Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Stuck in Kernel Panic Screen at Startup!
My MacBook crashed (first problem in 2 years) (it had the apple logo with the bar that would only go 10% of the way, go back to 0% then 10% then shut off) and I had to restore from my time machine backup, which worked fine except for the fact I choose my windows xp boot camp partition, so I had only used 35gb of my 80gb hard drive.
I wanted to reinstall windows xp on my MacBook. Since I couldn't reparation the start-up drive, I had to do it from the Leopard Disk 1. I then restored it from the time machine backup, it shut off after I left it for 15 or so minutes.
Then I tried to restore it again. It said it worked so I restarted it but I've been having the white screen with the apple logo, but no turning circle that then goes to the Gray screen that says.
"You need to restart your computer. Hold the Power button until it turns off, then press the power button again."
and then that again in 5 other languages below (same screen, I believe this is a kernel panic)
I turned off and then back on but it would have white apple screen (no turning circle) then be stuck for ever.
I then preformed both a quick and full apple hardware test. It said everything had passed.
I tried to repair disk permissions, verify disk permissions, verify disk and repair disk.
I tried holding down the shift key after the start up chime but it didn't make a difference (still white screen without loading circle then goes Gray with kernel panic message.
If any one could help it would be greatly appreciated.
(Also I don't know if this will help but I upgraded the RAM with 2x2gb
and I'm running snow leopard 10.6.2)
Score -1
Add a comment
1 Answer
Chosen Solution
The first thing I'd try is to remove the new ram and reinstall the original ram. Frequently kernel panic is related to memory. try that and let us know if it helps. Ralph
Score 2
10 Comments:
I've been using the upgrade ram fine for a year. Do you think I should still try?
by
Yes--it won't hurt and can be replaced if the fix doesn't work. Ralph
by
You might want to make sure you have a good backup of important data because at some point you may need to format the drive and reinstall from scratch. Not yet though--lets try to work through this. Ralph
by
I added the old ram but it still goes to same Gray screen.
by
Ok, you can put your newer ram back. Now lets try starting up with safe boot which leaves off a lot startup items. I'm including the URL on safe boot so you can see what we are trying to do. If safe boot clears the problem we need to look at the items not loaded for your problem. Ralph
http://support.apple.com/kb/HT1564
by
Show 5 more comments
Add a comment
Add your answer
Riy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 8,166
