iPhone 15 Back Glass Replacement
  1. iPhone 15 Back Glass Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Back Glass Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
    Ask FixBot
  2. iPhone 15 Back Glass Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Back Glass Replacement, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    Ask FixBot
  3. iPhone 15 Back Glass Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Back Glass Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Back Glass Replacement, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Ask FixBot
  4. iPhone 15 Back Glass Replacement, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 15 Back Glass Replacement, Remove the pentalobe screws: step 4, image 2 of 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
    Ask FixBot
  5. iPhone 15 Back Glass Replacement, Heat the bottom edge: step 5, image 1 of 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    Ask FixBot
  6. iPhone 15 Back Glass Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone 15 Back Glass Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone 15 Back Glass Replacement, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
    Ask FixBot
  7. iPhone 15 Back Glass Replacement, Back glass information: step 7, image 1 of 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    Ask FixBot
  8. iPhone 15 Back Glass Replacement, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Back Glass Replacement, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Back Glass Replacement, Separate the bottom edge adhesive: step 8, image 3 of 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    Ask FixBot
  9. iPhone 15 Back Glass Replacement, Heat the right edge: step 9, image 1 of 1
    • Heat the right edge of the back glass until it's hot to the touch.
    Ask FixBot
  10. iPhone 15 Back Glass Replacement, Separate the bottom right corner adhesive: step 10, image 1 of 3 iPhone 15 Back Glass Replacement, Separate the bottom right corner adhesive: step 10, image 2 of 3 iPhone 15 Back Glass Replacement, Separate the bottom right corner adhesive: step 10, image 3 of 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
    Ask FixBot
  11. iPhone 15 Back Glass Replacement, Heat the left edge: step 11, image 1 of 1
    • Heat the left edge of the back glass until it's hot to the touch.
    Ask FixBot
  12. iPhone 15 Back Glass Replacement, Separate the left edge adhesive: step 12, image 1 of 3 iPhone 15 Back Glass Replacement, Separate the left edge adhesive: step 12, image 2 of 3 iPhone 15 Back Glass Replacement, Separate the left edge adhesive: step 12, image 3 of 3
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
    Ask FixBot
  13. iPhone 15 Back Glass Replacement, Heat the top edge: step 13, image 1 of 1
    • Heat the top edge of the back glass until it's hot to the touch.
    Ask FixBot
  14. iPhone 15 Back Glass Replacement, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 15 Back Glass Replacement, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 15 Back Glass Replacement, Separate the top edge adhesive: step 14, image 3 of 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
    Ask FixBot
  15. iPhone 15 Back Glass Replacement, Heat the top right corner: step 15, image 1 of 1
    • Heat the top right corner of the back glass until it's hot to the touch.
    Ask FixBot
  16. iPhone 15 Back Glass Replacement, Separate the top right corner adhesive: step 16, image 1 of 3 iPhone 15 Back Glass Replacement, Separate the top right corner adhesive: step 16, image 2 of 3 iPhone 15 Back Glass Replacement, Separate the top right corner adhesive: step 16, image 3 of 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
    Ask FixBot
  17. iPhone 15 Back Glass Replacement, Open the back glass: step 17, image 1 of 3 iPhone 15 Back Glass Replacement, Open the back glass: step 17, image 2 of 3 iPhone 15 Back Glass Replacement, Open the back glass: step 17, image 3 of 3
    • Gently lift and swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
    Ask FixBot
  18. iPhone 15 Back Glass Replacement, Unfasten the lower connector cover: step 18, image 1 of 1
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
    Ask FixBot
  19. iPhone 15 Back Glass Replacement, Remove the lower connector cover: step 19, image 1 of 3 iPhone 15 Back Glass Replacement, Remove the lower connector cover: step 19, image 2 of 3 iPhone 15 Back Glass Replacement, Remove the lower connector cover: step 19, image 3 of 3
    Buy
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
    Ask FixBot
  20. iPhone 15 Back Glass Replacement, Disconnect the battery: step 20, image 1 of 3 iPhone 15 Back Glass Replacement, Disconnect the battery: step 20, image 2 of 3 iPhone 15 Back Glass Replacement, Disconnect the battery: step 20, image 3 of 3
    • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
    • A plus and minus sign is printed on the head of this connector.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    Ask FixBot
  21. iPhone 15 Back Glass Replacement, Unfasten the middle connector cover: step 21, image 1 of 2 iPhone 15 Back Glass Replacement, Unfasten the middle connector cover: step 21, image 2 of 2
    • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
    Ask FixBot
  22. iPhone 15 Back Glass Replacement, Remove the cover: step 22, image 1 of 3 iPhone 15 Back Glass Replacement, Remove the cover: step 22, image 2 of 3 iPhone 15 Back Glass Replacement, Remove the cover: step 22, image 3 of 3
    • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
    • Remove the cover.
