The iMac is Apple's line of all-in-one desktop computers.
8382 Questions View all
will not boot past apple logo
it will load in a different mac and also with install disk with c-key pressed . it will go past an thought setup
Add a comment
Chosen Solution
Once booted from the install disk run Tools->Disk Utility->Disk First Aid:Repair Permissions, then Disk Repair. Try to boot. If it wont do a safe (shift) boot. Since it will load in a different mac you could have an extension problem, a corrupt font or preference. Safe boot should get you around those. Make a new account and set it to boot to that. If that works you should use Migration Assistant to move your files, then delete the corrupt user.
If this Answer is helpful please remember to return and mark it Accepted.
4 Comments:
ok how do you safe boot and is using the shift key or not
by
Hold the shift key down right after you press the power button, until you see the spinning gear, (wheel) then release.
by
The "shift key boot" does present as list of on screen commands, but immediately goes back to Apple logo only display. No way to input commands on the "monitor" mode. Have no disk connected, just the internal one. Any suggestions?
by
no spinning wheel on screen..
by
Add a comment
ok no spinning wheel just go black after white screen
boot0 :gpt
Boot :done
Boot1:error
1 Comment:
Wayne - Please use the Add Comment link for comments/questions/updates - this space is for answers only. I'm not tracking your comment... is this dialog from the new account, or, from your Apple Hardware Test Disk? If it's not from the AHT run that 2 or 3x and record the codes/dialogs it reports.
by
Add a comment
Add your answer
wayne will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 782
