1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Questions View all
Question Closed
Monitor colour getting weird.
Hi.
I'm using iMac 2006 17" late Core 2 Duo 2.0 and OS is OS X Lion.
Anyway, I have trouble for monitor.
My English is bad so I explain simply.
I hope u guys understand this. :)
Turned on iMac and just booted -> Colour is good
takes few mins from booted -> Colour is getting weird
↓↓ check my links below ↓↓
This picture is just booted
This picture is takes few mins from booted
I don't know this problem is comes from Hardwares or .icc Profile's glitches.
Thanks.
P.S Anyone have this model's Factory .icc Profile?
Add a comment
1 Answer
Chosen Solution
Apple iMac "Core 2 Duo" 2.0 17-Inch Specs
Identifiers: Late 2006 - MA590LL - iMac5,1 - A1208 - 2114
http://www.everymac.com/systems/apple/im...
Hook it up to an external monitor and see if the issue persists on the external.
If you're running on two GB of RAM (Lion minimum), I would consider upgrading to 4 GB. Go to your system preferences and lower the screen resolution to see if the problem persists. My first guess is that you are stressing the limits of your machine with Lion. To check this try booting from a lower system on an external firewire drive if you have one or try booting in Safe mode (shift key). Let us know your results, please.
Score 2
3 Comments:
Thank you for answer.
I tried your solutions.
External monitor -> External monitor's colour is good and it doesn't change. But iMac is still bad.
Lower the screen -> little works but not helpful.
using lower system -> trying to install Snow Leopard now.
And I using 3GB RAM. I know this is maximum.
I think this problem is comes from screen.
Anyway, after installed Snow Leopard, I comment again.
Regards
by
What's the result when booting in Safe mode? The external monitor shows your GPU (video card) to be good so your issue is most likely with the screen.
by
I tried install lower system(snow leopard). but it doesn't works. and I dissembled iMac for cleaning(i thought this problem comes from dusts) and it also doesn't works.
So, I think this issue is came from screen. Now I have to go Ebay and find screen for replacement.
Thank's for your help.
Regards.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 658
