iPhone 15 Pro Screen Replacement
  1. iPhone 15 Pro Screen Replacement, Prepare your iPhone for disassembly: step 1, image 1 of 2 iPhone 15 Pro Screen Replacement, Prepare your iPhone for disassembly: step 1, image 2 of 2
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
    Ask FixBot
  2. iPhone 15 Pro Screen Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Pro Screen Replacement, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Ask FixBot
  3. iPhone 15 Pro Screen Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Pro Screen Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Pro Screen Replacement, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  4. iPhone 15 Pro Screen Replacement, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 15 Pro Screen Replacement, Remove the pentalobe screws: step 4, image 2 of 2
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
    Ask FixBot
  5. iPhone 15 Pro Screen Replacement, Screen bezel information: step 5, image 1 of 3 iPhone 15 Pro Screen Replacement, Screen bezel information: step 5, image 2 of 3 iPhone 15 Pro Screen Replacement, Screen bezel information: step 5, image 3 of 3
    • During the next two steps, make sure you're inserting your pick in the correct location:
    • There's a plastic bezel on the underside of the screen that sits on the frame. Insert your pick here, making sure it's completely under the bezel.
    • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two, complicating the repair.
    Ask FixBot
  6. iPhone 15 Pro Screen Replacement, Heat the bottom edge: step 6, image 1 of 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Ask FixBot
  7. iPhone 15 Pro Screen Replacement, Insert an opening pick: step 7, image 1 of 3 iPhone 15 Pro Screen Replacement, Insert an opening pick: step 7, image 2 of 3 iPhone 15 Pro Screen Replacement, Insert an opening pick: step 7, image 3 of 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  8. iPhone 15 Pro Screen Replacement, Screen information: step 8, image 1 of 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    Ask FixBot
  9. iPhone 15 Pro Screen Replacement, Separate the bottom edge adhesive: step 9, image 1 of 3 iPhone 15 Pro Screen Replacement, Separate the bottom edge adhesive: step 9, image 2 of 3 iPhone 15 Pro Screen Replacement, Separate the bottom edge adhesive: step 9, image 3 of 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Ask FixBot
  10. iPhone 15 Pro Screen Replacement, Heat the right edge: step 10, image 1 of 1
    • Heat the right edge of the screen until it's hot to the touch.
    Ask FixBot
  11. iPhone 15 Pro Screen Replacement, Position the opening pick: step 11, image 1 of 3 iPhone 15 Pro Screen Replacement, Position the opening pick: step 11, image 2 of 3 iPhone 15 Pro Screen Replacement, Position the opening pick: step 11, image 3 of 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
    Ask FixBot
  12. iPhone 15 Pro Screen Replacement, Release the right clip: step 12, image 1 of 3 iPhone 15 Pro Screen Replacement, Release the right clip: step 12, image 2 of 3 iPhone 15 Pro Screen Replacement, Release the right clip: step 12, image 3 of 3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
    Ask FixBot
  13. iPhone 15 Pro Screen Replacement, Separate the right edge adhesive: step 13, image 1 of 3 iPhone 15 Pro Screen Replacement, Separate the right edge adhesive: step 13, image 2 of 3 iPhone 15 Pro Screen Replacement, Separate the right edge adhesive: step 13, image 3 of 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
    Ask FixBot
  14. iPhone 15 Pro Screen Replacement, Heat the top edge: step 14, image 1 of 1
    • Heat the top edge of the screen until it's hot to the touch.
    Ask FixBot
  15. iPhone 15 Pro Screen Replacement, Separate the top edge adhesive: step 15, image 1 of 3 iPhone 15 Pro Screen Replacement, Separate the top edge adhesive: step 15, image 2 of 3 iPhone 15 Pro Screen Replacement, Separate the top edge adhesive: step 15, image 3 of 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
    Ask FixBot
  16. iPhone 15 Pro Screen Replacement, Heat the left edge: step 16, image 1 of 1
    • Heat the left edge of the screen until it's hot to the touch.
