Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Replacing battery on iPhone 3G
Help! I'm thinking of replacing my battery, but too attached and worried if my data (pictures, notes, etc) will erase completely. I can't back up my iPhone on iTunes because my phone is completely turned off and will not allow me to do so. My question is, if I replace the battery, will I lose all my data?
An answer would be highly appreciated, thank you...
Score -1
Add a comment
Chosen Solution
No. Battery replacement will not affect the data. The fact that you cannot back-up now is the problem. If the battery is not the problem then you have other issues to solve. But after battery replacement your data will be as before the battery replacement.
Score 1
Add a comment
if you remove and replace the battery you should not loose anything. i do it all the time and never loose any picks or other data. just like if your phone dies you dont loose anything. the only way you will loose picks and other data is if you do a reset of the phone. good luck.
Add a comment
Add your answer
lovedeexy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,513
