MacBook LCD Will not light up even after LCD replacement (Backlight)
Hey guys, I have a Late 09 Polycarb Unibody with backlight issues. I was quoted 200+ at the Genius bar to replace the LCD but decided to change it myself. After a quick installation, I'm still facing the same issue. The screen is powered on yet the backlight is not there and is extremely dim. I can even see the Brightness meter moving across the screen.
Is the next step checking out my logic board? I feel like this won't end well.
Thanks all.
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
First try hooking it up to an external monitor to isolate the problem. Did you get the part from a reputable dealer or off eBay?
Sounds like an inverter board issue, Apple part # 922-8280, to be sure on the part number we need the last three figures of your serial number. The inverter cable is Apple part # 922-8281 but these are only on the Early 2009 machines, so check to see which machine you have.
Score 2
Comments:
sorry sir but there is no any inverter board inside the display clamshell. there is only paper led inside and the LCD cables and network cables only.
by
Add a comment
Check the cables.
Add a comment
Add your answer
novacaak will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 776