    Ask FixBot
  17. iPhone 15 Pro Screen Replacement, Separate the left edge adhesive: step 17, image 1 of 3 iPhone 15 Pro Screen Replacement, Separate the left edge adhesive: step 17, image 2 of 3 iPhone 15 Pro Screen Replacement, Separate the left edge adhesive: step 17, image 3 of 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
    Ask FixBot
  18. iPhone 15 Pro Screen Replacement, Prop up the screen: step 18, image 1 of 3 iPhone 15 Pro Screen Replacement, Prop up the screen: step 18, image 2 of 3 iPhone 15 Pro Screen Replacement, Prop up the screen: step 18, image 3 of 3
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access its cables without straining them.
    Ask FixBot
  19. iPhone 15 Pro Screen Replacement, Unfasten the logic board cover: step 19, image 1 of 2 iPhone 15 Pro Screen Replacement, Unfasten the logic board cover: step 19, image 2 of 2
    • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
    • Four 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
    Ask FixBot
  20. iPhone 15 Pro Screen Replacement, Remove the logic board cover: step 20, image 1 of 3 iPhone 15 Pro Screen Replacement, Remove the logic board cover: step 20, image 2 of 3 iPhone 15 Pro Screen Replacement, Remove the logic board cover: step 20, image 3 of 3
    • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
    • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
    Ask FixBot
  21. iPhone 15 Pro Screen Replacement, Disconnect the battery: step 21, image 1 of 3 iPhone 15 Pro Screen Replacement, Disconnect the battery: step 21, image 2 of 3 iPhone 15 Pro Screen Replacement, Disconnect the battery: step 21, image 3 of 3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
    Ask FixBot
  22. iPhone 15 Pro Screen Replacement, Disconnect the screen: step 22, image 1 of 2 iPhone 15 Pro Screen Replacement, Disconnect the screen: step 22, image 2 of 2
    • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
    Ask FixBot
  23. iPhone 15 Pro Screen Replacement, Disconnect the ambient light sensor: step 23, image 1 of 2 iPhone 15 Pro Screen Replacement, Disconnect the ambient light sensor: step 23, image 2 of 2
    • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
    • Lift the cable to disconnect it.
    Ask FixBot
  24. iPhone 15 Pro Screen Replacement, Remove the screen: step 24, image 1 of 2 iPhone 15 Pro Screen Replacement, Remove the screen: step 24, image 2 of 2
    • Remove the screen.
    • During reassembly, follow this guide to apply new adhesive and install your screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
    Ask FixBot
  25. iPhone 15 Pro Screen Replacement, Ambient light sensor information: step 25, image 1 of 2 iPhone 15 Pro Screen Replacement, Ambient light sensor information: step 25, image 2 of 2
    • Check if your new screen comes with an ambient light sensor installed.
    • If it doesn't, follow the remaining steps to remove and transfer the sensor from your original screen to your replacement.
    Ask FixBot
  26. iPhone 15 Pro Screen Replacement, Remove the ambient light sensor cover screws: step 26, image 1 of 2 iPhone 15 Pro Screen Replacement, Remove the ambient light sensor cover screws: step 26, image 2 of 2
    • Use a Phillips #000 driver to remove the two 1.4 mm-long screws securing the ambient light sensor cover.
    Ask FixBot
  27. iPhone 15 Pro Screen Replacement, Remove the ambient light sensor cover: step 27, image 1 of 1
    • Remove the ambient light sensor cover.
    Ask FixBot
  28. iPhone 15 Pro Screen Replacement, Heat the ambient light sensor adhesive: step 28, image 1 of 1
    • Be careful not to overheat the screen—the plastic components can melt if they get too hot.
    • Use a hair dryer or heat gun to heat the ambient light sensor until it's warm to the touch.
