A1502 M.2 Adapter to Pull Data
Hello all, I have an a1502 serial c02mnt85fh00 in for service.
I need an adapter to first pull the data off. It says it’s similar to m.2 2280 however the plugin is different than that form factor m.2. What can I get to pull the data via USB? I’m sure one of you fine gents will have a solution. TIA
Dustin’s PC Repair
3 Comments
Are you sure that’s it? The pins are much shorter on the smaller side it you look closely.
by Dustin Short
I believe it need a SATA one then? I’m sorry it just doesn’t look like that one is going to work. It’s described as similar to 2280 but it’s not 2280 maybe it is Sata?
by Dustin Short
Macs do not use standard NVMe/PCIe SSD form-factors like PC's, the linked adapter will not work for this drive. A close look at the drive pins shows it is keyed differently.
by Chris Green
