Xbox Series X Power Supply Replacement
  1. Xbox Series X Power Supply Replacement, Uncover the back panel screws: step 1, image 1 of 2 Xbox Series X Power Supply Replacement, Uncover the back panel screws: step 1, image 2 of 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
    Ask FixBot
  2. Xbox Series X Power Supply Replacement: step 2, image 1 of 3 Xbox Series X Power Supply Replacement: step 2, image 2 of 3 Xbox Series X Power Supply Replacement: step 2, image 3 of 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    Ask FixBot
  3. Xbox Series X Power Supply Replacement, Remove the back panel screws: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    Ask FixBot
  4. Xbox Series X Power Supply Replacement, Unclip the back panel: step 4, image 1 of 3 Xbox Series X Power Supply Replacement, Unclip the back panel: step 4, image 2 of 3 Xbox Series X Power Supply Replacement, Unclip the back panel: step 4, image 3 of 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
    Ask FixBot
  5. Xbox Series X Power Supply Replacement: step 5, image 1 of 2 Xbox Series X Power Supply Replacement: step 5, image 2 of 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
    Ask FixBot
  6. Xbox Series X Power Supply Replacement, Remove the back panel: step 6, image 1 of 3 Xbox Series X Power Supply Replacement, Remove the back panel: step 6, image 2 of 3 Xbox Series X Power Supply Replacement, Remove the back panel: step 6, image 3 of 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
    Ask FixBot
  7. Xbox Series X Power Supply Replacement: step 7, image 1 of 3 Xbox Series X Power Supply Replacement: step 7, image 2 of 3 Xbox Series X Power Supply Replacement: step 7, image 3 of 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
    Ask FixBot
  8. Xbox Series X Power Supply Replacement, Remove the fan screws: step 8, image 1 of 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
    Ask FixBot
  9. Xbox Series X Power Supply Replacement, Disconnect the fan cable: step 9, image 1 of 3 Xbox Series X Power Supply Replacement, Disconnect the fan cable: step 9, image 2 of 3 Xbox Series X Power Supply Replacement, Disconnect the fan cable: step 9, image 3 of 3
    Buy
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
    Ask FixBot
  10. Xbox Series X Power Supply Replacement, Remove the fan: step 10, image 1 of 2 Xbox Series X Power Supply Replacement, Remove the fan: step 10, image 2 of 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
    Ask FixBot
  11. Xbox Series X Power Supply Replacement, Unlatch the base: step 11, image 1 of 3 Xbox Series X Power Supply Replacement, Unlatch the base: step 11, image 2 of 3 Xbox Series X Power Supply Replacement, Unlatch the base: step 11, image 3 of 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
    Ask FixBot
  12. Xbox Series X Power Supply Replacement, Twist and remove the base: step 12, image 1 of 3 Xbox Series X Power Supply Replacement, Twist and remove the base: step 12, image 2 of 3 Xbox Series X Power Supply Replacement, Twist and remove the base: step 12, image 3 of 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
    Ask FixBot
  13. Xbox Series X Power Supply Replacement, Remove the optical drive screws: step 13, image 1 of 2 Xbox Series X Power Supply Replacement, Remove the optical drive screws: step 13, image 2 of 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
    Ask FixBot
  14. Xbox Series X Power Supply Replacement, Remove the vibration isolator: step 14, image 1 of 3 Xbox Series X Power Supply Replacement, Remove the vibration isolator: step 14, image 2 of 3 Xbox Series X Power Supply Replacement, Remove the vibration isolator: step 14, image 3 of 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
    Ask FixBot
  15. Xbox Series X Power Supply Replacement, Disconnect the power and data cables: step 15, image 1 of 3 Xbox Series X Power Supply Replacement, Disconnect the power and data cables: step 15, image 2 of 3 Xbox Series X Power Supply Replacement, Disconnect the power and data cables: step 15, image 3 of 3
    Buy
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
    Ask FixBot
  16. Xbox Series X Power Supply Replacement, Remove the optical drive: step 16, image 1 of 2 Xbox Series X Power Supply Replacement, Remove the optical drive: step 16, image 2 of 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
    Ask FixBot
  17. Xbox Series X Power Supply Replacement, Disconnect the USB port cable: step 17, image 1 of 3 Xbox Series X Power Supply Replacement, Disconnect the USB port cable: step 17, image 2 of 3 Xbox Series X Power Supply Replacement, Disconnect the USB port cable: step 17, image 3 of 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
