Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
problem SSD upgrading MacBook Air
I bought SSD drive "Toshiba THNS128GG4BMAA for apple macbook air Rev B&C" (Ebay)
I installed it into my MB543LL (late 2008) instead old Samsung HDD. But Apple disk utilites does not see this drive and i can not format or install OS
Is there a way to make this SSD visible by Apple disk utilite ?
Score -1
1 Comment
i find answer myself. This SSD must be connected by inverted hard drive cable
by
Add a comment
Chosen Solution
The drive is probably a 3GB and needs to be slowed down to 1.5 GB to be seen. See if the drive has jumper pins and try 1&2 or 3&4.
Score 3
4 Comments:
is there a jumper on this SSD ?
by
I don't know, look at it.
by
no jumpers on Toshiba THNS128GG4BMAA
by
Contact Toshiba to see if it can be slowed down or if it is compatable: http://www.toshiba.com/tai/support_consu...
by
Add a comment
Were you able to find a cable that will work with that drive?
Add a comment
you can use the same original cable. Just flip hdd to connect (Toshiba THNS128GG4BMAA must be connected not like original hdd) - inverted
Add a comment
Add your answer
Andre will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,987
