Repair manuals for over two decades of Mac Laptops—iBook, PowerBook, MacBook, MacBook Pro, and MacBook Air.
30521 Questions View all
clicking sound, loud fan, red light in audio jack...?
Several months ago I replaced a broken keyboard, added RAM, replaced the battery (it was dying...), and installed a new 750GB hard drive into my older MBP. All was well until very recently. The machine started making this weird clicking noise periodically, and the fan would come on very loudly much too often and, I thought, much too loudly. I searched this wonderful forum and found that the clicking noise might have something to do with the Sudden Motion Sensor and I followed the directions to deactivate the SMS. It appeared to fix the problem, until a few days ago. The noise is back, and now, I also get intermittent audio issues; the headphone jack glows red and my audio disappears. I've read about the various fixes for that, but it's not working. Can anyone help, please? I'd hate to go buy a new machine right now. Thanks for your help...
Score -1
3 Comments
Can you give us the last four digits of your serial number so we can identify which model you have. In addition you have a few different things here: an audio problem with the headphone jack and a loud fan issue. which do you want to address first?
by
Last four digits of serial number: PW0J. I was sort of wondering if all the problems are somehow related, since they all began at the same time and might somehow be connected to the installation of the new hard drive/keyboard/battery/ram. Although for the life of me , I can't see how all that is connected. In order of importance (to me, anyway...): clicking, red light, fan noise. Thanks for the help.
by
Thanks for the thoughtful response. The hard drive is brand new, but I suppose it could be bad, right? I've been jiggling pen inserts into the audio jack and the red light seems to have corrected itself. I'll keep my ears open for more clicking sounds. I've been thinking about replacing the machine or parting it out. Thanks again...
by
Add a comment
Chosen Solution
The red light in the headphone jack means that the MacBook Pro thinks that an optical audio cable is plugged into that port. Plugging in an analog device is supposed to "reset" that. If it doesn't points to logic or audio in board problems.
Generally clicking noises are attributed to failing hard drives which are in the front-left of the computer (side oposite of optical drive). When the hard drive is making this noise, it's very likely going to fail soon, so I'd back up essential data... though if your logic board is acting up or damaged it could cause the clicking.
You might want to either part out the machine or replace the HD.
If this answer was helpful please remember to return an mark it Accepted.
Score 2
Add a comment
Red light in the headphone means there is a problem in the analog/digital switch of the port. You need to plug the headphone again. If still this problem remains then again try to plug the headphones again and again.
See about the clicking sound i would say that the hard drive is giving you a warning that it is about to fail due to physical damage. So, if you have important data stored in the drive then back up it immediately otherwise if the hard drive fails then you have to take expert assistance. to recover your data back.
Add a comment
Add your answer
Alan Lifton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,280