    Ask FixBot
  18. Xbox Series X Power Supply Replacement: step 18, image 1 of 2 Xbox Series X Power Supply Replacement: step 18, image 2 of 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
    Ask FixBot
  19. Xbox Series X Power Supply Replacement, Disconnect the power button cable: step 19, image 1 of 3 Xbox Series X Power Supply Replacement, Disconnect the power button cable: step 19, image 2 of 3 Xbox Series X Power Supply Replacement, Disconnect the power button cable: step 19, image 3 of 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
    Ask FixBot
  20. Xbox Series X Power Supply Replacement, Remove the chassis screws: step 20, image 1 of 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
    Ask FixBot
  21. Xbox Series X Power Supply Replacement, Peel up the USB port cable: step 21, image 1 of 2 Xbox Series X Power Supply Replacement, Peel up the USB port cable: step 21, image 2 of 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
    Ask FixBot
  22. Xbox Series X Power Supply Replacement, Remove the center chassis assembly: step 22, image 1 of 3 Xbox Series X Power Supply Replacement, Remove the center chassis assembly: step 22, image 2 of 3 Xbox Series X Power Supply Replacement, Remove the center chassis assembly: step 22, image 3 of 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
    Ask FixBot
  23. Xbox Series X Power Supply Replacement, Unlatch the chassis strap: step 23, image 1 of 3 Xbox Series X Power Supply Replacement, Unlatch the chassis strap: step 23, image 2 of 3 Xbox Series X Power Supply Replacement, Unlatch the chassis strap: step 23, image 3 of 3
    • Unlatch the chassis strap from the right side of the power supply.
    Ask FixBot
  24. Xbox Series X Power Supply Replacement: step 24, image 1 of 3 Xbox Series X Power Supply Replacement: step 24, image 2 of 3 Xbox Series X Power Supply Replacement: step 24, image 3 of 3
    • Pull the chassis strap over and off of the power supply.
    • Once the strap is off of the power supply, set the loose section to the side.
    Ask FixBot
  25. Xbox Series X Power Supply Replacement, Remove the power cable port: step 25, image 1 of 1
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm screws
    • One 35 mm screw
    Ask FixBot
  26. Xbox Series X Power Supply Replacement: step 26, image 1 of 2 Xbox Series X Power Supply Replacement: step 26, image 2 of 2
    • Lift the power connector out of its recess in the chassis.
    Ask FixBot
  27. Xbox Series X Power Supply Replacement, De-route the power cables: step 27, image 1 of 2 Xbox Series X Power Supply Replacement, De-route the power cables: step 27, image 2 of 2
    • Unlatch and open the lid on the power cable's plastic guide.
    Ask FixBot
  28. Xbox Series X Power Supply Replacement: step 28, image 1 of 2 Xbox Series X Power Supply Replacement: step 28, image 2 of 2
    • Lift the power cable out from underneath the extra section of the cable guide.
    Ask FixBot
  29. Xbox Series X Power Supply Replacement, Remove the corner cover: step 29, image 1 of 1
    • Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
    Ask FixBot
  30. Xbox Series X Power Supply Replacement: step 30, image 1 of 2 Xbox Series X Power Supply Replacement: step 30, image 2 of 2
    Buy
    • Your Xbox may not have this cover depending on the model.
    • Use your fingers or a pair of tweezers to lift and remove the power supply corner cover.
    Ask FixBot
  31. Xbox Series X Power Supply Replacement, Remove the accessory antenna board: step 31, image 1 of 1
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
    Ask FixBot
  32. Xbox Series X Power Supply Replacement: step 32, image 1 of 3 Xbox Series X Power Supply Replacement: step 32, image 2 of 3 Xbox Series X Power Supply Replacement: step 32, image 3 of 3
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
    Ask FixBot
  33. Xbox Series X Power Supply Replacement, Remove the board shield: step 33, image 1 of 1
    • Use a T8 Torx driver to remove the nine screws securing the board shield:
    • Six 8.8 mm black screws
    • Two 35 mm silver screws
    • One 13.1 mm silver screw
    Ask FixBot
  34. Xbox Series X Power Supply Replacement: step 34, image 1 of 3 Xbox Series X Power Supply Replacement: step 34, image 2 of 3 Xbox Series X Power Supply Replacement: step 34, image 3 of 3
    • Lift up the board shield to remove it from the center chassis.
