CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
419 Questions View all
Phone charges but doesn't stay on
So i recently opened up my phone, according to the guide here, in order to try to put it back together to get the screen to work. (The screen was black but the phone and touch screen all worked as normal.)
Well it worked, the problem is in the process something else go screwed up and now the phone wont stay on unless charging on the wall. It won't connect to or charge on the computer. Is there anything in specific that i could've damage that would cause this? Is there a way to fix it?
Comments:
Is there anyone with phone know-how who can help?
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
The battery could be faulty. Or if the battery connector (black plastic socket) that has contacts soldered to the Logic Board, if a solder joint is damaged, could have this problem.
Score 1
Comments:
ok i will check the solder joint because the battery was working perfectly before i went in and dissasembled the phone
by
So it appears to be a problem with the pressure contact on the antenna. if i open up and push it again it"ll work fine for a bit, but then it will die fast after long charging or only work while charging. When it does stay charged it connects to the computer but otherwise it only charges on the wall.
when it only works connected to the wall it'll suddenly lose service and ultimately stop being able to connect to the network until i open it and push the pressure contact again.
How delicate is the pressure contact? Is there an easy solution to fix it or will it be necessary to replace it?
by
Add a comment
This is a battery connector cold solder joint. You need to reflow the battery connector solder and you'll be fine.
Add a comment
Add your answer
kikiz8 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,392
