Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Black screen after replacing flex cable. [SOLVED]
[THE PROBLEM]
I ran into an issue in the shop where after replacing the Flex cable every screen I tried was black. The iPod wouldn't even beep when plugged in.
Since I googled the tar for a solution, and couldn,' find one, I'll post what I found for anyone else with the same problem who hasn't been able to find a solution.
The solution is moved below, to the answer so that it can be cleared per request.
Score 2
2 Comments
Please use the last paragraph as an answer and accept it to clear the question.
by
Thanks for letting me know guys, I did as you suggested.
by
Add a comment
1 Answer
Chosen Solution
[HOW TO FIX IT]
I covered the circuits around the flex cable and de-solder it then cleaned up the pads and soldered on the new flex.
Not adhering to my own soldering instructions, of course I got in a rush and did this without de-soldering the + terminal on the battery first.
In my case, I went back and disconnected the + terminal on the battery and soldered it back on. The black screen went away and the iPod kicks up just fine.
I hope this helps fellow techs that may have found this.
Score 3
Add a comment
Add your answer
Country Computer Service will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 12
All Time: 3,305