    Ask FixBot
  29. iPhone 15 Pro Screen Replacement, Pry up the sensor: step 29, image 1 of 2 iPhone 15 Pro Screen Replacement, Pry up the sensor: step 29, image 2 of 2
    • Be very gentle handing the ambient light sensor, as its cable is extremely fragile.
    • Use the flat end of a spudger to gently lift the ambient light sensor out of its enclosure.
    Ask FixBot
  30. iPhone 15 Pro Screen Replacement, Reheat the ambient light sensor: step 30, image 1 of 1
    • By this point, the sensor has likely cooled down.
    • Apply more heat until the entire glued down part of the sensor is warm to the touch.
    Ask FixBot
  31. iPhone 15 Pro Screen Replacement: step 31, image 1 of 3 iPhone 15 Pro Screen Replacement: step 31, image 2 of 3 iPhone 15 Pro Screen Replacement: step 31, image 3 of 3
    • Insert the tip of an opening pick under the bottom right corner of the sensor.
    • Slide the pick under the sensor and lift until you can grip it with your fingers.
    Ask FixBot
  32. iPhone 15 Pro Screen Replacement, Remove the ambient light sensor: step 32, image 1 of 1
    • Use your fingers to slowly peel up and remove the sensor.
    Ask FixBot
  33. iPhone 15 Pro Screen Replacement, Disassembly complete: step 33, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps show how to reassemble the iPhone.
    Ask FixBot
  34. iPhone 15 Pro Screen Replacement, Prepare the ambient light sensor: step 34, image 1 of 2 iPhone 15 Pro Screen Replacement, Prepare the ambient light sensor: step 34, image 2 of 2
    Tool used on this step:
    Tesa 61395 Tape
    $2.95
    Buy
    • Use tweezers to reposition any adhesive that may have covered the ambient light sensor during removal. The adhesive should form a border around the raised white rectangle.
    • If the adhesive was damaged or stayed with the old screen, replace it with a 1 mm‑wide strip of thin, double-sided tape along its bottom border.
    Ask FixBot
  35. iPhone 15 Pro Screen Replacement, Place the ambient light sensor: step 35, image 1 of 3 iPhone 15 Pro Screen Replacement, Place the ambient light sensor: step 35, image 2 of 3 iPhone 15 Pro Screen Replacement, Place the ambient light sensor: step 35, image 3 of 3
    • Align the ambient light sensor with its recess in the back of the screen.
    • Use a spudger or your finger to place the ambient light sensor into its recess.
    Ask FixBot
  36. iPhone 15 Pro Screen Replacement, Press the ambient light sensor: step 36, image 1 of 3 iPhone 15 Pro Screen Replacement, Press the ambient light sensor: step 36, image 2 of 3 iPhone 15 Pro Screen Replacement, Press the ambient light sensor: step 36, image 3 of 3
    Tesa 61395 Tape
    $2.95
    Buy
    • Use a hair dryer or heat gun to soften the adhesive under the ambient light sensor and its cable. It only needs to be warm—not hot.
    • Use your finger to press down the ambient light sensor cable.
    • If the ambient light sensor cable isn't sticking, apply a few small pieces of thin, double‑sided tape like Tesa tape to the back of the sensor cable.
    Ask FixBot
  37. iPhone 15 Pro Screen Replacement, Install the ambient light sensor bracket: step 37, image 1 of 3 iPhone 15 Pro Screen Replacement, Install the ambient light sensor bracket: step 37, image 2 of 3 iPhone 15 Pro Screen Replacement, Install the ambient light sensor bracket: step 37, image 3 of 3
    • Use tweezers or your fingers to place the ambient light sensor bracket, foam side down, aligned with its screw holes.
    • Use a Phillips screwdriver to install the two 1.4 mm‑long screws securing the ambient light sensor bracket.
