Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
when charging the display says" charging not allowed w/ this divice
my phone charger wont charge the phone.
Score -1
Add a comment
Chosen Solution
Clean the iPhone charging port with a clean dry toothbrush. Make sure USB charging cable is good. If still problem, clean iPhone charging port with the toothbrush and a small amount of Isopropyll Alcohol, clean the pins which are on top of the port mid rib.
Score 1
Add a comment
Most Helpful Answer
The charger must be for a different model iPhone. Example, using an iPhone 3G charger will sometimes give that message. Use the charger that came with your phone originally.
Score 1
Add a comment
Add your answer
jimmy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 370
