Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
What parts needed to fix iPhone 5S not detecting battery charge?
I recently changed the battery in an iPhone 5s. Before that the phone had been off for a long time and the phone would not turn on nor receive a charge. Now that I've changed the battery (and the screen), the phone turns on but the battery charge doesn't increase or decrease when being used. When the phone is restarted it shows the correct charge but it won't change until its restarted again. I opened up the phone again after reading some questions and answers on this site to see if anything was missing or damaged, and I found that three SMD components were missing between the battery connector and the EMI shield containing the Qualcomm chip. Here is a picture of the logic board missing three SMD components:
I found a picture on this forum about the SMDs around the battery connector, they seem to be labelled C275, C25, and C23. Here is another picture of the diagram showing those components:
My question is do I need to replace those missing SMDs to correct the battery charge display, or do I simply need to recalibrate the battery? And if they need to be replaced, what are those missing components? I've read in some questions and answers that a missing FL11 could cause this issue, but that chip is intact on the iPhone 5s that I'm working on.
Add a comment
Chosen Solution
Turns out that the replacement battery was no good. Apparently there are a lot of fake iPhone 5s batteries being sold that are using components from iPhone 4 batteries, so I got a refund and bought another battery from a seller on eBay and that one works well. Be careful who you buy from, check their customer reviews to see if the seller's batteries have any issues and also check the refund/return policy of the seller or the e-commerce platform you're using.
Score 1
Add a comment
Most Helpful Answer
Those three are likely not to blame, but I would verify that neither of the 2 to the far left are loose. Those will definitely mess with the ability for data about the battery to show correctly.
Score 1
1 Comment:
I checked the two to the far left (FL11 and C279) and they are attached firmly.
by
Add a comment
Add your answer
jacob malu will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 71