    Ask FixBot
  38. iPhone 15 Pro Screen Replacement, Remove the screen adhesive: step 38, image 1 of 3 iPhone 15 Pro Screen Replacement, Remove the screen adhesive: step 38, image 2 of 3 iPhone 15 Pro Screen Replacement, Remove the screen adhesive: step 38, image 3 of 3
    • The adhesive remaining on the phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
    • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
    Ask FixBot
  39. iPhone 15 Pro Screen Replacement: step 39, image 1 of 3 iPhone 15 Pro Screen Replacement: step 39, image 2 of 3 iPhone 15 Pro Screen Replacement: step 39, image 3 of 3
    • Any unevenness will compromise the iPhone's seal. Clean the frame thoroughly.
    • Apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to a cotton swab or lint-free cloth.
    • Wipe along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    Ask FixBot
  40. iPhone 15 Pro Screen Replacement, Orient the adhesive: step 40, image 1 of 1
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to orient it correctly.
    Ask FixBot
  41. iPhone 15 Pro Screen Replacement, Apply the adhesive: step 41, image 1 of 3 iPhone 15 Pro Screen Replacement, Apply the adhesive: step 41, image 2 of 3 iPhone 15 Pro Screen Replacement, Apply the adhesive: step 41, image 3 of 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but don't remove it all the way.
    • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
    • When the adhesive is aligned, set it down along the bottom edge.
    Ask FixBot
  42. iPhone 15 Pro Screen Replacement: step 42, image 1 of 3 iPhone 15 Pro Screen Replacement: step 42, image 2 of 3 iPhone 15 Pro Screen Replacement: step 42, image 3 of 3
    • Continue peeling the back liner off of the adhesive while setting the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If you don't have another one handy, it's okay to put your iPhone back together without adhesive, but keep in mind that it won't be water resistant until you install new adhesive.
    Ask FixBot
  43. iPhone 15 Pro Screen Replacement, Press the adhesive into place: step 43, image 1 of 3 iPhone 15 Pro Screen Replacement, Press the adhesive into place: step 43, image 2 of 3 iPhone 15 Pro Screen Replacement, Press the adhesive into place: step 43, image 3 of 3
    • Use the flat end of a spudger to press the adhesive into place all around the iPhone.
    • Be careful not to press on the camera, spring contacts, or other internal components.
    Ask FixBot
  44. iPhone 15 Pro Screen Replacement, Remove the top liner: step 44, image 1 of 2 iPhone 15 Pro Screen Replacement, Remove the top liner: step 44, image 2 of 2
    • Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
    • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners along the edges.
    Ask FixBot
  45. iPhone 15 Pro Screen Replacement, Adhesive information: step 45, image 1 of 1
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. Be careful not to touch anything to the exposed adhesive.
    Ask FixBot
  46. iPhone 15 Pro Screen Replacement, Prop up the screen: step 46, image 1 of 1
    • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
    Ask FixBot
  47. iPhone 15 Pro Screen Replacement, Connect the screen and ambient light sensor: step 47, image 1 of 3 iPhone 15 Pro Screen Replacement, Connect the screen and ambient light sensor: step 47, image 2 of 3 iPhone 15 Pro Screen Replacement, Connect the screen and ambient light sensor: step 47, image 3 of 3
    • Use your finger or the flat end of a spudger to connect the screen and ambient light sensor press connectors.
    Ask FixBot
  48. iPhone 15 Pro Screen Replacement, Connect the battery: step 48, image 1 of 2 iPhone 15 Pro Screen Replacement, Connect the battery: step 48, image 2 of 2
    • Use your finger or the flat end of a spudger to connect the battery press connector.