    Ask FixBot
  23. iPhone 15 Back Glass Replacement, Disconnect the wireless charging coil: step 23, image 1 of 2 iPhone 15 Back Glass Replacement, Disconnect the wireless charging coil: step 23, image 2 of 2
    • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
    Ask FixBot
  24. iPhone 15 Back Glass Replacement, Remove the back glass: step 24, image 1 of 1
    • Remove the back glass.
    Ask FixBot
  25. iPhone 15 Back Glass Replacement, End of disassembly: step 25, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Ask FixBot
  26. iPhone 15 Back Glass Replacement, Remove the back glass adhesive: step 26, image 1 of 2 iPhone 15 Back Glass Replacement, Remove the back glass adhesive: step 26, image 2 of 2
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
    • Use the tweezers to pull the adhesive off of the phone.
    Ask FixBot
  27. iPhone 15 Back Glass Replacement: step 27, image 1 of 3 iPhone 15 Back Glass Replacement: step 27, image 2 of 3 iPhone 15 Back Glass Replacement: step 27, image 3 of 3
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
    Ask FixBot
  28. iPhone 15 Back Glass Replacement, Orient the adhesive: step 28, image 1 of 3 iPhone 15 Back Glass Replacement, Orient the adhesive: step 28, image 2 of 3 iPhone 15 Back Glass Replacement, Orient the adhesive: step 28, image 3 of 3
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the rear camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
    Ask FixBot
  29. iPhone 15 Back Glass Replacement, Apply the adhesive: step 29, image 1 of 3 iPhone 15 Back Glass Replacement, Apply the adhesive: step 29, image 2 of 3 iPhone 15 Back Glass Replacement, Apply the adhesive: step 29, image 3 of 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
    • Hold the liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
    Ask FixBot
  30. iPhone 15 Back Glass Replacement: step 30, image 1 of 3 iPhone 15 Back Glass Replacement: step 30, image 2 of 3 iPhone 15 Back Glass Replacement: step 30, image 3 of 3
    • When the adhesive is aligned, use the flat end of a spudger or your finger to press it down firmly along the bottom edge.
    Ask FixBot
  31. iPhone 15 Back Glass Replacement: step 31, image 1 of 3 iPhone 15 Back Glass Replacement: step 31, image 2 of 3 iPhone 15 Back Glass Replacement: step 31, image 3 of 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
    Ask FixBot
  32. iPhone 15 Back Glass Replacement, Press the adhesive into place: step 32, image 1 of 3 iPhone 15 Back Glass Replacement, Press the adhesive into place: step 32, image 2 of 3 iPhone 15 Back Glass Replacement, Press the adhesive into place: step 32, image 3 of 3
    • Make sure the liner is aligned properly by checking that all spring contacts and the rear camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
    Ask FixBot
  33. iPhone 15 Back Glass Replacement, Remove the top liner: step 33, image 1 of 3 iPhone 15 Back Glass Replacement, Remove the top liner: step 33, image 2 of 3 iPhone 15 Back Glass Replacement, Remove the top liner: step 33, image 3 of 3
    • Remove the top adhesive liner.
    • Depending on your adhesive, your liner might be split into multiple parts or be a single piece.
    Ask FixBot
  34. iPhone 15 Back Glass Replacement, Prop up the back glass: step 34, image 1 of 3 iPhone 15 Back Glass Replacement, Prop up the back glass: step 34, image 2 of 3 iPhone 15 Back Glass Replacement, Prop up the back glass: step 34, image 3 of 3
    • Prop up the back glass along the right edge of the iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the wireless charging coil press connector, then the battery press connector.
