Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Questions View all
MacBook Air A1304 Trackpad Problem
MacBook Air A1304
Good morning everybody!
I experience very weird trackpad behaviour in my A1304. Trackpad gets stucked on single click. When i turn my machine and i do not touch trackpad and operate only with external mouse everything is fine, but if i just once touch trackpad it is like operating with constantly depressed left click.
I have tried may different solutions: hard drive and permissions repair, SMC and PRAM resets, clean Mac OS install, cleaning the connectors, etc.
It brings me to the conclusion that I need to replace the topcase, unless you may have any other idea how to deal with this problem.
I also looked for a definite answer if A1237 topcase will fit my A1304. I have found this thread: Can I use parts from a A1237? but there is no conclusion what was the final solutions. I have 1,6 processor so maybe that helps to get final knowledge! Does anyone have experience on this one?
How can I identify my top case verison? Where can i find its part number?
Thank you very much for your help!
Score -1
Add a comment
Chosen Solution
Try reseating the trackpad cable. Here's how: MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement
UPDATE
Apple MacBook Air "Core 2 Duo" 1.6 13" (NVIDIA) Specs Identifiers: Late 2008 - MB543LL/A - MacBookAir2,1 - A1304 - 2253*
The above MAY be your Book. Flip it over and remove the back and battery. This should give you access to the trackpad which is removable. There are eight very small screws that hold it in place and position it. First try just loosening then and move the pad around a bit to see if you have any debris stuck in it. That failing, go ahead and remove it and clean the socket and underside and see if that works. The topcase part # should be 661-5739. Simran (an answer contributor from India) wrote a guide for replacing this that may help: MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement
MacBook Air Models A1237 and A1304 Trackpad Control Cable Image
Guide
Difficulty:
Moderate
MacBook Pro 13" Unibody Mid 2009 Trackpad Image
Guide
Difficulty:
Moderate
Score 3
2 Comments:
Been there... unfortunately
by
UPDATE! I just made a breakthrough discovery! I have unplugged a flex from the click bar and voila! Trackpad works normaly! Now I need to find out What happend with this bar!
by
Add a comment
I wish it was the case. Unfortunately may MBA has trackpad which is welded into the topcase so there is nothing I can do about it. But still my question is valid: is A1237 top case compatible with my machine?
Add a comment
It turned out that the microswitch on the clickbar got stucked. I took a long needle and after couple of attempts managed to pop it out. TA-DA! Everything works perfectly!
Add a comment
Could you please explain how and where did you exactly find that microswitch? I have the same problem but there are so many switches and cables that I am not really sure which one do you mean. Did you take out the track pad or its somewhere on the surface of it (after you take out the battery)?
Thanks a lot!
Filip
Add a comment
Hi Filip,
Sorry to get back to you so late, but I did not visit this thread since May.
The microswitch is on the bottom side of clickbar. You need to remove the screw that is in the middle of metal bezel covering clickbar (after removing battery) so you can see the microswitch. In the center of it is the liitle rod that supposed to be moving and clicking. Try to pop it back with a needle. Hope that helps. If not, give me a shout.
Add a comment
Add your answer
Marcin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 11,956