    Ask FixBot
  35. Xbox Series X Power Supply Replacement, Remove the chassis strap: step 35, image 1 of 3 Xbox Series X Power Supply Replacement, Remove the chassis strap: step 35, image 2 of 3 Xbox Series X Power Supply Replacement, Remove the chassis strap: step 35, image 3 of 3
    • Disconnect the chassis strap from the locking tabs on either side of the power supply.
    Ask FixBot
  36. Xbox Series X Power Supply Replacement: step 36, image 1 of 2 Xbox Series X Power Supply Replacement: step 36, image 2 of 2
    • Remove the chassis strap.
    Ask FixBot
  37. Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: step 37, image 1 of 3 Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: step 37, image 2 of 3 Xbox Series X Power Supply Replacement, Remove the 10-pin power cable: step 37, image 3 of 3
    • Grip and compress the locking tab on the 10-pin power connector.
    • While compressing the locking tab, lift the connector straight up to disconnect it from the board.
    Ask FixBot
  38. Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: step 38, image 1 of 3 Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: step 38, image 2 of 3 Xbox Series X Power Supply Replacement, Remove the 2-pin power cable: step 38, image 3 of 3
    • Grip and compress the locking tab on the 2-pin power connector.
    Ask FixBot
  39. Xbox Series X Power Supply Replacement, Open the cable guide: step 39, image 1 of 2 Xbox Series X Power Supply Replacement, Open the cable guide: step 39, image 2 of 2
    • Open the lid on the power supply's plastic cable guide.
    Ask FixBot
  40. Xbox Series X Power Supply Replacement, Remove the power supply screws: step 40, image 1 of 2 Xbox Series X Power Supply Replacement, Remove the power supply screws: step 40, image 2 of 2
    • Use a T8 Torx driver to remove the four screws securing the power supply around its perimeter:
    • Three 35 mm silver screws
    • One 8.8 mm black screw
    Ask FixBot
  41. Xbox Series X Power Supply Replacement, Remove the power supply: step 41, image 1 of 2 Xbox Series X Power Supply Replacement, Remove the power supply: step 41, image 2 of 2
    • Remove the power supply.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
42 other people completed this guide.
Carsten Frauenheim
165,456 Reputation
439 Guides authored
iFixit Member of iFixit
Staff
122 Members
25,936 Guides authored
33 Guide Comments
So, I am a skilled DIYer. I had 1 series x that had no power all the sudden, under warranty, sent back and received a refurb. Then I got a halo infinite edition, it all the sudden wouldn't send video. It would power up but I couldn't boot in safe mode or low res mode. Sent it back, send me a refurb. Now my brothers Xbox did the same thing. It turns on but never boots then shuts off after few minutes. No controller connects either, and can't have the xbox sync with the flash. His is not under warranty so I bought a PSU and replaced, still same thing. Any ideas? Microsoft just sends you a refurb and doesn't tell you what was wrong or else I'd know since it happened to my infinite console.
heavychevy9 - Reply Share
Have you tried replacing the SSD drive?
Kason M - Reply Share
FYI this guide is amazing! Down to providing the length of screws and circling in photos. A++
Well ladies and gentlemen I did it. Took about an hour and a half, only because I put one of the cables on backwards, otherwise it would have only taken an hour. SHES ALIVE!!!! Thank you so much to the person that created these instructions they were SPOT ON!
CAN I GET A A'MEN!!!
Jake Burton - Reply Share
It just worked for me too! Took me about 2 hours, but I tend to work on this stuff extra slowly to be careful. Thanks so much!
Jon Aron - Reply Share
Past 24 Hours: 59
Past 7 Days: 413
Past 30 Days: 1,943
All Time: 94,412
