the top edge adhesive: step 14, image 3 of 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
    Ask FixBot
  15. iPhone 15 Pro Taptic Engine Replacement, Heat the left edge: step 15, image 1 of 1
    • Heat the left edge of the screen until it's hot to the touch.
    Ask FixBot
  16. iPhone 15 Pro Taptic Engine Replacement, Separate the left edge adhesive: step 16, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Separate the left edge adhesive: step 16, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Separate the left edge adhesive: step 16, image 3 of 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    Ask FixBot
  17. iPhone 15 Pro Taptic Engine Replacement, Prop up the screen: step 17, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Prop up the screen: step 17, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Prop up the screen: step 17, image 3 of 3
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access its cables without straining them.
    Ask FixBot
  18. iPhone 15 Pro Taptic Engine Replacement, Unfasten the logic board cover: step 18, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Unfasten the logic board cover: step 18, image 2 of 2
    • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
    • Four 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
    Ask FixBot
  19. iPhone 15 Pro Taptic Engine Replacement, Remove the logic board cover: step 19, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Remove the logic board cover: step 19, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Remove the logic board cover: step 19, image 3 of 3
    • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
    • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
    Ask FixBot
  20. iPhone 15 Pro Taptic Engine Replacement, Disconnect the battery: step 20, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Disconnect the battery: step 20, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Disconnect the battery: step 20, image 3 of 3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
    Ask FixBot
  21. iPhone 15 Pro Taptic Engine Replacement, Disconnect the screen: step 21, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Disconnect the screen: step 21, image 2 of 2
    • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
    Ask FixBot
  22. iPhone 15 Pro Taptic Engine Replacement, Disconnect the ambient light sensor: step 22, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Disconnect the ambient light sensor: step 22, image 2 of 2
    • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
    • Lift the cable to disconnect it.
    Ask FixBot
  23. iPhone 15 Pro Taptic Engine Replacement, Remove the screen: step 23, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Remove the screen: step 23, image 2 of 2
    • Remove the screen.
    • During reassembly, follow this guide to apply new adhesive and install your screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
    Ask FixBot
  24. iPhone 15 Pro Taptic Engine Replacement, Unfasten the loudspeaker: step 24, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Unfasten the loudspeaker: step 24, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the four screws securing the loudspeaker:
    • One 2.7 mm‑long screw
    • Three 2 mm‑long screws
    Ask FixBot
  25. iPhone 15 Pro Taptic Engine Replacement, Remove the loudspeaker: step 25, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Remove the loudspeaker: step 25, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Remove the loudspeaker: step 25, image 3 of 3
    • A plastic buffer is adhered to the top edges of the loudspeaker and Taptic Engine.
    • Lift the bottom edge of the loudspeaker until you can grab it with your fingers.
    • Peel the loudspeaker from the plastic buffer on its top edge and remove it.
    Ask FixBot
  26. iPhone 15 Pro Taptic Engine Replacement, Disconnect the Taptic Engine: step 26, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Disconnect the Taptic Engine: step 26, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the Taptic Engine press connector.
    Ask FixBot
  27. iPhone 15 Pro Taptic Engine Replacement, Unfasten the Taptic Engine: step 27, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Unfasten the Taptic Engine: step 27, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the two 2 mm‑long screws securing the Taptic Engine.
    Ask FixBot
  28. iPhone 15 Pro Taptic Engine Replacement, Remove the Taptic Engine: step 28, image 1 of 1
    • Remove the Taptic Engine.
    Ask FixBot
  29. iPhone 15 Pro Taptic Engine Replacement, Disassembly complete: step 29, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps show how to reassemble the iPhone.
    Ask FixBot
  30. iPhone 15 Pro Taptic Engine Replacement, Transfer the plastic buffer: step 30, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Transfer the plastic buffer: step 30, image 2 of 2
    • Transfer the plastic buffer from the top edge of the old Taptic Engine to your replacement part.
    • This buffer sits between the Taptic Engine and the battery. Align a short edge of the buffer with the left edge of the Taptic Engine.
    Ask FixBot
  31. iPhone 15 Pro Taptic Engine Replacement, Install the Taptic Engine: step 31, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Install the Taptic Engine: step 31, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Install the Taptic Engine: step 31, image 3 of 3
    • Set the Taptic Engine into place.
    Ask FixBot
  32. iPhone 15 Pro Taptic Engine Replacement, Install the Taptic Engine screws: step 32, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Install the Taptic Engine screws: step 32, image 2 of 2
    • Use a Phillips #000 screwdriver to install the two 2 mm‑long screws securing the Taptic Engine.
    Ask FixBot
  33. iPhone 15 Pro Taptic Engine Replacement, Connect the Taptic Engine: step 33, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Connect the Taptic Engine: step 33, image 2 of 2
    • Use your finger or the flat end of a spudger to connect the Taptic Engine press connector to its socket on the frame.
    Ask FixBot
  34. iPhone 15 Pro Taptic Engine Replacement, Install the loudspeaker: step 34, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Install the loudspeaker: step 34, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Install the loudspeaker: step 34, image 3 of 3
    • Set the loudspeaker into its recess in the phone.
    Ask FixBot
  35. iPhone 15 Pro Taptic Engine Replacement, Install the loudspeaker screws: step 35, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Install the loudspeaker screws: step 35, image 2 of 2
    • Use a Phillips #000 screwdriver to install the four screws securing the loudspeaker:
    Ask FixBot
  36. iPhone 15 Pro Taptic Engine Replacement, Remove the screen adhesive: step 36, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Remove the screen adhesive: step 36, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Remove the screen adhesive: step 36, image 3 of 3
    • The adhesive remaining on the phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
    Ask FixBot
  37. iPhone 15 Pro Taptic Engine Replacement: step 37, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement: step 37, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement: step 37, image 3 of 3
    • Any unevenness will compromise the iPhone's seal. Clean the frame thoroughly.
    • Apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to a cotton swab or lint-free cloth.
    • Wipe along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    Ask FixBot
  38. iPhone 15 Pro Taptic Engine Replacement, Orient the adhesive: step 38, image 1 of 1
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to orient it correctly.
    Ask FixBot
  39. iPhone 15 Pro Taptic Engine Replacement, Apply the adhesive: step 39, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Apply the adhesive: step 39, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Apply the adhesive: step 39, image 3 of 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but don't remove it all the way.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
    • When the adhesive is aligned, set it down along the bottom edge.
    Ask FixBot
  40. iPhone 15 Pro Taptic Engine Replacement: step 40, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement: step 40, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement: step 40, image 3 of 3
    • Continue peeling the back liner off of the adhesive while setting the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If you don't have another one handy, it's okay to put your iPhone back together without adhesive, but keep in mind that it won't be water resistant until you install new adhesive.
    Ask FixBot
  41. iPhone 15 Pro Taptic Engine Replacement, Press the adhesive into place: step 41, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Press the adhesive into place: step 41, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Press the adhesive into place: step 41, image 3 of 3
    • Use the flat end of a spudger to press the adhesive into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
    Ask FixBot
  42. iPhone 15 Pro Taptic Engine Replacement, Remove the top liner: step 42, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Remove the top liner: step 42, image 2 of 2
    • Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners along the edges.
    Ask FixBot
  43. iPhone 15 Pro Taptic Engine Replacement, Adhesive information: step 43, image 1 of 1
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. Be careful not to touch anything to the exposed adhesive.
    Ask FixBot
  44. iPhone 15 Pro Taptic Engine Replacement, Prop up the screen: step 44, image 1 of 1
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
    Ask FixBot
  45. iPhone 15 Pro Taptic Engine Replacement, Connect the screen and ambient light sensor: step 45, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Connect the screen and ambient light sensor: step 45, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Connect the screen and ambient light sensor: step 45, image 3 of 3
    • Use your finger or the flat end of a spudger to connect the screen and ambient light sensor press connectors.
    Ask FixBot
  46. iPhone 15 Pro Taptic Engine Replacement, Connect the battery: step 46, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Connect the battery: step 46, image 2 of 2
    • Use your finger or the flat end of a spudger to connect the battery press connector.
    Ask FixBot
  47. iPhone 15 Pro Taptic Engine Replacement, Install the logic board cover: step 47, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Install the logic board cover: step 47, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Install the logic board cover: step 47, image 3 of 3
    Ask FixBot
  48. iPhone 15 Pro Taptic Engine Replacement, Fasten the logic board cover: step 48, image 1 of 1
    • Use a Y000 screwdriver to install the six screws securing the logic board cover:
    Ask FixBot
  49. iPhone 15 Pro Taptic Engine Replacement, Remove the final adhesive liners: step 49, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Remove the final adhesive liners: step 49, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Remove the final adhesive liners: step 49, image 3 of 3
    • Once you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing accidentally sticks to it.
    • Use tweezers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the frame.
    Ask FixBot
  50. iPhone 15 Pro Taptic Engine Replacement: step 50, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement: step 50, image 2 of 2
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the frame.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the frame.
    Ask FixBot
  51. iPhone 15 Pro Taptic Engine Replacement, Place the screen: step 51, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Place the screen: step 51, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Place the screen: step 51, image 3 of 3
    • Align the screen over the frame, then lower it into place.
    Ask FixBot
  52. iPhone 15 Pro Taptic Engine Replacement, Press the screen: step 52, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Press the screen: step 52, image 2 of 2
    • Firmly press along the edges of the screen to engage the clips and compress the adhesive.
    Ask FixBot
  53. iPhone 15 Pro Taptic Engine Replacement, Install the pentalobe screws: step 53, image 1 of 1
    • Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
    Ask FixBot
  54. iPhone 15 Pro Taptic Engine Replacement, Heat the screen: step 54, image 1 of 2 iPhone 15 Pro Taptic Engine Replacement, Heat the screen: step 54, image 2 of 2
    • To help the adhesive bond, apply heat to the edges of the screen using a hair dryer or heat gun until it's hot to the touch.
    • If you have screen vise clamps, use them to strengthen the bond of the new adhesive. If not, keep reading for more ways to secure the screen.
    Ask FixBot
  55. iPhone 15 Pro Taptic Engine Replacement, Press the back glass: step 55, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement, Press the back glass: step 55, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement, Press the back glass: step 55, image 3 of 3
    • To evenly compress the iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the iPhone's original box, take the lid and place it on a flat surface.
    • If you don't have the original box, skip this step for an alternate method.
    • Place the iPhone screen-side-up in the lid of the box with the camera bump in its recess.
    • Find something close to the size of the iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes, ideally overnight.
    Ask FixBot
  56. iPhone 15 Pro Taptic Engine Replacement: step 56, image 1 of 3 iPhone 15 Pro Taptic Engine Replacement: step 56, image 2 of 3 iPhone 15 Pro Taptic Engine Replacement: step 56, image 3 of 3
    • If you don't have the iPhone's original box, follow the these two steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    • Place three layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    Ask FixBot
  57. iPhone 15 Pro Taptic Engine Replacement: step 57, image 1 of 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Ask FixBot
Congratulations on replacing the Taptic Engine!
Spencer Day
190,922 Reputation
1,204 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 50
Past 30 Days: 211
All Time: 5,398
