when charging the display says" charging not allowed w/ this divice
my phone charger wont charge the phone.
Clean the iPhone charging port with a clean dry toothbrush. Make sure USB charging cable is good. If still problem, clean iPhone charging port with the toothbrush and a small amount of Isopropyll Alcohol, clean the pins which are on top of the port mid rib.
The charger must be for a different model iPhone. Example, using an iPhone 3G charger will sometimes give that message. Use the charger that came with your phone originally.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 370