    Ask FixBot
  35. iPhone 15 Back Glass Replacement, Place the middle connector cover: step 35, image 1 of 2 iPhone 15 Back Glass Replacement, Place the middle connector cover: step 35, image 2 of 2
    • Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
    Ask FixBot
  36. iPhone 15 Back Glass Replacement: step 36, image 1 of 2 iPhone 15 Back Glass Replacement: step 36, image 2 of 2
    • Use your finger to press the cover down on the logic board.
    • While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
    Ask FixBot
  37. iPhone 15 Back Glass Replacement, Place the lower connector cover: step 37, image 1 of 3 iPhone 15 Back Glass Replacement, Place the lower connector cover: step 37, image 2 of 3 iPhone 15 Back Glass Replacement, Place the lower connector cover: step 37, image 3 of 3
    • Use tweezers to hook the top of the lower connector cover into its slot on the logic board.
    • Lay the lower connector cover over the press connectors.
    Ask FixBot
  38. iPhone 15 Back Glass Replacement, Install the cover screws: step 38, image 1 of 2 iPhone 15 Back Glass Replacement, Install the cover screws: step 38, image 2 of 2
    • Use a tri-point Y000 screwdriver to install the 0.9 mm‑long screw securing the middle connector cover.
    • Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
    Ask FixBot
  39. iPhone 15 Back Glass Replacement, Remove the final adhesive liners: step 39, image 1 of 2 iPhone 15 Back Glass Replacement, Remove the final adhesive liners: step 39, image 2 of 2
    • Use tweezers or your fingers to separate the pull tabs at the bottom of the frame, near the charging port.
    Ask FixBot
  40. iPhone 15 Back Glass Replacement: step 40, image 1 of 3 iPhone 15 Back Glass Replacement: step 40, image 2 of 3 iPhone 15 Back Glass Replacement: step 40, image 3 of 3
    • Remove the narrow liner covering the adhesive along the left and top edges of the frame.
    Ask FixBot
  41. iPhone 15 Back Glass Replacement: step 41, image 1 of 3 iPhone 15 Back Glass Replacement: step 41, image 2 of 3 iPhone 15 Back Glass Replacement: step 41, image 3 of 3
    • Hold the back glass over the phone without letting it touch the adhesive, so you can access the remaining liners along the right edge of the phone.
    • Use a pair of tweezers or your fingers to remove the remaing liners along the right edge of the phone.
    Ask FixBot
  42. iPhone 15 Back Glass Replacement, Install the back glass: step 42, image 1 of 3 iPhone 15 Back Glass Replacement, Install the back glass: step 42, image 2 of 3 iPhone 15 Back Glass Replacement, Install the back glass: step 42, image 3 of 3
    • Lay the back glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all the clips.
    Ask FixBot
  43. iPhone 15 Back Glass Replacement, Heat the back glass: step 43, image 1 of 2 iPhone 15 Back Glass Replacement, Heat the back glass: step 43, image 2 of 2
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass. If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
    Ask FixBot
  44. iPhone 15 Back Glass Replacement, Press the back glass: step 44, image 1 of 3 iPhone 15 Back Glass Replacement, Press the back glass: step 44, image 2 of 3 iPhone 15 Back Glass Replacement, Press the back glass: step 44, image 3 of 3
    • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    Ask FixBot
  45. iPhone 15 Back Glass Replacement: step 45, image 1 of 2 iPhone 15 Back Glass Replacement: step 45, image 2 of 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
    Ask FixBot
  46. iPhone 15 Back Glass Replacement: step 46, image 1 of 3 iPhone 15 Back Glass Replacement: step 46, image 2 of 3 iPhone 15 Back Glass Replacement: step 46, image 3 of 3
    • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Stack them to a consistent height taller than the camera bump.
    Ask FixBot
  47. iPhone 15 Back Glass Replacement: step 47, image 1 of 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    Ask FixBot
  48. iPhone 15 Back Glass Replacement, Install the pentalobe screws: step 48, image 1 of 2 iPhone 15 Back Glass Replacement, Install the pentalobe screws: step 48, image 2 of 2
    • Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
    Ask FixBot
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
17 other people completed this guide.
Clay Eickemeyer
104,117 Reputation
476 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
17,861 Guides authored
1 Guide Comment
where are you getting your back replacements from?
Raheem Muhammad - Reply Share
Past 24 Hours: 134
Past 7 Days: 947
Past 30 Days: 4,046
All Time: 85,200