    Ask FixBot
  49. iPhone 15 Pro Screen Replacement, Install the logic board cover: step 49, image 1 of 3 iPhone 15 Pro Screen Replacement, Install the logic board cover: step 49, image 2 of 3 iPhone 15 Pro Screen Replacement, Install the logic board cover: step 49, image 3 of 3
    Ask FixBot
  50. iPhone 15 Pro Screen Replacement, Fasten the logic board cover: step 50, image 1 of 1
    • Use a Y000 screwdriver to install the six screws securing the logic board cover:
    Ask FixBot
  51. iPhone 15 Pro Screen Replacement, Remove the final adhesive liners: step 51, image 1 of 3 iPhone 15 Pro Screen Replacement, Remove the final adhesive liners: step 51, image 2 of 3 iPhone 15 Pro Screen Replacement, Remove the final adhesive liners: step 51, image 3 of 3
    • Once you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing accidentally sticks to it.
    • Use tweezers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the frame.
    Ask FixBot
  52. iPhone 15 Pro Screen Replacement: step 52, image 1 of 2 iPhone 15 Pro Screen Replacement: step 52, image 2 of 2
    • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the frame.
    • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the frame.
    Ask FixBot
  53. iPhone 15 Pro Screen Replacement, Place the screen: step 53, image 1 of 3 iPhone 15 Pro Screen Replacement, Place the screen: step 53, image 2 of 3 iPhone 15 Pro Screen Replacement, Place the screen: step 53, image 3 of 3
    • Align the screen over the frame, then lower it into place.
    Ask FixBot
  54. iPhone 15 Pro Screen Replacement, Press the screen: step 54, image 1 of 2 iPhone 15 Pro Screen Replacement, Press the screen: step 54, image 2 of 2
    • Firmly press along the edges of the screen to engage the clips and compress the adhesive.
    Ask FixBot
  55. iPhone 15 Pro Screen Replacement, Install the pentalobe screws: step 55, image 1 of 1
    • Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
    Ask FixBot
  56. iPhone 15 Pro Screen Replacement, Heat the screen: step 56, image 1 of 2 iPhone 15 Pro Screen Replacement, Heat the screen: step 56, image 2 of 2
    • To help the adhesive bond, apply heat to the edges of the screen using a hair dryer or heat gun until it's hot to the touch.
    • If you have screen vise clamps, use them to strengthen the bond of the new adhesive. If not, keep reading for more ways to secure the screen.
    Ask FixBot
  57. iPhone 15 Pro Screen Replacement, Press the back glass: step 57, image 1 of 3 iPhone 15 Pro Screen Replacement, Press the back glass: step 57, image 2 of 3 iPhone 15 Pro Screen Replacement, Press the back glass: step 57, image 3 of 3
    • To evenly compress the iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
    • If you have the iPhone's original box, take the lid and place it on a flat surface.
    • If you don't have the original box, skip this step for an alternate method.
    • Place the iPhone screen-side-up in the lid of the box with the camera bump in its recess.
    • Find something close to the size of the iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes, ideally overnight.
    Ask FixBot
  58. iPhone 15 Pro Screen Replacement: step 58, image 1 of 3 iPhone 15 Pro Screen Replacement: step 58, image 2 of 3 iPhone 15 Pro Screen Replacement: step 58, image 3 of 3
    • If you don't have the iPhone's original box, follow the these two steps for another method to evenly compress the screen.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    • Place three layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
    Ask FixBot
  59. iPhone 15 Pro Screen Replacement: step 59, image 1 of 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Ask FixBot
Congratulations on completing the repair!
After your repair, depending on the replacement part, you may be able to pair it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
43 other people completed this guide.
Spencer Day
190,922 Reputation
1,204 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
11 Guide Comments
Very helpful
Roger Dunham - Reply Share
Pls also make the videos of your guides available on YouTube so it can be more understandable
Seyi Raji - Reply Share
Where the hell do you buy the replacement display on the iFixIt website?
Anonymous - Reply Share
You can buy it at selfservicerepair.com it is a lot cheaper there
nicholaswiding - Reply Share
This adhesive is way more annoying than it has any logical reason to be.
Seth Blagg - Reply Share
Past 24 Hours: 154
Past 7 Days: 1,042
Past 30 Days: 4,482
All Time: 97,626
