Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Why can I not hear the caller?
i had trouble with myi phone 3gs would not charge .I changed the battery and the dock connector,this fixed the problem. the problem i have now, when i make a call the person on the end can hear me,but i can not hear them . if i put it on loudspeaker or use headphones then i can hear them.any clues to my problem. thanks dave
Score -1
Add a comment
1 Answer
Most Helpful Answer
may be a loose connection on #3 connector, this one turns the lcd backlight off when on a call and its the earspeaker.
sometimes get loose or misaligned on the reassambly process, open again and check.
Score 1
Add a comment
Add your answer
dave chapman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 344
