Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
considering a replacement battery
In the instructions on how to replace the battery, it says to clean all metal-metal contact points with windex, couldn't I just wear latex/nitrile gloves and avoid getting the oil on them to begin with?
Score -1
Add a comment
Chosen Solution
Never clean anything when repairing an iPhone, unless this is a known liquid damage iphone.
Add a comment
Sure you could, but I think it would be much safer to clean the contacts (I stay away from Windex due to the water content, I use isopropyl alcohol) while you are working on it. That way, there is no doubt that they are clean and you will not have to worry about it after its done.
Add a comment
Add your answer
joe buis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 233
